Dyno Discussion and SlipsDiscussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
I was expecting some better numbers. The AFR was between 11.8 to 12.2 across the range although I had it street tuned to 12.9-13.1 doing second gear pulls. The one thing I noticed when I got home was that it wasnt dynoed to the 7200rpm rev cut. Mods are in sig.
__________________
Mods:| Cammed VQ35 | SSIM | HR springs | ARP rod bolts | OEM Nissan rwd head-gaskets | Budget Y-pipe and Catback | NWP Spacers | Dynomax Superturbo muffler | EdgeRacing Converter | Transgo Reprogramming Kit | Hayden Transmission Cooler | JWT Pop Charger | Emanage Ultimate | SSV4 | Innovate LC-1 WB | DR mod | ES motor mounts | ES x-member bushings | ES LCA bushings | Polyfilled tranny mount| 15" RX-7 BBS wheels (12lbs/rim) | Street tuned: 13.0 AFR, 7200 Rev limit, advanced timing |
Yes, 3.0 exhaust manifolds.
There was no time to do any tuning today. They just had enough time to do a couple of pulls and see where things were at. Hopefully over the course of the next few weeks I can figure out what's going on.
__________________
__________________
SHIFT_LOTS OF OIL
DCMAX current mods- 4th gen intake, 2.5" custom catback, NWP block off plate, 00SE tailight w/overlays, Rewired fog lights, Eyelid, JIC coilovers, FSTB, 3.0 OBX headers, SSIM...
95 White GXE- 15.1 sold... now 14.9 (car next to me in sig)
00 Sterling GXE- 15.0 (ebay intake, exhaust) my next love and beauty (crashed n sold)
02 Sterling GLE- 13.84@100 2.1'
I'm actually thinking about taking it somewhere else to have it dynoed again. Even though its an auto, I still think I should have seen some better numbers. I dont think the AFR being in the 11.8 and low 12s would make that big of an impact.
I think the track closest to me is closed for the season. Or so I was told by one of the operators so that will have to wait till next season.
__________________
It was street tuned in 2nd gear and the AFR was close to 13 flat. When I dynoed it today, 3rd gear, the AFR was down in the 11s and low 12s. We used my wideband so that there would be some sort of consistency. I data logged the runs with the EU and everything else seemed fine.
__________________
the widebands were not calibrated. Either yours or the dyno's. I would recalibrate your WB and do a run just to make sure it wasnt yours. If that's the case then use another dyno.
Another things, when you tune in one gear (2nd in your case) you most tune in a way that for 3rd gear (your real dyno gear) its going to LEAN by about .3-.4 because of the added airflow with the longer gears. In your case, on the dyno, this did the exact opposite, pointing the finger towards the dyno's WB.
Either case, on a dyno, WB readout has no effect on how the power to the ground is calculated. I would go to another dyno just to verify this against this dyno. If the new dyno is within close approximation to this one, then there's something going on with your engine. Also, was the TC locked for these pulls?
__________________
Guys I need money to recover from my recent engine build (it wasnt by choice LOL). Im selling a Holset turbo if you are interested
We never used the dyno's WB. My WB was used. Also the car was dynoed in D with OD off. I was under the assumption that the TC doesnt lock up with OD off.
__________________
I rechecked the AFR today doing some 2nd gear pulls, and they're where I had them. 13 flat. The curve is nice and straight from 3500rpm right to 7200 with the exception of the spot where the stock fuel cut is where it momentarily dips into low 12s.
I have a dyno appointment at a different location booked for next week but in the mean time I would like to get some suggestions as to where I should look in the event that the second dyno confirms the low numbers. Where would you guys look for problems in the motor?
The setup:
02 vq35de
Nismo knock off cams
converted TB
SSIM with port matched LIM
4th gen IACV
oil catch can between pcv and UIM
breather on front valve cover
I installed the NWP spacers myself and now I'm second guessing if I put too much RTV on the spacers and maybe they're blocking the air path. Could something like that cause such significant losses?
__________________
the TC does lock up with OD off. always dyno like that with OD off. i have verified this myself with my manual lock up switch, dynoed with TC unlocked, put down like 240whp, dynoed with TC in stock setting with OD off, dynoed 312whp. so yea it does lock up.
oh snap all this time i thought it was a VQ30 with VQ35 cams... oops my bad, yeah something's off
__________________
SHIFT_LOTS OF OIL
Ok guys, when I was looking at the EU data log stuff, I noticed that I did a 50-100mph pull in 7.88 seconds in 2nd gear on the street. I compared this to several other 2nd gear pulls that I had saved and that number is consistent. Does that seem decently quick or is that average?
Also, I noticed that in the higher rpm, ignition timing is between 36-39 degrees. I was told it should be in the mid to low 30s.
__________________
general consensus is that any ign timing advance after 35* is a waste and will not yield any more power. Some have said that the threshold is even lower than that.
__________________
Give me a call Will when you get a chance, we can discuss... there is some misinformation in this thread.
Did you do a map trace to see which cells your dyno run tracked through on the I/J map? Are they the same as where it tracks through the 2nd gear pull (shouldn't be much different but I'm not sure how you changed the map doing your last tuning runs). Running high 11 AFR will lose some power but you should still have more than what you got with those mods. The ignition timing, where are you reading the 36-39 degrees... at what rpm? Also, is that an averaged number on the EU or a peak number you're seeing? 36 degrees up past 7000 rpm is no concern, but did you play with timing on the dyno at all to see where the optimal setting is? The numbers in that initial map were based on a different car (although still a 4th gen), so you may need to tweak a degree or two.
Are you sure you aren't having a KS problem again to cause a power loss? Also, check compression or better yet do a leakdown test.
__________________
2000. 3L. 5-spd. Black on black. SE. (DD)
1998. 3L. 5-spd. Sterling Mist. SE. (fun car)
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
