Go Back   Maxima Forums > Maintenance, Tech, & Care > Fluids and Lubricants
Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-07-2003, 01:56 AM   #41
Quote:
Originally posted by foodmanry
Check to see if the gasket has hardened. If it hasn't then it's ok to use.
Thanks for the advice, put it on a couple days ago and so far so good.
__________________
1994 Maxima SE
Mods: Courtesy clear corners and K&N drop in filter AKA still stock!
max107 is offline   Reply With Quote
Old 09-03-2003, 09:51 PM   #42
HI, I was researching some info for my Infiniti J30(VG30DE) and ran across this thread.
Oil Filter: Nissan 15208-60U00, Baldwin B113(Microlite), Hastings LF385, Donaldson P550227, ACDELCO PF1232
Are some of the cross references I came up with. I am currently using the Baldwin filter with the microlite filter medium and am happy with it. I ordered a six pack from http://www.adiesel.com/ online for $6 per filter(MSRP: $13.25).
Baldwin Cross-Reference
http://catalog.baldwinfilter.com/
Hasting Cross-Reference
http://www.hastingsfilter.com/catalog.html
Fleetguard Cross-Reference - I wish we crossed to a StrataPore™ filter!
http://www.fleetguard.com/fleet/en/catalog/index.jsp
http://www.fleetguard.com/fleet/en/p...stratapore.jsp
Donaldson Cross-Reference
https://dynamic.donaldson.com/webc/W...Code=WEBC_XREF
Wix Cross-Reference
http://www.wixfilters.com/filterlookup/index.asp
CM Filters
http://www.cmfilters.com/spin-on.cfm#cross
springnr is offline   Reply With Quote
Old 12-13-2003, 06:28 PM   #43
Ford Only.
Send a message via AIM to dmontzsta
I dont know if anyone still pays any attention to this thread. But I just went to Autozone and bought a Mobil 1 filter for $11.99 I am going to use it on my change tommorrow, anyone have any experience with them? before I put it on.
Thanks,
__________________
- 99 Ford Mustang GT 5 Speed.
- 2007 Ford F150 SuperCrew.
- 75 Circle Racer with Big Block Ford Power.
dmontzsta is offline   Reply With Quote
Old 12-15-2003, 11:36 AM   #44
Evil Administrator - "The Problem"
bill99gxe's Avatar
Quote:
Thanks,
The M1-208 should work fine.
bill99gxe is offline   Reply With Quote
Old 12-15-2003, 11:42 AM   #45
I'm needing a caw
Jeff92se's Avatar
Yota filters?
Jeff92se is offline   Reply With Quote
Old 12-19-2003, 09:11 AM   #46
bill99gxe's Avatar
Quote:
Originally Posted by Jeff92se
Yota filters?
TOyota.
Old 12-20-2003, 11:08 AM   #47
Ford Only.
Yota filters?
What filter do you use Jeff?
__________________
Old 02-11-2004, 12:43 PM   #48
1992 Maxima SE
Send a message via ICQ to Menel Send a message via AIM to Menel
anyone hear anything about toyota moving oil filter manufacturing to thailand? is there any comparison between japanese version and the thai version?
some are reporting that the thai version of the supra filter is cheap and has a paper filter on the inside much like Fram.
Menel is offline   Reply With Quote
Old 03-24-2004, 01:44 PM   #49
I'm needing a caw
Jeff92se's Avatar
Cut up Toyota 90915-YZZA2
http://www.autoxreview.com/reviews/P...il_filters.htm
Old 03-24-2004, 09:09 PM   #50
zcd
say no to 'yota
I tried the Toyota filter on my 93se, not only did it make the ticking louder, it does it all the time now. I'm about to drive the car off a cliff I'm so sick of it's issues.
dmontzmax, I got one of those the previous oil change, it did nothing to help the ticking whatsoever, just another oil filter, and expensive too.
zcd is offline   Reply With Quote
Old 03-24-2004, 09:20 PM   #51
I'm needing a caw
Jeff92se's Avatar
Don't blame the filter. Once your VTCs are past a certain point, it will clack no matter what you do.
Quote:
It's a proven quality filter and it's actually alot cheaper than a K&N/Mobil 1/Napa gold. It's not cheaper than a Fram but then again, who in hell uses crappy Fram filters. I only paid $3.29 ea for my Yota filter
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Old 03-24-2004, 09:28 PM   #52
zcd
Jeff, I was responding to dmontzmax about the Mobile filter, and I paid like $4 w/tax for that Toyota filter.
Old 03-24-2004, 09:37 PM   #53
I'm needing a caw
Jeff92se's Avatar
I was just stating it wasn't the Toyota filter's fault that the VTCs are ticking. Every person that has tried it, has noticed a decrease in VTC noise.
Old 03-24-2004, 09:47 PM   #54
NWP Engineering.com
Aaron92SE's Avatar
Send a message via AIM to Aaron92SE Send a message via MSN to Aaron92SE Send a message via Yahoo to Aaron92SE
I immediately noticed less ticking. But then again, the ticking came back to normal. It's just b/c my VTCs are old.
Before you drive the car off a cliff, if it's a 5spd, try to sell it to someone that will appreciate it. If it's an auto, drive it off a cliff.
__________________
NWP Engineering Phenolic Thermal Intake Spacers
10hp and 12ft-lb gain & 40°F temp drop on the VQ35DE
Engine Torque Link Bracing Kits now available for the 1995-2003 Maxima!
The first VQ35DE Full ECU engine swap in a 3rd gen Maxima
92 Maxima SE Auto VQ35DE Swap
VE Auto PB: 12.8 @ 104mph w/ 75 shot
VQ35 PB: 12.76 @ 108 mph ALL MOTOR
Winner of the MAXUS 09 NA Maxima Unlimited class!
Aaron92SE is offline   Reply With Quote
Old 03-25-2004, 07:48 AM   #55
Whats wrong with using a Frame filter ? They seem to be working fine for Max !
rimmer1 is offline   Reply With Quote
Old 03-25-2004, 09:27 AM   #56
I'm needing a caw
Jeff92se's Avatar
I take it you haven't read any of the stickies in this section
Quote:
__________________
Sold Jan 14, 2006'
Mod list:
Old 03-25-2004, 09:51 AM   #57
Ford Only.
hahahaha
__________________
Old 04-02-2004, 05:12 PM   #58
Send a message via AIM to fugi43
Hey,
I picked up 7 fiters (60U00) for $42 in GA today... That was just the Nissan dealer. I still haven't tried Infinity yet. I guess there's still hope. If anyone wants more I'll check for you. I'd be cost + shipping (~ $6 ea w/lrg quantity + shipping)
So, what's the shelf life on these things (w/the shrink-wrap)?
Lata,
Matt
P.S. - Sorry all you S. Georgia Z guyz
P.P.S. - 60U00's listed on Ebay
fugi43 is offline   Reply With Quote
Old 07-10-2004, 02:45 PM   #59
Send a message via AIM to OoTOAoO Send a message via Yahoo to OoTOAoO
I've looked at the stickies and I don't see where it says frams are bad.... I just put one on my 91 GXE, i've always used them, should I look into using a different one? What will be my gains?
josh
OoTOAoO is offline   Reply With Quote
Old 07-23-2004, 04:19 PM   #60
I would just like to add another testimonial to the Toyota filter.
About 3 weeks ago I changed my oil and removed my Nissan 15208-60U00 filter, replacing it with identical oil but using the Toyota 90915-YZZA2 filter instead. Over the last 3 weeks I have (so far) noticed a significant decrease of instances of cold startup valve clatter. I can probably count on one hand the number of times it has rattled upon a cold start out of dozens to date.
It seems to be a very high quality filter, and identical to the US version. I paid about $11 after tax.
Previous oil filters such as the Nissan 15208-60U00 and Purolator's Pure ONE all rattled with roughly the same frequency.
My VTC assemblies are fine, as far as I have been able to tell, and the engine has always had its oil changed regularly.
This filter is a pleasant surprise, and without the supply problems of finding other premium quality filters.
To answer OoTOAoO's question, Fram filters are very cheaply made with smaller filter elements, and just don't tend to inspire confidence when you look inside them. Fram makes the vast majority of cheap, generic, rebranded filters for others as well. For your GXE this isn't as big an issue and they should work "okay", but there is better stuff out there.
Bman is offline   Reply With Quote
Old 09-30-2004, 12:47 PM   #61
Send a message via MSN to Loe max
Quote:
josh
5-7fwhp
Billions Nissan in Sioux Falls, SD at least the guy at the counter, said they didn't have any more of those filters around. I'm going to check Nissan and Infiniti dealers in Minnesota as well as maybe Toyota dealers if I can't find any. I can hear one or two clacks upon cold startup's now, but that maybe due to the fact that its been 4,200miles since the last oil change
Loe max is offline   Reply With Quote
Old 10-04-2004, 12:40 PM   #62
Bill99gxe have you looked at aftermarket filter's that cross reference with the Toyota 90915-YZZA2? According to Purolators website, they seem to have a filter part# L14476 http://www.pureoil.com/ProductFinder.aspx?action=IG
According to the spec sheet http://ecat.arvinmeritor.com/smartlink/?partnum=L14476 it looks as though there is an anti-drain back valve but I'm not sure if this filter is similar HD as the Toyota filter.
Here are other cars with this type of OEM filter http://www.pureoil.com/ProductFinder.aspx?action=WUG Just type in the purolator part#L14470. It looks as though Chevy and GEO also uses this filter. I'm sure you can walk into your Chevy dealer and buy a similar filter for cheaper $$$ than a Toyota one.
__________________
-Loe-
2000 BMW 328Ci 5-speed (sold)
2004 BMW ///M3 SMG
2004 Audi S4 V8 6speed
Old 10-04-2004, 12:42 PM   #63
I'm needing a caw
Jeff92se's Avatar
Why? If you want to use a Purolator, just use the one that x-references with the Nissan filter. I paid less than $4 for my Toy filters. And I assume you read my stickie in the 3-gen section on where to get them
__________________
Sold Jan 14, 2006'
Mod list:
Old 10-04-2004, 01:11 PM   #64
I typed in the Nissan filter and it doesn't seem to cross reference with anything. When I type in the make,model,year it seems as though they list the same part# for both SOHC and DOHC Maxima's. I thought there were no aftermarket filters for the VE, thats why I suggested to use the Toyota to x-reference yes, I do read 3rd gen stickies
Old 10-10-2004, 12:47 AM   #65
bill, any ideas on if these toyota filters would work on an i30/vq30de? i checked autozone and you can use both mobile1 filters between a 97 i30 and an 97 camry. if it definitely works, i'm heading over to toyota and grabbing some as i have to replace my filter soon.
??? is offline   Reply With Quote
Old 10-14-2004, 11:25 AM   #66
bill99gxe's Avatar
Quote:
Toyotas generally use a 3/4 thread, most 95-on Nissans use a M20 thread......they are technically close, but I wouldn't put a metric threaded filter on a english threaded motor and vice versa.
Answer: No, they do not cross reference. Nissans made in '94 and before generally have a 3/4 thread as well......
Old 01-04-2005, 12:26 PM   #67
about the little fiber washer,its for the drain plug.This is what the toyota parts guy said.Also its not the right one.He exchanged it for a copper one.The kind that are used on spark plugs.He said that the plain fiber one will leak.I`m trying that toyota filter since my ticking has escalated.I also tried lucas oil treatment.It stoped about 50% of the noise,and with this toyota filter maybe the noise will completly go.
Thanks for the info about the toyota filter....
kenjr is offline   Reply With Quote
Old 02-21-2005, 10:44 AM   #68
Send a message via AIM to aph111 Send a message via Yahoo to aph111
Anyone have specifics on oil to go with filter.Is a certain brand-velocity helping VTC problem more than others??
aph111 is offline   Reply With Quote
Old 05-11-2005, 04:20 AM   #69
Looks like jerry rome nissan still lists the 60U00 filter for the VE which you can order, but im not sure if they actually do carry it....
EDIT: Nevermind, their database is outdated and superceded with the 55 model.
aussie983 is offline   Reply With Quote
Old 07-02-2005, 12:13 AM   #70
VE Powah!!!
Duckman540i's Avatar
Send a message via AIM to Duckman540i
Well I just put in the Toyota 90915-YZZA2 now called the "90915-YZZF2" (same filter) I used to get VTC Tick 50% of the time on over-night cold starts for about 1-2 min. With the Toyota Filter, it has eliminated it completely! Good little filter, real small compared to the Nissan one, but a perfect fit. I payed $6.45 @ the local Toyota dealer and it's worth every penny! I highly suggest this filter!
__________________
'92 SE 5-Speed:
Super-White, Black Leather, All Options.
Mods: Way Too Many To List
Duckman540i is offline   Reply With Quote
Old 10-10-2005, 05:44 PM   #71
down to my last 100k
wow I just found this thread on the ticking... lol so funny cause i feel so embrassed st stop lights and fast food drivethru's im going tomorrow to toyota for a filter. Anyone know the best oil to go with the toyo filter? thanks
slickblack94 is offline   Reply With Quote
Old 10-30-2005, 11:34 PM   #72
Why not get a single or dual remote oil filter kit; flow and if mounted with filter end down, a massive oil reserve for start-up.
Of course, you can install a ing. kill switch, so that you can crank the engine over until oil pressure is obtained without starting it. I believe the F1 has such a system.
Maximum Tune is offline   Reply With Quote
Old 09-25-2006, 10:28 PM   #73
More on topic info with pictures and part numbers in this following thread: running 11's
TempMaxMan is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
