Dyno Discussion and SlipsDiscussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Figured I would dyno the DEK swap again to see what power its at.
SAE corrected
4th gear pull
DEK swap, OEM DEK cams
'95 fed spec ECU
SMT-6 tuning
Adjustable FPR - return style
OEM NGK platinum plugs index matched
OEM DEK white dot coil packs
Amsoil intake & HTPerformance MAF adaptor with Frankencar midpipe
70mm Pathy TB
Port matched 2K VI (switch over around 4800 rpm)
5th gen lower with no swirl valves
Blehmco grounding kit
OEM flywheel & crank pulley with all ancilleries hooked up
2001 AE clutch setup
Cattman headers with the y-pipe part header wrapped
Resontated 2.5" test pipe wrapped with header wrap
2.5" LSS mandrel bent catback with it's resonator wrapped with header wrap
2.5" Remus muffler section
Amsoil engine and gear oil
51 pound tire/wheel combo - 17 x 8 MOMO arrows with 235/45/17 Falkens
I'm waiting on those biki rom boards to come out so I can raise the rev limiter and re-tune with it. A 7200 rpm rev limit would help me alot.
The SMT-6 gets better results because it can advance timing as well as tune the A/F ratio. The EU is capable of doing the same and more.
For the future I may header wrap the secondaries and gasket match them, convert to a returnless fuel setup, and try those intake manifold spacers NWP is selling.
__________________
- Joe
1996 KH3 Maxima SE - 222 WHP / 208 WTQ SAE corrected @ 209,000 miles, VQ30DEK swap
(5 spd - project car, never ending money pit )
Very good numbers for the setup Joe, that's about what I had with my DE+00VI.
Definitely needs more revs, and I'd be interested to see where the peak is... a lot of DEK dynos tend to peak a little lower than DE+00VI from what I've seen, but of course as you know there's more to it than just the cam difference.
__________________
2000. 3L. 5-spd. Black on black. SE. (DD)
1998. 3L. 5-spd. Sterling Mist. SE. (fun car)
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
__________________
SHIFT_LOTS OF OIL
DCMAX current mods- 4th gen intake, 2.5" custom catback, NWP block off plate, 00SE tailight w/overlays, Rewired fog lights, Eyelid, JIC coilovers, FSTB, 3.0 OBX headers, SSIM...
95 White GXE- 15.1 sold... now 14.9 (car next to me in sig)
00 Sterling GXE- 15.0 (ebay intake, exhaust) my next love and beauty (crashed n sold)
02 Sterling GLE- 13.84@100 2.1'
Joe.....Amazing however I am not surprised that motor has always been strong, I will catch up with you next time your in the area maybe you can take me for a spin.
__________________
2003 Nissan Maxima SE - Majectic Blue 6MT HLSD Meridan Edition, Titanium Editon-Dynoed 206.61whp and 219.54wtq...Stock 17 Degree Timing Advance*Apexi/Berk Short Ram Intake*Cattspeed Y-pipe*Cattman 2.5 B-Pipe*HKS Sport Exhaust*Cattman Ti FSTB*Progress RSB*ES Poly Front Sway Bar Bushings*HKS Grounding kit*Axxtion STS
damn thats solid, lol @ those torks its pretty much a line not even a curve
It is funny the TQ on this car makes it feel slow. Since there is no sudden surge of power the car feels slow and smooth on highway pulls, then the speed gets into the triple digits pretty quick.
quick question??? you have a link for that cattspeed Y-pipe that is listed in your sig???
__________________
SHIFT_LOTS OF OIL
haha, thats what alot of people dont understand with the VQs i love it when people sit there and say 350Zs are slow and go on and on but its the power comes on soo smooth.
how easy is the SMT-6 to use and install, this is the first time im hearing about it, ur AFR is dead on through the whole powerband, it might be easier for people like me who dont want to go through the complications of the EU.
__________________ 96 Black I30t VLSD 5spd A.K.A Big Black(has a bad attitude) Eibach springs//Koni yellows//Koyo OE Radiator//F&RSTB//Black retro'd Cefiros w/E46 Bi-Xenon projectors/ZKW clear lense'd//Budget y-pipe//test pipe//Apexi WS2//WAI//Grounding kit
SMT-6 is only 7 wires and needs a RF filter on the crank signal line so it takes a bit of time to setup right. I got mine to work in '05 and Kevlo had one before the EU that I got to work for him. He sold his setup to Otransedental (sp?) and it didn't work for him. I told him how to set it up and he didn't want to do it that way then i never heard back from him, so
SMT-6 is limited in timing advance and it only works when the engine is not in closed loop. I only tune from 3500 rpm to redline and use the AFPR to tune fuel below that rpm range.
__________________
- Joe
man, if companies paid as much attention to the VQ30DE-k motor like they did the VQ35... beautiful numbers buddy, i just come in this thread to just look at the sheet just because lol
__________________
SHIFT_LOTS OF OIL
This engine never ceases to amaze me. Had a two day track event at New Jersey Motor Sports park in some pretty harsh conditions and the DEK held up nicely. The oil level didn't move at all and it felt good all thru the event. Now if I can get the rest of the damn car to hold up as well.
__________________
- Joe
taurus SHO, what? lol
__________________ 95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR 3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
Wow, those are impressive numbers. I've always been curious about removing my swirl valves, but have never had a good enough reason to do it. Were you pleased with the results?
__________________
-----5-speed DE-K with 205 whp and 199 wtq SAE corrected-----
-------Shortened Koni Yellows/Eibachs, Cobra/Q45/Hawk/SS-------
--SFC S.2, LTB S.2, RSB, FSTB, TB's (removed!), all ES bushings--
-------------Enkei RPM2/Michelin Pilot Sport A/S Plus-------------
