Go Back   Maxima Forums > Track and Tune > Dyno Discussion and Slips
Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-24-2009, 08:34 PM   #1
96sleeper's Avatar
Send a message via AIM to 96sleeper
Finally dynoed the car at higher boost, 431 hp/368 tq
I have been having some fuel system problems, so I wanted to dyno the car again and try to get the issues all sorted out. I think I figured out that the rising rate adjustable fpr is not rising anymore under boost so I will get that fixed. I was pretty rich in the middle and a little lean up top on this run.
I have seen over 12psi before from this pulley at the track, but today on the first two runs I was only getting a hair over 10 psi. For the last run I tightened the belt a little bit and saw 11 psi for this 3rd and final run.
Stock bottom end VQ35 with JDM knockoff cams and VQ30 timing equipment
V1 S-trim vortech with 2.70" pulley at 11psi for this dyno.
Intercooled, 3" charge piping, 3.5" CAI for S/C
Z32 MAF sensor, ported 70mm TB and hand ported IM
JWT ECU with S/C program and 100 octane timing map
deatschwerks 550cc injectors, walbro pump with boost-a-pump
adjustable fpr, SAFC for fine tuning
cattman headers
2.5" test pipe with electric cutout opened for dyno
2.5" exhaust with hooker muffler
fidanza flywheel/ACT XT pressure plate and street disc
__________________
96 Pebble Beige SE
14.2@97mph as an auto
13.7@102mph as a 5spd
12.9@106mph after 3.5 swap
11.6@120mph with the S/C
Cardomain link
Latest Dyno 431hp/368tq click here
CAR IS FOR SALE
96sleeper is offline   Reply With Quote
Old 01-24-2009, 09:01 PM   #2
nycnissans
secondtonone317's Avatar
Send a message via AIM to secondtonone317
Nice numbers..........
__________________
Co-Owner and Founder of NYCNissans.com
secondtonone317 is offline   Reply With Quote
Old 01-24-2009, 09:12 PM   #3
'Trynna' is not a word
mtrai760's Avatar
__________________
98 SE - VQ35
2k SE - Stock... pretty much
Boost, juice, conversions, been there, done that.
mtrai760 is offline   Reply With Quote
Old 01-24-2009, 10:52 PM   #4
Send a message via AIM to QNO_A32
amazing...mind posting some pics n stuff???
__________________
I LOVE WEED CREW MEMBER #1
QNO_A32 is offline   Reply With Quote
Old 01-24-2009, 11:05 PM   #5
wow! nice setup.
__________________
That's how I roll!
maxina97 is online now   Reply With Quote
Old 01-25-2009, 12:35 AM   #6
Beater
Tatanko's Avatar
Send a message via AIM to Tatanko
You need an emanage!
Great numbers nonetheless, though
__________________
SHIFT_obsession
Tatanko's Maxima Site & VQ35DE.com
Tatanko is offline   Reply With Quote
Old 01-25-2009, 01:15 AM   #7
UnPr3d!cT@bL3 M@X !!!
JonBlz's Avatar
Send a message via AIM to JonBlz
very nice numbers keep up the amazing work
__________________
Y0u kNoW Wh@T !t !$ !!!!! Money/Cash
^^R.I.P to my 99 maxima in Jan09
came back with an 02 maxima SE 6 spd nov 09
JonBlz is offline   Reply With Quote
Old 01-25-2009, 04:28 AM   #8
Send a message via Yahoo to po8pimp
any vids of the dyno?? Also being a 6th gen owner, was wondering what the perks are by using the VQ30 Timing equipment vice the VQ35 Timing equipment?
__________________
po8pimp is offline   Reply With Quote
Old 01-25-2009, 08:29 AM   #9
My axles cry for mercy...
essential1's Avatar
Nice numbers at 11lbs.
Quote:
Using the vq30 timing equipment is not for power reasons. 4th and 5th gen guys with the VQ30 originally need to do this so that our original ECU can be retained with the swap.
for us to use VQ35 timing...
Full Monty 3.5 swap progress
It would be a downgrade for you to "try" to use VQ30 timing.
__________________
01 I30, [5 speed swap][4th gen pedals and master cylinder][OEM clutch][OEM flywheel][ksport coilovers front, D2 coilovers rear][10k hid headlights and fogs][custom WAI][cattman exhaust][tenzo type-M, 19x8.5 +17F, 19x10 +22R][300zx calipers][Cobra 13" drilled and slotted rotors]
5 speed swap myths BUSTED:
1. Both driver and passenger side AUTO axles work fine.
2. AUTO flywheel bolts work fine.
essential1 is offline   Reply With Quote
Old 01-25-2009, 07:45 PM   #10
SC Overspinning Swapper!!
Very nice number....and very comparable to mine.
__________________
Built/swapped VQ35, 6-speed HLSD, SC boosted....and daily driven
443whp/378wtq
meximax is offline   Reply With Quote
Old 01-26-2009, 02:36 AM   #11
VQ35 FTW
mastercater7's Avatar
Quote:
I am right there with ya'll and once I put my new gates belt on I will redyno, hopefully this week. Great numbers man! Were you running 100 octane fuel for this dyno pull?
Zack
mastercater7 is offline   Reply With Quote
Old 01-26-2009, 05:10 AM   #12
96sleeper's Avatar
Quote:
Zack
No, 93 octane. I had JWT program my ecu for 100 octane because their normal boosted program is very weak on timing and doesn't make good power.
__________________
96 Pebble Beige SE
Cardomain link
CAR IS FOR SALE
Old 01-26-2009, 08:45 AM   #13
You can't friend yourself
Kevlo911's Avatar
Any dyno with the cutout closed?
__________________
97 Pearl White Max GLE
I has car
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 01-26-2009, 09:07 AM   #14
96sleeper's Avatar
Quote:
I did that last time when I was on 6 lbs of boost and dynoed 366hp. I think it was around 20hp then off the top of my head. I was trying to get the fuel sorted out this time and didn't want to change any other variables.
__________________
96 Pebble Beige SE
Cardomain link
CAR IS FOR SALE
Old 01-26-2009, 10:09 AM   #15
3.5 in the works
DandyMax's Avatar
Send a message via AIM to DandyMax Send a message via MSN to DandyMax
Nice numbers Matt. I forget, are you running an SSIM or Z33 mani?
__________________
2000. 3L. 5-spd. Black on black. SE. (DD)
1998. 3L. 5-spd. Sterling Mist. SE. (fun car)
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
DandyMax is offline   Reply With Quote
Old 01-26-2009, 12:07 PM   #16
96sleeper's Avatar
Quote:
It is similar to a SSIM A33 manifold.
__________________
96 Pebble Beige SE
Cardomain link
CAR IS FOR SALE
Old 01-26-2009, 01:11 PM   #17
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
Vey nice numbers. Was your 11.6 at 12lb's of boost?
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 15.508@90mph 60' 2.3 AUTO (Bad KS and stock catback) 210whp, 213wtq
The Dark Phoenix 13.402@102mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is online now   Reply With Quote
Old 01-26-2009, 01:51 PM   #18
96sleeper's Avatar
Quote:
It was the same pulley and same setup, but I am not sure how much actual boost I saw on the run. It might have been less because I only trapped 120mph on the 11.6 pass, and previously had been almost 122mph.
__________________
96 Pebble Beige SE
Cardomain link
CAR IS FOR SALE
Old 01-26-2009, 05:50 PM   #19
Quote:
Spray it and get into the 10's!
Idk though... your pretty much at the limit for a stock bottom end vq35de.
Do you think you can get any faster by building the bottom? Or will it just blow by all the gears after 500hp?
VQrebuild96 is offline   Reply With Quote
Old 01-26-2009, 06:12 PM   #20
96sleeper's Avatar
500hp in a fwd would be useless. I already have to stay on drag radials full time just to hook in 2nd gear (sometimes). 1st gear is useless except on slicks.
I can run faster than my 11.6 if I launch it hard like I used to when I was n/a, I just haven't been able to yet. It might not even hook with a hard launch. I have already reached the point where adding more power won't help anything. It has a few more tenths in it now.
__________________
96 Pebble Beige SE
Cardomain link
CAR IS FOR SALE
Old 01-26-2009, 08:12 PM   #21
very nice numbers.
__________________
12.1 @ 119.77: semi bald all season tires.
DonSupreme is offline   Reply With Quote
Old 01-30-2009, 11:58 PM   #22
Send a message via AIM to AsthmaMax11
awesome #'s matt. You must really love that car to have taken it this far. When are you going to the track next?
__________________
98 Maxima 5-speed boltons - SOLD
best ET: 14.5
best 60': 2.27
best trap: 98.98 mph
AsthmaMax11 is offline   Reply With Quote
Old 01-31-2009, 07:01 AM   #23
96sleeper's Avatar
Quote:
I have enjoyed the car, but I can feel the end drawing near. I will probably try to go to the track one more time this spring and give it one more chance.
__________________
96 Pebble Beige SE
Cardomain link
CAR IS FOR SALE
Old 01-31-2009, 08:55 PM   #24
I'm hoping to get 4:10's and drag radials in the next few months so I might actually give you a good race this time. Just got a cam and tune so I am in need of some good races.
__________________
best ET: 14.5
best 60': 2.27
Old 02-01-2009, 11:35 AM   #25
ZHP
4DRSpeed's Avatar
Send a message via AIM to 4DRSpeed
Good god!!
__________________
'96 Nissan Maxima SE 5-SPD - Ruby Pearl/BLK Leather
4DRSpeed.com - It's coming!
4DRSpeed is offline   Reply With Quote
Old 02-01-2009, 12:18 PM   #26
Gut it like a fish
accordingtou's Avatar
Im impressed... As always.
__________________
Stock & performance parts F/S@ PANTRY sale.lol Philly Pa
accordingtou is offline   Reply With Quote
Old 02-03-2009, 11:48 AM   #27
Send a message via AIM to G4nismo
very nice numbers! good job
__________________
03 Z33 Brickyard touring coupe 6spd
97 Maxima - Sold
Quote:
Originally Posted by 35oZephyR View Post
My350z = General Car Enthusiast Forum (sprinkled in with a little Z douchebaggery)
G4nismo is offline   Reply With Quote
Old 02-03-2009, 12:02 PM   #28
All I have to say is niceeeeeeeeeeeee...
__________________
2theMaX05 is offline   Reply With Quote
Old 02-09-2009, 05:50 PM   #29
since you already dumped that much money in the car... just asking:
Would you be able to shave some time off the 1/4 mile if you were to get a quaife HLSD? Obviously i'm kind of a noob still, but wouldn't that help to put the power to the ground. From your mod list I couldn't see whether or not you had the AE tranny in it. Quaife probably isn't substantially better than the AE LSD.
__________________
MODS:
Illuminas + Eibach | Stillen FSTB | Progress Rear Swaybar | 10mm Front/ 25mm Rear Eibach Spacers | Unorthodox UDP | Stillen Y-Pipe | HKS Rear Section | InJen WAI | Shinjinduo Grounding Kit | 300ZX BBK | Ionic Dynamics Bodykit | Ebay Projectors | Foglight HIDs |License Plate LEDs | Blacked out grills | Pioneer Avic-D3 | Interior LEDs
McSteve is offline   Reply With Quote
Old 02-09-2009, 05:56 PM   #30
96sleeper's Avatar
I don't have the AE tranny, but I do have the factory VLSD unit. It works fine. I bet I would not be able to tell any difference with a quaife. I can already leave two black strips anytime I want to, and when I am on the slicks it hooks ok. Weight transfer is the biggest enemy of a fwd at the dragstrip and there is only so much you can do. I can shave some more off my time in the 1/4 mile from the launch though. I should be able to get back in the 1.7x 60ft range if I decide to launch it hard like I used to when I was n/a.
__________________
96 Pebble Beige SE
Cardomain link
CAR IS FOR SALE
Old 02-11-2009, 01:12 PM   #31
nice numbers u should try 3'' all the wayback see if that helps
99MAXPIMP is offline   Reply With Quote
Old 02-15-2009, 11:08 PM   #32
Send a message via AIM to 95BLKMAX
Quote:
doesnt need it. he has a cutout and it was open for this dyno
__________________
Guys I need money to recover from my recent engine build (it wasnt by choice LOL). Im selling a Holset turbo if you are interested
95BLKMAX is offline   Reply With Quote
Old 02-26-2009, 10:59 AM   #33
Send a message via ICQ to maxima92se Send a message via AIM to maxima92se
OMG gives the impression that the 3.5 is a beast vs the 3.0... Good numbers none the less.
__________________
98 Nissan Maxima..
Mods..
Supercharged, FMIC, K&N CAI, 00VI, VAFCII, Short Ram intake, Budget Y, warpspeed high flow cat, Greddy SP2 Catback, dropped!!
Zeitronix wideband and datalogging laptop just for tuning
18x8 G35 rims wrapped in Dunlop W10 235/40/18 tires.
Z32 4piston calipers, Cobra Xdrilled/Slotted.
14lbs Super Charged Sleeper@332fwhp
SOON: RC440cc injectors, Transmission, clutch and headers!!
maxima92se is offline   Reply With Quote
Old 02-26-2009, 04:07 PM   #34
Impressive! How many miles do you get out of a clutch?
acecars is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
