Go Back   Maxima Forums > Track and Tune > Dyno Discussion and Slips
Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-09-2008, 04:08 PM   #1
3.5 in the works
DandyMax's Avatar
Send a message via AIM to DandyMax Send a message via MSN to DandyMax
Dyno - cammed DEK!! ruh roh
*Warning* - long post... oh, and some 3.5 swappers may flip out after reading this... J/K
So I got on the dyno this morning to finish up my tuning on the cammed DEK, seeing as I'm heading to the track tomorrow for one last hurrah with the 3L to hopefully beat my PB with it before putting the 3.5 in. So obviously I wanted it running and tuned up in top notch shape for tomorrow.
Anyways, I started off with just a straight baseline pull to see where it was at, and it put down about 246 whp. But viewing the loggers I could see it needed some tuning, so after 10-12 pulls and a bunch of playing with fuel and ignition timing I had it running up around 263 whp. Once I optimized it at that level then it was time to open the cutout and make some noise! I did so and after a little more tweaking I just about hit 270 whp at 7500 rpm, actually it came out as 269.87.
So it goes without saying I'm happy with that. Interestingly enough, the modeling I'd done before building the engine predicted around 275 whp at 7700 rpm, and I was skeptical at the time that it was accurate (never fully trust software lol), but hey the program was just about bang on. It does require meticulously measuring and inputing data to get that close though.
So below I've posted 2 graphs, the first one is the best run from today, and the second is just a fun comparison with my 220whp run from 2005 (with stock DE cams and 00VI). The cams have obviously shifted the power band as one would expect, although I have changed more than just cams between the 2005 dyno to now.
You'll notice the dip in the first graph at 6500 rpms, that spans approximately 200 rpms - that unfortunately is unavoidable and is due to the EU adding fuel to get past the stock limiter. There is a momentary rich spike that drops out the power for a split second, but keep in mind that 200 rpms goes by VERY quickly, especially in the lower gears and is almost unnoticeable in the car. It looks big and ugly on the DJ graph, but in reality affects the performance of the car barely at all. I can positively say that the car pulls pretty smoothly through that area, even in 3rd and 4th gear, despite how it looks.
A couple more thoughts: calculating out the crank horsepower gives me somewhere in the 315 range, meaning this engine is doing easily 100 hp per litre. Woot! Also, you can see that it really would have liked to rev to 8000-8200 rpm, if the oil pump/bottom end would have allowed... peak would have been around 7700 or so I believe, probably 273, 274 whp, or something like that. But I am not taking it higher than 7500/7600 now, don't want to blow another pump.
Oh, guess I should post the engine mod list applicable to today's dyno as well:
VQ30DE-K Swap
VQ35 Oil pump w/ low pressure cut off switch
VQ35 JDM cams (similar specs to JWT S1)
VQ35HR valve springs and retainers, double shimmed
Mild head "work" (NOT ported though)
Unorthodox flywheel
Exedy Stage 1 clutch
Greddy EManage Ultimate
Pathfinder TB
Stock DEK crank pulley
Custom intake w/ MAF delete
Cattman headers/y-pipe/catback (plus cutout)
Low temp T-stat
Walbro fuel pump
Returnless fuel rail w/ adjustable FPR
First graph: Best run
Second graph: Comparison 2008 to 2005
__________________
2000. 3L. 5-spd. Black on black. SE. (DD)
1998. 3L. 5-spd. Sterling Mist. SE. (fun car)
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
DandyMax is offline   Reply With Quote
Old 05-09-2008, 04:13 PM   #2
'Trynna' is not a word
mtrai760's Avatar
Mad props.
__________________
98 SE - VQ35
2k SE - Stock... pretty much
Boost, juice, conversions, been there, done that.
mtrai760 is offline   Reply With Quote
Old 05-09-2008, 04:17 PM   #3
Beater
Tatanko's Avatar
Send a message via AIM to Tatanko
Holy sh*t. 270 WHP and you could have gone farther? My god man
__________________
SHIFT_obsession
Tatanko's Maxima Site & VQ35DE.com
Tatanko is offline   Reply With Quote
Old 05-09-2008, 04:35 PM   #4
Holy crap. You haven't gutted the 00vi, either? Define "custom intake"
I am anticipating moar greatness from the 3.5. 320 maybe?
MorpheusZero is offline   Reply With Quote
Old 05-09-2008, 05:02 PM   #5
Shift_Broken Tranny
Holy sh!t batman he's pushing more than some of the boosted guys
I smell a bidding war when this engine goes up for sell
__________________
My Cardomain _ _Maxima runs 13.4@109
Dyno:? whp & ? wtq
Nitrous PB: 13.4@110mph
All Motor PB: 14.0@99mph
3280lb with driver, full trim, rims, spare, jack, fluids, etc & notorized proof
t6378tp is offline   Reply With Quote
Old 05-09-2008, 05:18 PM   #6
Send a message via AIM to speed racer
Those are some real nice number. When you tuned it did you also play with the fuel injectors.
speed racer is offline   Reply With Quote
Old 05-09-2008, 05:25 PM   #7
3.5 in the works
DandyMax's Avatar
Quote:
No it's not gutted. Ported for PF TB, and power valve removed, that's it. The "custom intake" refers to everything before the TB.
Quote:
It's already sold...
Quote:
Play with the fuel injectors? Not sure what you mean.. they're just stock DEK injectors...
__________________
Best 60': 1.73
Old 05-09-2008, 05:47 PM   #8
Quote:
Power valve removed = close to gutted, that's all I needed to know.
If you massage them they will relax a little which will improve flow.
Old 05-09-2008, 06:11 PM   #9
sparks03max's Avatar
wow great numbers, this REALLY makes me want to put some ebay S1 knockoffs in my 3.5 and rev it up a little higher.
__________________
2003 SE 6MT Titanium Edition - Sterling Mist
Power mods: SRI, VIAS Delete, NWP spacers, Cattman Headers, Custom exhaust, TurboXS UTEC + Tuner
12-second 5.5 gen track vid: http://www.youtube.com/watch?v=HDz_fIHZgig
sparks03max is offline   Reply With Quote
Old 05-09-2008, 06:28 PM   #10
Super Moderator
Send a message via AIM to nismology
The 00VI might just be the best IM nissan has ever made. Amazing results!
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline   Reply With Quote
Old 05-09-2008, 08:39 PM   #11
Former Vendor
Send a message via AIM to BLACKonBLACK98
man thats awesome. i'm not a huge performance guy but i do plan on doing a nice all-motor build in the future. might wanna block me from your aim ahead of time.
BLACKonBLACK98 is offline   Reply With Quote
Old 05-09-2008, 08:42 PM   #12
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
All I can say is wow!
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 15.508@90mph 60' 2.3 AUTO (Bad KS and stock catback) 210whp, 213wtq
The Dark Phoenix 13.402@102mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is offline   Reply With Quote
Old 05-09-2008, 11:38 PM   #13
Send a message via AIM to 98SEBlackMax
Nice numbers!!! and I don't say that often.
It's near what I want to make in power on a 3.0. Gives me some more motivation for my own build. With the right combination these 3.0s don't have a problem with making power up top, just a problem staying together.
__________________
- Joe
1996 KH3 Maxima SE - 222 WHP / 208 WTQ SAE corrected @ 209,000 miles, VQ30DEK swap
(5 spd - project car, never ending money pit )
2007 KH3 Frontier NISMO 4x4 - ??? WHP / ??? WTQ
(6 spd - daily driver)
98SEBlackMax is offline   Reply With Quote
Old 05-10-2008, 12:32 AM   #14
faster than you think
tedo007's Avatar
Send a message via AIM to tedo007
simply amazing
__________________
Mods: OBXv2 Headers, OBX Cold Air Intake w/K&N Filter, 17 Degree Advanced, 10000K Headlight, 10000k Fog Light, Fog Re-Wire, FSTB
1/8: 2.19 60ft 9.3279 @77.34 mph
tedo007 is offline   Reply With Quote
Old 05-10-2008, 05:23 AM   #15
KRRZ350's Avatar
Send a message via AIM to KRRZ350
KRRZ350 is offline   Reply With Quote
Old 05-10-2008, 07:10 AM   #16
96sleeper's Avatar
Send a message via AIM to 96sleeper
Awesome numbers. It ought to fly at the track on slicks with a great launch.
__________________
96 Pebble Beige SE
14.2@97mph as an auto
13.7@102mph as a 5spd
12.9@106mph after 3.5 swap
11.6@120mph with the S/C
Cardomain link
Latest Dyno 431hp/368tq click here
CAR IS FOR SALE
96sleeper is offline   Reply With Quote
Old 05-10-2008, 07:26 AM   #17
maybe its time for me to build my dek just laying in my pole barn collecting dust .
but freaking sweat man now we have to see what kinda times you will pull
__________________
97 Maxima GXE Totalled
96 Maxima Se Blown 3.5 New one coming
90 B12 Sentra My new winter beater
Product_Of_Korea is offline   Reply With Quote
Old 05-10-2008, 08:06 AM   #18
You can't friend yourself
Kevlo911's Avatar
What are the benefits of a returnless style setup on a 30? Mad props man, I wish I could crack the 220 mark and I would be happy lol
__________________
97 Pearl White Max GLE
I has car
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Kevlo911 is offline   Reply With Quote
Old 05-10-2008, 09:34 AM   #19
Send a message via AIM to codyace
Quote:
Something about revving my car high, and ebay cams, doesn't go together....
Congrats to the o/p
__________________
Cody Ace -- 'Engine Response > Peak Power'
1997 240sx - SR20DET - GT2871r .64 Power - 400whp/330ft lbs
1996 Maxima SE - Fully Loaded, Stock as it comes
codyace is offline   Reply With Quote
Old 05-10-2008, 11:32 AM   #20
Beater
Tatanko's Avatar
Quote:
Congrats to the o/p
The knockoff cams are by no means "low quality." They have used by plenty of people.
__________________
SHIFT_obsession
Old 05-10-2008, 12:53 PM   #21
Quote:
Lower fuel temp?
Old 05-10-2008, 11:08 PM   #22
3.5 in the works
DandyMax's Avatar
There is definitely more power available in the engine if one were to get the heads ported and do up the bottom end to rev mid 8000's, bump compression etc. But I wasn't prepared to invest that much in it. I'm focused on my 3.5 now.
Lower fuel temp?
Yes, significantly. And as a bonus, simpler plumbing with the engine swap etc...
To me that's not gutted at all... lots of material left inside there still if one wanted to truly gut it.
Tried that, all I got was a couple of blisters for my trouble.
__________________
Best 60': 1.73
Old 05-10-2008, 11:18 PM   #23
Gut it like a fish
accordingtou's Avatar
Hope for the 3.0
Great #'s
Are the hr springs & shims you used Stronger or cheaper than the JWT set?
im planning to rev up to 7500 with jwt springs in my 3.5, what do you think?
__________________
Stock & performance parts F/S@ PANTRY sale.lol Philly Pa
accordingtou is online now   Reply With Quote
Old 05-11-2008, 12:02 AM   #24
I want to hear it at eight grand.
In fact, I want to hear it at mid 7s... where are your sound clips dammit
Alright, but removing the power valve >> regular 00vi for top-end, we can agree on that...
You are not using the proper swedish injector massage oil I also heard sweet talking them one at a time before a run can help
Old 05-11-2008, 01:55 AM   #25
Bear > Wookie
DrunkieTheBear's Avatar
Send a message via AIM to DrunkieTheBear
HEHE, My car is being built exactly like dandy's except I'll be adding a few other things here and there. Could I be the first VQ to break the 300whp mark Its not gonna happen I know.........
__________________
2004 Pontiac Grand Prix GTP Comp G
|3.5" Intake Bpi/R2C|Ram Air|3.4" Pulley|180* T-stat|Headers|Corvette Brakes|SSC Lowering|KYB|LEDs everywhere|GXP parts|SE Parts|
Want a Plug and Play Harness for your Emanage Ult/Blue? CLICK HERE!
Quote:
Originally Posted by MOHFpro90 View Post
Thank you Dave. I love you Dave.
Quote:
Originally Posted by bigleman View Post
...so i had to get towed out of a ditch last night...
DrunkieTheBear is offline   Reply With Quote
Old 05-11-2008, 02:59 AM   #26
Good luck getting another 30whp over dandy with "a few other things" if you pull 100whp/liter off I will be very impressed to say the least, especially on an auto
(I assume you're going to swap to a manual before you do build the motor...)
Old 05-11-2008, 08:09 AM   #27
Bear > Wookie
a man can dream....
__________________
Old 05-11-2008, 10:04 AM   #28
3.5 in the works
DandyMax's Avatar
Quote:
Originally Posted by accordingtou View Post
Great #'s
Which cams (ie how much lift?). Check out this graph. It tells the story. The HR springs + shim set are slightly cheaper than JWT from DaveB IIRC.
I may yet make another video or 2 before pulling the engine out of the car. In the interim I'm working on videos from the track yesterday.
Yes. That's part of the reason my 2005-2008 comparison shows a loss before 5000 rpm. And the cams play into it a bit too, especially lower down.
The 100 hp/L mark is based on estimated crank numbers, tranny shouldn't matter if you use the appropriate loss percentage when back-calculating the crank # from the whp number.
__________________
Best 60': 1.73
Old 05-11-2008, 10:34 AM   #29
brotherhood of tq
liqidvenom's Avatar
Send a message via AIM to liqidvenom
i must say this is a very very nice setup. EU is doing alot for us in regards to tuning.
__________________
Slow car on 18's
liqidvenom is offline   Reply With Quote
Old 05-11-2008, 11:01 AM   #30
Toolie
knight_yyz's Avatar
Great numbers Dan! did you beat your record at the track?
__________________
6MT | 06HLSD | I/H/E & FC | Stillen FSTB & RSB | Eibach Pro Kit | Illuminas | Watkins STS | UDP | NWP Spacers | Greddy Blue | ES Bushings
253.50 fwhp
249.75 lb/ft tq
14.3 @ 101mph (street tires, bad wheel bearing and a few spun tranny bearings)
knight_yyz is offline   Reply With Quote
Old 05-11-2008, 11:18 AM   #31
Send a message via AIM to i30dvr
not to flame the thread or anything cause DANDYMAX is the Motherfu....man but where is the "power valve" in the OOVI. Obviously dandy ur not going to tell us all ur secrets but i'm trying to hit 200whp in my dek swapped auto. I hit 180whp now...i have a vafc...what do you recommend to best get me to my goal and beyond?
__________________
DEK INSIDE......
5speed swap'd
Budget Y-pipe
DMH e-cutout
30% all the way around
Ksport 36-way coilovers
VAFC II
AEM Uego Wideband
6000k HID
Coming soon --??hmm--
i30dvr is offline   Reply With Quote
Old 05-11-2008, 11:53 AM   #32
RIP Kevin007
ajcool2's Avatar
Quote:
ibsomebodysaysswapina5speed
__________________
DCMAX FTW
Fear me.
Old 05-11-2008, 12:13 PM   #33
ahah yea man...i wish i could do that...but idk like i've paid for everything that i've done to my car and my parents said the car is devalued which it is because of the dek swap but because i don't plan on selling anytime soon i don't understand what there hesitation is on me swapping to a manual. But they did say i could do the 3.5 which makes no sense and seeing the power that dandy made out of the 3.0 makes me just wanna keep this to see how much more i can extract.
__________________
DEK INSIDE......
5speed swap'd
Budget Y-pipe
DMH e-cutout
VAFC II
AEM Uego Wideband
6000k HID
Old 05-11-2008, 12:45 PM   #34
UnPr3d!cT@bL3 M@X !!!
JonBlz's Avatar
Send a message via AIM to JonBlz
Wow that's crazy 3.0 for life LOL
__________________
Y0u kNoW Wh@T !t !$ !!!!! Money/Cash
^^R.I.P to my 99 maxima in Jan09
came back with an 02 maxima SE 6 spd nov 09
JonBlz is offline   Reply With Quote
Old 05-11-2008, 01:06 PM   #35
100whp/liter > 100bhp/liter
Old 05-11-2008, 01:24 PM   #36
3.5 in the works
DandyMax's Avatar
Um yeah, just go ahead and ignore my last comment, must have had some kind of brain fart. When I go back and re-read your/his posts now it all makes sense. Carry on..
__________________
Best 60': 1.73
Old 05-11-2008, 01:28 PM   #37
Hah ok ignore my last comment, I went back and re-read your/his posts... I mis-read the first time. Carry on..
dandy- any opinions to my above post? if you want we can talk through pm
__________________
DEK INSIDE......
5speed swap'd
Budget Y-pipe
DMH e-cutout
VAFC II
AEM Uego Wideband
6000k HID
Old 05-11-2008, 01:31 PM   #38
3.5 in the works
DandyMax's Avatar
Yes PM me please so we don't clutter the thread...
__________________
Best 60': 1.73
Old 05-11-2008, 01:36 PM   #39
Koni Kroo
95maxrider's Avatar
Send a message via AIM to 95maxrider
Screw a 3.5, you've already got the DE-K in the car. Don't listen to your parents. If you're paying for it, it shouldn't matter what they say unless you plan on selling your car sometime soon. Just run the DE-K into the the ground like me and be happy
5 speed swap+EU=220 whp
__________________
-----5-speed DE-K with 205 whp and 199 wtq SAE corrected-----
-------Shortened Koni Yellows/Eibachs, Cobra/Q45/Hawk/SS-------
--SFC S.2, LTB S.2, RSB, FSTB, TB's (removed!), all ES bushings--
-------------Enkei RPM2/Michelin Pilot Sport A/S Plus-------------
95maxrider is offline   Reply With Quote
Old 05-11-2008, 03:11 PM   #40
Bear > Wookie
Well I start my project soon, I am buying my engine this month and start work on it. It should be done in December and I will post numbers then.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
