Go Back   Maxima Forums > Track and Tune > Dyno Discussion and Slips > Dyno Slips (moderated)
Dyno Slips (moderated) Post your dyno slips here. Please be sure to include your modifications as part of your post.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-02-2003, 06:44 PM   #1
Send a message via AIM to MardiGrasMax
428.16 hp - 379.33 tq - 1998 GXE manual
Air Temp 58.1F
Baro 29.49Hg
CF 0.97
Actual Totals were 439.76hp & 389.61tq
Modifications...
Vortech V1 Super Charger
Vortech 2.62" Pulley, 15psi Peak at Redline
Vortech FMU w/3:1 Calibration Disc and Boost Bleeder Valve
Vortech Mondo Blow Off Valve
Nissan 300ZX TT 370cc Injectors
70mm Throttle Body from 3.5L Pathfinder
Bored and Port Matched Intake Manifold TB Port
Custom 3" Super Charger Cross Over Pipe
Custom 3.5" Mandrel Bent Cold Air Intake for SC with K&N Filter
Middle East Variable Intake Manifold (ME/VI)
G-Force ECU Modified for Normally Asperated Performance & Stock Injectors
J&S Electronics Utlra SafeGuard Ignition Controller
Fields Hyper R Boxer Series Air Fuel Controller
Water Alchahol Injection from 9psig up 50% Water/50% Denatured Alch.
Nitrous Oxide Systems 35HP Dry Nitrous System, 2deg Ignition Retard
Nitrous Oxide Systems Bottle Heater
Warpspeed 3" Y Pipe Wrapped with Thermo-Tech Exhaust Wrap
3" Test Pipe, Wrapped with Thermo-Tech Exhaust Wrap
Warpspeed 3" B-Pipe with Resonator
3" Magnaflow SS Straight Through Muffler
SMC Short Shifter
Clutchnet.com Six Puck Sprung Hub Clutch and Heavy Duty Pressure Plate
Place Racing Urethane Front and Rear Motor Mounts
Walbro GSS342 255lph High Pressure In Tank Fuel Pump
NGK BKR6E V Power Copper Spark Plugs, 1-Steps Colder Than Stock. 0.030" Gap
Spark Plugs Are Indexed Using Moroso Indexing Washers
Harlen Components RPM Switch (For ME/VI Valve Control)
Harlen Components Window Switch (For Nitrous Control)
Autometer Dual Pillar Mount Gauge Pod
APEXi Electronic EGT Gauge (Pillar Mounted)
Autometer 0-100psi Sport Comp Full Sweep Electric Fuel Pressure Gauge (Pillar Mounted)
J&S Electronics Knock Monitor Gauge w/ Air to Fuel Ratio (Pillar Mounted)
Custom 3 Gauge DIN Mount
Autometer Sport Comp 30hg to 20psi Vacuum/Boost Gauge (DIN Mounted)
Autometer Sport Comp Mechanical Oil Pressure Gauge (DIN Mounted)
Autometer Sport Comp Electric Oil Temp Gauge (DIN Mounted)
Perma-Cool Oil Cooler
16psi Radiator Cap
Brembo Cross Drilled and Slotted Front Rotors
Stillen Cross Drilled Rear Rotors
Porterfield R4-S Front & Rear Brake Pads
Goodridge SS Braided Brake Lines
Generic Front Strut Tower Tie Bar
ADCO Rear Sway Bar
Eibach Springs
KYB ABX Struts & Shocks
Quaife ATB Differential
Redline MT90 Gear Oil
Redline 10-W30 Motor Oil
16x8 Mazda RX-7 rims (16lbs)
225x50-15 Dunlop SP5000
15x7 Kosei K1 Racing Wheels (14lbs) (For Track Use)
M&H 24.5x8.5x15 Drag Slicks (For Track Use)
Some Hyper White blaahhh blaahh blaahhh...
__________________
Parted out and sold the fastest that was...
Now a G35 Sedan, Built Motor, Greddy TT... Trying to be as fast on street tires and the Max was on slicks
MardiGrasMax is offline
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
