Dyno Discussion and SlipsDiscussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
__________________ TEAL 1997 Sentra GXE (the SE-L Imposter)...R.I.P. RED 1999 Sentra SE-L (the REAL SE-L)...3.5 inside GREEN 1996 Maxima GLE (the PIMP-mobile)...stock BLUE 1994 G20T (God I love this car for some reason) WHITE 1993 G20 (God I hate this car for some reason) BLACK 2004 Buell Blast 500cc (It's seen better days)
Mods: I/H/E(side exit), AEM standalone with Dyno Tuning. I'm considering some cams, although they are a lot of work and money, I'm also considering an aftermarket I.M., I can't recall which brand I was looking at.
I'd like to hit 300whp in N/A form.
do you need glasses??? i guess the black paint in the engine bay is throwin you off..
Quote:
Originally Posted by t6378tp
that engine bay is mad empty
__________________
2K2 SE 6 speed Grey Lustre SE Every option minus navi, black leather, HLSD, Hotshot headers, Cattman Catback, Frankencar WAI, HP autoworks STS, ES motor mount inserts, ES shifter bushings, FSTB, RSB. JIC FLA-1 coilovers, A34 Brakes Hawk HPS pads, TR Motorsports MT1's, Toyo 4s, 64,000 original owner miles.
no you need glasses
I do not see a battery, power steering, a/c lines or heater line. just look at the firewall see were 2 gromets are. what else no motor mount, no power or windshield wiper res, blah, blah, blah
__________________ My Cardomain _ _Maxima runs 13.4@109
Dyno:? whp & ? wtq
Nitrous PB: 13.4@110mph
All Motor PB: 14.0@99mph
3280lb with driver, full trim, rims, spare, jack, fluids, etc & notorized proof
Hehe, Oh no, that engine bay is Full...full of the one thing that matters
As far as the engine mount goes, I snapped that pic when the MM was getting remade. I snapped the old one the last time I dynoed.
Left one: Wimpy, Wimpy, Wimpy
Right one: Hefty, Hefty, Hefty
As far as times, nothing to brag about, I don't live near a track anymore, so I don't get many runs. The best times I can speak of are 13.3 @ 107, considering, this was one month after I finished the project. Since then, I've sorted out a lot of problems and tuned on the dyno. The car could undoubtedly get into the mid 12s with just a pair of slicks.
I've constantly been removing as much weight as possible from the car while still retaining the luxury of a full interior, probably sounds like an oxymoron, but there are no AC components, I can see straight through the air vents to the firewall, no power steering, no radio, no airbags, only 8 fuses and 8 relays in the entire car. The car was wired from head to toe, all sound insulation removed, no airbags, B13 steering wheel. The VQ35, itself is actually equivalent in weight to the SR20DET.
Seats out, I would be somewhere around 2200lbs w/o driver.
Nice numbers. I see you eliminated the power valve. Is the IM shelf also removed? Care to share your timing map?
Yea, the power valve is gone completely, I gutted it, minus the shaft. I don't know much about bringing up just the timing map. I don't want to upload the ECU settings, as I have quite a bit invested in the tune. Also, no guarantee it'll work on a different setup.
Quote:
Originally Posted by Kevlo911
How hard was the stand alone to wire in? How well does it work with the vtc's?
Standalone was very easy, it came pre-wired from a company called VQswap.com, they do pretty much everything you need to power it up and crank the starter. Although I could've probably wired it cleaner if I did the wiring myself. According to them, it does control the VTC, although I have no way of really knowing, once again, I don't know the software well enough.
