How to flush automatic transmission fluid? What ATF to use? How to check the level?
#241
Originally Posted by andrei3333
i do want to drop the pan but i dont wanna play with any return lines, and duno where to get the thread sealant sky jumper is referring to, so i may just keep doing these drain and fills like once a year or so to preserve the tranny.
#242
Lucas Tranny Fix is Amazing
Ok So I did an drop and drain a month ago. Cleaned out the magnets and then filled with Nissan Matrix D ATF. Wow the car shift so much smoother. Then a few weeks back I did another drain, but no drop this time. I then added one full bottle of Lucas Tranny Fix (very thick stuff) and topped off with Nissan ATF. Wow what a difference. I thought the car shifted smoother before, but now its even more smoother and quieter too. I guess that Lucas Stuff actually works. I would recommended it for sure!!!
#244
I know how a flush...technically dosent flush 100% old fluid out, and for good reasons too, but will numerous flushes really do anything for me?
I just got one done, and havent noticed remarkable effects.
Will doing 3 more flushes within the next 9 mnths actually help and or will I see great improvements? I got a used 02 auto with 77k . I dont think the car was mainatained that well mechanically.
#245
I think you'll notice a diff w/ more "flushes" done. I did. After one time I didn't seem to notice a lot, but the next time I did. Not sure if it was just a matter of time thing or not, but sure did seem to improve after 2 changes. Doing another 2 b4 years out to make sure ALL (or darn close to it) the old is out.
#246
Originally Posted by MichMaxFan
I am trying to find the thread sealer, too. Supposedly the Permatex #3 is ok to use, but the closest I can find is, I think, what they call their 3D grade and designated for aerospace app's, so really not sure what the grade #3 really is....is the 3D grade what people are talking about? I don't wanna screw up any sensors w/ trace amts of stuff that might be bad.
#248
hey guys i have a question i just got an 04 SL with bout 44,xxx on it and idk if the fluid has ever been changed it looks alittle redish doesnt smell burnt i dont have a manual with the car nor any maintance records i know it shouldnt be changed now cause it looks fine but what greater mileage should it usually be changed and is it better to be flushed or just drain and refilled cause i got this maintance price book from nissan with the prices and it had a flush and then just a fill one.. thanks
#249
1. It's NOT too early to flush...in fact, you'll find according to many, that you're late.
2. Read this entire sticky on the ATF...lots of help in there. I have read many posts over and over to gain a solid understanding of working on my car and frequency of fluid changes.
3. Doing a drain/fill gets only 50% changed, so if you do it now and wait another 40K, then half of the fluid likely will be 80K miles old, which is a HUGE NONO according to tranny experts. You'll likely need atleast 3 more drain/fills or one entire flush, but read up on flushing because power flushes are NOT recommended, but there is a flush method w/ the tranny lines that IS recommended in place of the power flush, if you choose not to do the multiple drain/fills to purge the old fluid out.
Hope this helps.
Hope this helps.
#251
Hope this helps.
Hope this helps.
#252
Originally Posted by macneil17
thanks.. so then if i went to nissan to do this do u know what kind of flush do they do..
but once a year a drain and fill at the dealer is not that bad actually
#253
No, nissan will tell you that the "tranny oil pan does not need to be removed" which means they only do drain and refill service. If u want to drop the pan u have to go to a private mech, or DIY.
#254
i feel really lazy right now and dont wanna pull out the fsm, but what does it recommend dropping the pan or drain and fill?
but i asked the dealer exactly the same question before i serviced my car. There are 3 ways of servicing the auto tranny: drain and fill, pan removal, and power flush (using the famous T-Tech machine) which is not recommended.
#255
#256
anybody tried to use Pennzoil® Dexron®-III Mercon® ATF for flush?
if yes, how does it fill while shifting?
#258
well yeah you could do that but i dont think nissan actually recommends it.
#259
Well, i think thats the job of the customer to do their own research, cars are all the same and at the same time they are all different.
I was curious about this service from the dealer because of my past car transmission experiences, so i went ahead and did something unthinkable: I actualyl ASKED a question at the counter!
To be honest the dealer was not hiding the fact that they just drain the pan, so i dont think they were evil and conspired to take my money.
Btw just to clarify, dropping the pan and cleaning the magnets will empty out the same amount of fluid as just draining the pan, correct ? i want to do this beforethe year is done but do i NEED this permatex sealant or not, shouldn't the gasket hold, it does have like 21 bolts hahaha ?
#262
I have an 05 Altima, with the 3.5 engine and Auto 5 speed. It's the same trans as an 05 and 06 Maxima
If I'm going to do a complete transmission fluid replacement, would it be safe to drain the fluid out from the return hose and then pouring fluid thru the dipstick tube?? Would a component inside the trans be damage from not getting lubrication from the return hose of the cooler?
#263
I can't speak for your year, but I assume it is like my 2000MY. I have just drained the pan and refilled and repeated that a few times. On my van, I just did a drain/fill and then used the return line as well to purge the converter of fluid. This way I got all (I think) out at the same time. Wow, I was amazed at how easy it was w/ the return line on my van. Only thing is to make sure that you put back into the trans what you drain from the pan and it must be to proper level before doing anything w/ the return line. Don't let more than 1-2 qts come out of the return line at a time. If you run it dry, you damage the tranny. My van came out REAL fast, like 1qt in about 6-8 secs. I have not done it on my max yet w/ the return line, but probably will in the future. Let out a quart, put one new one in. Let out another quart, put new in, etc, etc.
#264
Thanks for replying.
The method you describe sounds good. The first time that I drain and refill the tranny I was able to get 3 quarts out.
So maybe it would be safe to get out about 2 quarts, then refill (using the line method). Then repeat the process again.
#265
Also, I would stay away from getting 2qts out in one time if you do the tranny line method and keep it very minimal (If that's what you meant in your post). The system needs fluid, and I don't know how low it can go in the pan before you start sucking air and damage the trans, so I would really keep it to 1 qt and just do it multiple times, after replacing the old w/ a new qt of fluid, obviously. Keep careful track of how much you drain from the pan and let out of the tranny line and how much new you put in. Always put back in what you took out before you run the car again.
#266
does anybody know if it's ok to switch from synthetic to regular tranny fluid? i did a flush with mobil 1 synthetic ATF and my 1-2 shifts started becoming slow at high rpms (5-6k) i'm thinking about flushing the synthetic out and going back to regular fluid.. i dont know if that would make sense or not.. anybody have experience doing that?
#270
Licensed to Spell
Sorry guys but I didn't have the patience to read the whole thread. I recently did a full transmission flush and installed a Hayden 403 cooler. I used Jime's method for flushing the system. I assume the website for Jime's instructions is common knowledge so I won't post it here. I deviated from his write-up just a little. For one, I disagreed with him that the pan should not be lowered, cleaned, the magnets cleaned and the filter replaced. I drained my fluid, dropped the pan, cleaned it well, changed the filter with a new OEM filter, replaced the two magnets (cleaning them probably would have been fine) and re-installed with a new gasket and new pan bolts and a new drain plug washer and drain plug. To do the flush, I did not remove the feed line at the radiator like his write-up suggest, I removed the return line at the transmission. That way I got out all the fluid that would be in the return/feed lines and in the radiator. It went well. It is much easier to have a partner start/stop the car. I went with Mobil 1 synthetic. The problem is that I literally bought my original 10 quarts over a year ago (yes, I am lazy). Well, it turns out I drained a little more than I was putting in and I ended up needing one or so more quarts. Well, my bottles from 1 year ago state Dexron III on the bottle, the new Mobile 1 ATF only states Mercon V! Nowhere on the bottle does it say it's o.k. for Japanese or Dexron cars. I only need 1 or 2 more quarts so I really hope it's o.k. to mix. Why did Mobile 1 do that???? The cooler install went well too. Overall, I'm really glad I did everything.
#272
Maxima.org Sponsor and Donating Maxima.org Member
Concerning the fluid level, you just need to be patient with it. After refilling your transmission, start the engine and move the gear shift through each gear. Put it back in park and then check the fluid relative to the "cold" markings. If you're below the minimum mark, add a small amount of fluid to bring it to the Cold range. When you're in the range, drive the car for 5-6 miles to warm the transmission to normal operating temperature, then check it again using the "hot" markings (vehicle at normal operating temp, level ground, idling in Park). If you need to add fluid, do it a little at a time so as not to overfill it.
#273
even if it is the wrong fluid though, i doubt if 1-2 quarts would do much with 10 quarts of the right stuff
#274
Licensed to Spell
QUOTE=FishyMan;6160087]When I DRAIN/ REFILL, how much do I do it?
Are u sure 9.4 qts?
Damn seems a bit too much. I can't get a good reading, damn it.[/QUOTE]
I was just telling you how much the whole system takes. I wouldn't say 9.4 qts sounds like a lot when you consider the pan, the torque converter, all internals and paths, etc.
The Haynes, Chiltons and FSM are very vague on the drain and re-fill amount. They just tell you to measure what you take out and put back in the same amount. But, from what I've read:
If you are just draining and re-filling, refill with about 4 qts.
If you are draining, dropping the pan and refilling, go with 5 qts.
Just start with the above numbers. Then go for a short drive, let everything heat up, shift through the gears, read your dipstick and add fluid accordingly. Not really a big deal.
Are u sure 9.4 qts?
#275
you know, i had that same issue.. i called mobil1 about it and they said that they only have 1 kind of synthetic ATF and it meets or exceeds the dextron III requirements... i also went on their website and it said the same thing.. so i did a full flush with that stuff.. now, granted my transmission did start to slip in high RPMs about 1,000 miles later, so.. i dont know.. it could have been coincidence, or it could have been the wrong fluid.. my tranny did have over 100k on it and i drove it hard sometimes.. but pretty convenient that it started slipping soon after i did the flush
#276
Licensed to Spell
Ahhh, you are killing me wyche. Crap, not what I wanted to hear. So you used the Mercon V Mobile 1, right? I know Jime has been using the stuff for years and I don't think he has had problems (although he probably bought it when the bottle read Dexron III ?). What did you end up doing? Fix your trans? Switch back?
I guess I'll just go for it, I'll stick 1-2 qts of the Mercon V Moble 1. It will only make up 10-20% of the total fluid so hopefully, if it is the wrong stuff, it won't be that bad. I'll let you know if my trans breaks in 1,000 miles! lol I also hope that by letting my 10 bottles sit in my garage for 1.5+ years, the fluid didn't age/break down. :I Thanks for the input.
#277
Licensed to Spell
If you're going to use a synthetic ATF, give AMSOIL a try. It's specifically labeled as meeting Nissan-matic D, J and K requirements. I sell a lot of it to members on this site and people are very pleased with it. It also works great in power steering systems requiring ATF.
#278
Just start with the above numbers. Then go for a short drive, let everything heat up, shift through the gears, read your dipstick and add fluid accordingly. Not really a big deal.[/QUOTE]
I seriously cannot get a reading confident enough. I have driven the car hot enough and measured it that way, both hot and cold show some fluid pass the limit. Even overnight cool-down, next morning. The reading shows it going past a bit. "Maybe, I'll get a picture". This sounds stupid, but does anyone have a picture to educate? I had no problems with these with my Hondas. The dipstick was easy to read w/o hesitation.
The thing with the drain and refill is, I am not sure if the PREVIOUS owner did it properly. So if they refilled too much, then if I drained and put back the same, wouldn't I be putting too much?
#279
Licensed to Spell
Yeah, you are right. If the car previously had the wrong total amount, you measure, say, 4 drained quarts, re-fill with 4 new quarts, then yes, you'll still be at the wrong level. But I'm not quite sure what your problem is. It sounds like you are clearly reading your stick and you have too much fluid. Period. What is it that makes you think you aren't reading your stick correctly? You'll need to open your drain plug for a few seconds or use a medical syringe and long tube to suck a little out.
#280
I can read the oil w/o problems, well it is pretty easy to get the right level. I think I might've there's a bit too much ATF in it. I will drain it all out and post what I find.
I'll take some pictures, hopefully you and some others can chime in.
I appreciate it.
Thanks.
