NWP Engineering 92 Maxima VQ35 NA AT - 271whp & 244ft-lbs
2/19/10 Edit: I went back to do some more dyno tuning at National Speed, Inc in Wilmington, NC. This time, my 128mph speed limiter was removed from my 02 Maxima AT ECM. I installed an 03 Maxima 6spd ECM, which I found out has a 145mph speed limiter (dyno proven). So I still was not able to max out 3rd gear. But my power is dropping off around the same time my speed limiter kicks in, so it's not a big deal.
We were finally able to tinker with the ignition timing. We found out that between 3500-4500rpm, the engine put down as much as 18 ft-lbs of torque MORE by retarding the timing by 4-5 degrees. I had it set around 29 degrees in this area before and the engine responded well to dropping the timing. Also, on top end, I had the timing set around 28-33 degrees. When we retarded the timing down to around 26 degrees, the engine did not loose any HP. So we kept the timing lowered.
Also, uncorrected, it put down 290whp!
This is the first dyno since I finished the engine swap. It made 271whp and still climbing strong when the stock speed limiter kicked in around 130mph. With STD, it's making 278whp and 251ft-lbs.
I will be using a 6spd 03 Maxima ECU and that should solve my speed limiter issues on the dyno. I can't wait to find out what kind of power this engine can really lay down, especially when the engine tune is to my liking. We haven't completely tuned for the absolute best ignition timing.
I still don't know how high this engine is producing significant HP.
Edit: Here is a 2nd gear dyno run that I did during the Dyno Day on Saturday. The HP will be lower in 2nd gear. The signal cut out during the run, but at least it gives me an idea of how much power I'm making at 7200rpm when the UTEC's rev limiter kicked in. For my next dyno session, I will extend the rev limiter.
I included the same 3rd gear run you see above so you can compare.
Edit again: Here is a good comparison of how my engine reacts to the cutout being open. An instant 20hp!
Edit again: Here is the video.
http://www.youtube.com/watch?v=Of39Ck6gLqA
That power just keeps on climbing!
Didn't you try to dyno it in 2nd gear? If so, I'm sure the numbers were inflated, but I'd really like to see what the graph looks like all the way to 7200.
2nd gear shouldn't change anything, the dyno operator can usually correct for different ratios. That engine is making great power with just a lil less tq than I would expect for a 3.5l
The numbers would be inflated, if the dyno operator doesn't correct them. He should be able to rev it all the way to 7200 in 2nd gear...
Impressive numbers Aaron, hard work pays off. I dont think those numbers are inflated considering the work you have put into this built motor. Did you dyno with the TC locked or unlocked?
Why would you want to dyno in 2nd gear? 3rd gear would give you the most accurate HP/TQ numbers.
Those are some good numbers Aaron!
With tuning you will surely see improvements...
Maybe with a 3inch exhaust and cams I can get close to those hp numbers...
I need to shed some serious pounds to come even close to your car weight though...
Thanks everyone!
I have the rev limiter set to 7200 at the moment. But as soon as I solve my speed limiter issue, I may need a higher rev limiter to take advantage of all the top end power I'm making. I built the engine to easily handle over 7500rpm if I need to rev it that high.
We did one pull in 2nd gear just to determine if it was a speed limiter related issue or some weird rev limiter issue that was only lower on the dyno. It was a speed limiter issue for sure. That one 2nd gear pull we did lost the signal after 5K. But the only reason we did it was to make sure 2nd gear would rev to 7200rpm as it should.
AFR is a smooth 12.8-13.0:1. Ignition timing goes as high as 31 degrees on top end. Deluboz cams. The rest of my modifications are shown here:
http://www.nwpengineering.com/mods.html
The TC was locked on all runs. With it unlocked, the power isn't as smooth and tends to spike on low end when you first go WOT.
The cutout produces 20hp though when it's open. I do have the stock and very restrictive muffler and Bpipe. I like being quiet on the street.
Thanks everyone!
Good that you had TC locked that means ur numbers are even more accurate. I remember when I unlocked mine on a dyno it showed about 15% less power, but thats ofcourse because of the change in gearing n such..
Good stuff man, I am very interested to see your nitrous numbers now!!!!! That should take care of the lack in torque
Yeah cutout is always going to be a huge plus (20hp) on the flip of a button is awesome!
I haven't found any concrete information yet. But right now, it appears that a 2003 Maxima SE 6spd with 17" wheels and LSD had the highest speed limiter (149mph or so) or none at all. That's the ECU I have waiting to go in. With a 149mph limiter, I should be ok until I'm ready to do low/mid 10s on 22" slicks.
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
I haven't tried. Regardless, the 6spd ECU is going to be installed in order to fix my cruise control. If I ever run into that speed limiter, then I'll worry about it then.
I have a strange feeling that my car does not have a speed limiter at 149mph. If you do hit a limiter that fast, you would probably also be upgrading to bigger tires to make 3rd longer, which would probably throw off your speedo and let you reach higher speeds, anyway.
But instead of changing my slick size, I will just remove the speed limiter if the one on the 6spd ECU ever becomes a problem for me. There are ways to remove it, Technosquare can I'm sure. And I may be able to just trick the ECU and prevent a speed signal from going to the ECU from the cluster.
There has to be a simple fix for the limiter, although I have never messed with that, oddly enough mine dosnt have a limiter I dont think, i have maxed out the speedo and no limiter, I dont even think 97 GLE is supposed to have an extended/removed limiter. So im sure its not something hard to do, cut wire or some simple thing.
I may be making gobs of power at 7200 as well. That's why I built up the valvetrain. If I need to rev to 7700, I will.
Yeah from the look of that curve, you may be making peak power around 6700-7000. That's interesting for those somewhat mild cams, but your IM/head porting has probably gone a long way towards shaping the curve for topend.
I hope to get my 6spd ECU installed tomorrow at the dealership. They will be able to reprogram my NATS. And I might as well get a new key made ($80 OUCH!).
Does anybody know if the dealership will be able to easily see if there is a speed limiter on the ECU?
Here is a 2nd gear dyno run that I did during the Dyno Day on Saturday. I edited the original post to include this chart.
The HP will be lower in 2nd gear. The signal cut out during the run, but at least it gives me an idea of how much power I'm making at 7200rpm when the UTEC's rev limiter kicked in. For my next dyno session, I will extend the rev limiter further. There was no reason to extend it during the 3rd gear passes due to the governor.
From 6300rpm to 7100rpm, it only drops by 4HP!
I still have mine. I just don't drive it anymore. I fired it up and drove it around the block the other day. "WOAH!" The way that VE is tuned, it's either on or off. spin the tires or nothing. with the stiff suspension and monster brakes on it, it's a bear to drive. forgot how much fun it was!
Very very nice, I love how the power stays up there after it peaks. Question, was your tuning device picking up any knock at all? Usually you stop advancing time when your power drops or when it starts to knock, so if you gained power/torque by retarding the timing that means you were very near or right on that limit where it should be knocking.
Aaron that is an awesome curve, kudoz!!!
