Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
NISformance 2004 Maxima FWD HR stock cams 320 whp 285 tq
Old 10-02-2017, 03:09 PM
HR Swap Pioneer
SurraTT's Avatar
Here we have a 2004 Maxima with 2009 Maxima FWD HR engine
We originally worked on this car many years ago.
2009 Maxima engine (stock internals)
Ebay altima ser headers
3" crush bent catback
NISformance 4" short ram intake
GTR injectors
350Z RevUp ecu
Gutted upper intake manifold (since the z ecu cant run vias anyway, thats why under 3700 rpm there is a dip, working vias would fix this)
UpRev reflash tune
The car is now fully dyno tuned on this setup making great power at 313 whp.
We have been doing a lot of testing and running 3.5" intakes for a while now so we decided this car here would be a perfect test car since it has our 4" intake on it.
All the following dyno runs are from today, on the same car with same air temps , coolant temps, oil temps, and AFR ratio. the ONLY changes are the actual intake pipes.
This first graph is how the car was setup by us years ago with a short ram 4"
313 whp 283 tq with the top end pretty flat after 6200 rpm
Here is some 3.5" intake testing we tested 3 different lengths.
By changing the intake lengths we can move around a nice bump in power. The bump in power really helps the top end power and torque. We are not looking at just peak numbers, there is actually a nice gain in the top end.
Zoomed in at the top end. Clearly can see the differences.
Ok so now we overlay the 4 and 3.5 intakes.
The red, blue, green, yellow are same from previous pic of different length 3.5" intakes. The dark blue , brown, olive are 4"
Zoomed in on the top end
Zoomed out, kinda cluttered so hp and tq on 2 separate pics
Its pretty clear the 3.5" makes more power in a few areas over the 4" in the midrange and top end.
In conclusion, intakes yeah they are a big topic in the FWD VQ community. We have been making intakes for a few years now but not in a full production scale. We originally tested the 4" in 2012 and made 300whp on stock cams. Which was a huge accomplishment back then. But now we have our own dyno and are able to do more in depth tuning and testing. As a result of our testing here on this car and many other cars we simply run 3.5" intakes for the clear power gains over 4". If you have headers , catback exhaust, tune, and intake then chances are your car is making good power no matter what exact intake you may have. In some of our testing we have not shown any difference between these intakes on cars with smaller exhaust or headers that have very small runners.
Thanks for all the support over the years! Our mission is to push the platform into a new performance level.
All testing proved by www.NISformance.com
SurraTT is offline
Old 10-02-2017, 03:18 PM
HR Swap Pioneer
SurraTT's Avatar
Pic of intakes tested.
All tested intakes manufactured by NISformance
SurraTT is offline
Old 10-07-2017, 05:01 PM
Itz Shak's Avatar
Good stuff. I'm assuming this would apply to DE's as well?
Itz Shak is offline
Old 10-14-2017, 05:33 AM
HR Swap Pioneer
SurraTT's Avatar
We have not tested many different length intakes on DE yet. But results should be similar.
SurraTT is offline
Old 08-15-2018, 09:05 AM
Lightly modded
95maxrider's Avatar
Any updates on intakes for DE motors?
95maxrider is offline
SurraTT
06-26-2017 08:43 AM
sparks03max
63
01-04-2012 06:45 AM
96sleeper
35
04-07-2006 01:23 PM
Rafe
07-09-2004 12:57 PM
Quick Reply: NISformance 2004 Maxima FWD HR stock cams 320 whp 285 tq
