Go Back   Maxima Forums > Track and Tune > Dyno Discussion and Slips
Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Thread Tools Display Modes
Old 04-27-2008, 10:31 PM   #1
Do lighter rims = more whp on a dyno?
Do lighter rims make a car show more whp on a dyno? Reason I ask is cuz (theoretically) with the lighter weight rims, the drive shafts will spin them faster, which leads to the dyno interpreting it as more power, right?
FWIW I'm reducing from 23 lbs to 18.5 lb rims.
__________________
2001 Mitsubishi Eclipse GT
2003 Mitsubishi Galant ES - my college beater
COMING IN '09...
Nissan Altima Coupe SE or I35/3.5L Maxima
1997 Nissan Maxima SE
RIP 12.23.04
ChuckDaMaxRider is offline   Reply With Quote
Old 04-27-2008, 10:38 PM   #2
i would think that it would. Although its only a few pounds difference it IS rotational mass that you are reducing. I reduced my wheels/tire combo from 41 to 35 pounds! Your tire weight is also very important for the weight on the outer edge makes more of a difference.
__________________
"Friends don't let friends, drive stock "
RacerX1320 is offline   Reply With Quote
Old 04-28-2008, 07:09 AM   #3
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
I went from a 51.5lb wheel / tire combo to a 37.5 lb combo and did see a difference. Although it was not a direct comparison, it was impressive.
So Also pay attention to alignment.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 04-30-2008, 10:27 PM   #4
Thats why they call it Wheel Horse Power
Different size and weight wheel and tire combo will effect the ability to put down power.
irax is offline   Reply With Quote
Old 04-30-2008, 11:39 PM   #5
"Titanium"
sparks03max's Avatar
What wheel/tire combo are you using now? I'm getting rid of these g35 wheels. Ride and handling went out the window compared to the stockers.
__________________
2003 SE 6MT Titanium Edition - Sterling Mist
Direct port turbo injection with 2 naws foggers, the big ones!
sparks03max is offline   Reply With Quote
Old 05-01-2008, 07:12 AM   #6
Certified Hooptie
NmexMAX's Avatar
Quote:
Motegi Traklites
__________________
Old 05-01-2008, 09:42 AM   #7
Send a message via AIM to !PrjctMax!
track wheels=show?
__________________
Lots of performance parts for sale
http://forums.maxima.org/6th-generat...-out-sale.html
OEM shocks, coil-packs, mud-flap, LIM
!PrjctMax! is offline   Reply With Quote
Old 05-01-2008, 10:02 AM   #8
Certified Hooptie
NmexMAX's Avatar
Quote:
Originally Posted by !PrjctMax! View Post
track wheels=show?
I have MMEV5's, which are known to be heavy, those used to be my 'show' wheels. Now, I have the tracks, which are light show wheels.
Anyone who is serious about lightweight wheels know that 17" is the way to go.
__________________
Old 05-01-2008, 12:50 PM   #9
STFU n00b!
Remember that on a dyno you're spinning up a 3000lb roller as well. a couple lb of change on the wheel weights is going to make very little, if any, measurable difference.
you'll see it more on the track in your first couple gears than you ever will on a dyno.
__________________
93 SE 5 spd- Only thing still stock is the carpet.
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 05-01-2008, 01:20 PM   #10
Use the Search Function!!
mtrai760's Avatar
Send a message via AIM to mtrai760
Quote:
Umm, No. They call it Wheel Horsepower because it is measured at the wheels, and therefore subject to drivetrain loss, VS. being measured at the crank, like auto manufactures do to post the cars HP.
__________________
98 SE - Supercharged at 10psi w/the works - VQ35 coming soon...
2k SE - Stock... pretty much
88 RX-7 - Sold
95 240sx KA-T 10psi - sold
3 4th gens.... gone....
mtrai760 is offline   Reply With Quote
Old 05-01-2008, 08:19 PM   #11
505max94se's Avatar
Quote:
Wouldn't the weight of the 3000lb roller be factored into the dyno's power measuring process?
More like the last couple of gears. Heavy wheels will make more of a negative impact to the vehicle's acceleration from higher speeds than they will from lower speeds.
__________________
My CarDomain Page
505max94se is offline   Reply With Quote
Old 05-01-2008, 09:46 PM   #12
Quote:
Wrong.
Wheel moment of inertia will have an identical effect on acceleration as the car's total weight. As speed increases wind resistance increases as well as rolling resistance--the torque of the engine has to overcome forces acting on the body before it is divided up amongst accelerating the wheels and the car itself, and all of a sudden inertia is no longer such a huge factor in acceleration. Given the same engine, Cd and transmission, a 1000lb car will have the same top speed as a 3000lb car, because top speed is drag limited instead of weight/inertia limited. The 1000lb car will get there much quicker, but the fact remains.
While wheel weight is not as severe in its differing effects between gears as, say, flywheel weight, the only upgrade that will be more noticeable at speed than at rest is if you manage to somehow lower the Cd of the vehicle.
That said, the affects of wheel weight should technically be more noticeable in second gear at 20mph then in first gear at 20mph, but this is negligible and not really what anyone meant.
__________________
All stock.
MorpheusZero is offline   Reply With Quote
Old 05-01-2008, 09:57 PM   #13
Currently using a 17x8 15 pound wheel right now. And deff felt a difference when i put them on. Now considering those buddy club QF's. When i first saw their price i said absolutely not but they have stayed in the back of my mind ever since. CONSTANTLY.
__________________
Old 05-01-2008, 09:59 PM   #14
Quote:
Yeah, they are pretty ridonk.... I really wish I could get some 16x9 SSR comps or something and wrap them in 255/45 T1Rs
__________________
All stock.
Old 05-01-2008, 10:15 PM   #15
Blackbirdvq hit me up a while back about some SSR comps. You can see if he still has them, doubt it though i mean they are SSR's.
__________________
Old 05-01-2008, 10:21 PM   #16
When I said "I wish I could get" I meant more like "I wish I had that kind of money and the will to spend it on wheels instead of a motorcycle"
__________________
All stock.
Old 05-02-2008, 09:51 AM   #17
Certified Hooptie
NmexMAX's Avatar
Quote:
Originally Posted by MorpheusZero View Post
Wrong.
This is only true for a load based i.e. Mustang Dyno, not a Dynojet.
__________________
Old 05-02-2008, 12:47 PM   #18
Where did I mention a dyno? Read the thread man.
__________________
All stock.
Old 05-02-2008, 01:25 PM   #19
Certified Hooptie
NmexMAX's Avatar
Your post is perfect for explaining how a Mustang dyno works, so I'm book marking it for t3h 's
__________________
Old 05-04-2008, 03:45 PM   #20
505max94se's Avatar
Changing the mass of the flywheel only directly affects rotational mass on the input side of the trans and this effect shouldn't change if the output side of the trans is spinning faster or slower based on gear change (i.e., change in vehicle speed). The only operating speeds that a flywheel will encounter are idle to fuel cut. If anything, the changing the mass of the flywheel will be more noticeable in lower gears because lower gears give the input mass a chance to accelerate at a faster rate.
I've owned/built two VE-5 3rd gens that were/are almost identically modded when my tests were made. They both have/had the same ride height, tire width, and vehicle weight. One has a little more power, heavier brake rotors, and heavier wheels. Which one will have a high top speed and easier time getting to its top speed? I know because I went 155-160mph (on a track) in the one with less power and much less rotational mass. The other one would run out of breathe around 140... I've even raced these two cars (on a track) against each other. From 0-80, the Maxima with more rotational mass would win and between 80-100 the other one would catch up and start to pass the one with more rotational mass.
Here's a quote pertaining to inertial and mass. I found it HERE
"Mass as a Measure of the Amount of Inertia
All objects resist changes in their state of motion. All objects have this tendency - they have inertia. But do some objects have more of a tendency to resist changes than others? Absolutely yes! The tendency of an object to resist changes in its state of motion varies with mass. Mass is that quantity which is solely dependent upon the inertia of an object. The more inertia which an object has, the more mass it has. A more massive object has a greater tendency to resist changes in its state of motion."
FYI, I'm not referring to dyno physics, I'm merely referring to real world physics. Although, in my mind, I would think that the two would be fairly similar.
__________________
My CarDomain Page
Old 05-04-2008, 04:02 PM   #21
505max94se's Avatar
Quote:
Absolutely
__________________
My CarDomain Page
Old 05-05-2008, 01:03 AM   #22
Flywheels are only noticed in the lower gears, yes, because more of the torque will be used to accelerate the flywheel in the lower gears. I am not sure why you thought I meant otherwise, I made it pretty clear.
Which one had more top end? Did they both have the same alignment? Correct tire pressure? Were the rolling diameters the same? Were the speedos calibrated identically? Were the drivers identical? etc
Anyway you are not listening. It is simple physics.
If we lived in a vacuum, with ideal (lossless) gearboxes, tires and bearings, the top speed of our cars would be C (speed of light). We would have no drag to overcome and all the power would go into accelerating the wheels and the body of the car. It would take awhile to get to 300 thousand kilometers a second, but it would get there given enough time. If you put the car in neutral it would never stop or even slow down.
The reason we cannot attain this top speed, besides our obvious time constraints, is because we have friction in our bearings and between our gears, but more importantly because we have to move a fawkton of air around our car very quickly the faster the car goes. This soaks up energy. If you put your car in neutral in the real world at 80mph it will slow to 70 in a matter of 10 to 20 seconds. But this funny thing happens--if you put your car in neutral at 140mph it will slow to 130 in about 5 seconds, and if you put it in neutral at 40mph it will take much longer to slow to 30. This is the force that your car has to overcome at high speeds, the force it has to obliterate before it can even think about accelerating your car and overcoming inertia. This force increases with a degree of speed CUBED. That is why a 100hp Scion xPOS can do 100mph but it takes a 640hp 'vette ZR1 to do 200mph.
Did you ever wonder why a brand new 600RR with 120hp and 380lbs (+150lb rider), a power to weight ratio of 450hp/ton can only do 150mph while a 5.5 gen with a power:weight ratio of 160hp/ton can attain the same speed? The bike will get to 150mph much quicker than the Maxima, but the only reason it's able to go faster than a 120hp civic is that it has a much smaller profile and does not have to move nearly as much air.
Wheels have a set amount of rotational inertia. Their inertia DOES NOT CHANGE WITH SPEED. For every 1mph increase in speed, it takes a set amount of energy to increase the rate of wheel rotation by a certain rpm (corresponding to 1mph increase), exactly like for every 1mph increase, it takes a set amount of energy to increase the velocity of the car by 1mph due to inertia. They have an identical effect on the acceleration as weight--the effect decreases as speeds rises (although NOT AS SEVERELY AS THE EFFECT OF A FLYWHEEL, which will DECREASE IN THE HIGHER GEARS).
If you want to get very technical about it, when speeds increase the tires will actually bubble a little which will increase the rolling diameter and set the moment of inertia of the wheel relative to its rolling diameter less, meaning that even in a vacuum, the effect of wheel weight on acceleration will decrease with speed.
Oh yeah, do not try and quote physics sites. I know what inertia is and you are just making an ass of yourself.
__________________
All stock.
