03-03-2008, 07:44 PM
Licensed to Spell
I’m proud to be part of the 300 horsepower club! :oD
Guys, please excuse my double post. I couldn't choose just one forum to post in. Thanks for understanding.
Exact duplicate post in the SC/TC forum.
Copy and paste:
I went to the “Dyno Day” at Dyno Extreme on Sunday, 03-02-08 in Stanton CA (near Knott’s Berry Farm in Buena Park) with James / The Wizard. It was nice to meet up with Joe (joebangaa) and Mike (VIPMaxima, banned,  ). Good job guys on your dynos by the way.
It was a fun time. Lots of high horsepower Supras and other cars. Lots of food, snacks and drinks. Bikini car wash, etc.
Well, I got my highest horsepower to date!  322.76 HP and 307.82 TQ.
Last year I was around 240. So, with an 80+ HP increase, I’m quite stoked, to say the least.
A HUGE thanks goes out to Jimbo “The Wizard” Ozouf for helping me crank out 3 pretty big mods in just the week before the dyno.
Total (power) mods and variables are as follows:
Un-tuned
Unless I say otherwise below, I have all OEM parts and the “stock” parts that come with the Stillen SC kit (yes this means: stock injectors, stock MAF, standard Vortech FMU with 8:1 disc, Bosch bypass valve, stock fuel pump, etc.)
One-step colder NGK platinum plugs gapped to 0.037”
91 Octane gas
13.7 lb 17” rims
12.5 lb 12.2” rotors (stock are 15lb ea.)
Cattman cat-back
LSS test pipe (just for dyno and track days)
Warpspeed Fed Spec aluminum Y-Pipe
Fed Spec. left bank manifold (from Fanaticrock – thanks man!)
(I did a CA spec --> Fed Spec left exhaust bank manifold conversion which eliminated the huge left bank pre-cat. I installed a Cattman O2 simulator for the two downstream O2 sensors)
Vortech V2 supercharger, freshly re-built
2.87” Vortech SC pulley (see boost/PSI information below)
Custom intake piping
A 5”d x 8”l PWR water to air aftercooler (barrel design) with a Bosch water pump, a Jackson Racing front-mount heat exchanger, and a Vortech ice chest/water reservoir.
Thermal insulation to protect the underside of the intake tubing from the exhaust manifold/engine heat.
4th gen. Variable Intake set at 5200 RPMs (installed by The Wizard, the VI master)
Freshly rebuilt I30t VLSD automatic transmission (with Hayden #403 cooler)
Perma-Cool oil cooler (not sure if that results in a power increase or not, but, just in case)
I think that’s it. I hope I am not forgetting anything.
Oh, and my I30 fuzzy A, B and C pillars (good for at least 10 HP  )
I have a bad memory but I think the mods that are new this time (322HP) from last time (240HP) are: one-step colder plugs, lighter rotors, Cattman catback, Fed. Spec. conversion, re-built blower (which fixed a chipped impeller blade and inlet oil leak), a few more PSI, larger PWR AC which replaced a smaller JR AC (see explanation below), 4th gen. VI, VLSD tranny with cooler, oil cooler. But I did have my fuzzy pillars last time (otherwise I would have dynoed at 230)!
As far as the boost / PSI level... Well, on the dyno I made maximum boost of 10PSI. However, I always hit 12PSI max on the street. The dyno owner/operator told me this was normal and it’s because the dyno has less of a load than the street. Huh?
I recently replaced my small 3”d x 11”l Jackson Racing (JR) water to air aftercooler (AC) with the PWR AC mentioned above. The PWR is supposed to be more efficient in cooling and result in less boost loss. I now lose 1PSI across the PWR AC where before I lost 2PSI across the JR AC. I also have a dual intake temperature gauge by Autometer. I have one probe upstream of the AC and one downstream. With my JR I would see about a 10 degree difference during idling/cruising and a max delta of 40^ during a full boost run. With the PWR I know see a 15-20^ delta when cruising and a 60^ delta during a full boost run. During the dyno, I added ice to the ice reservoir and saw a max delta of 85^!
Dyno Extreme didn’t hand out dyno graphs that day. So, excuse me for the digital camera photo of my dyno. The owner should be sending out the run files via e-mail shortly so I will post up the dyno when I get it. Also, these are the uncorrected numbers.
I’m really stoked. Two of my dreams were achieved at once: 1.) Break 300HP and 2.) Get a single-digit weight to horsepower ratio (~2900 lb / 322 HP = 9.00 LB/HP!!).
__________________
Cleaning up the .org's grammar, one member at a time.
1999 SE, Pearl White/Black leather - Fully loaded with all factory options except TC (ABS, heated seats, side airbags, etc.) - Supercharged (322 HP / 307 TQ)
1996 GLE, Pearl/Black - Superchargerless
1993 SHO, Pearl White/Gray - Stock
Super Charger install instructions
Licensed to Spell
Pics
__________________
03-03-2008, 09:04 PM
Certified Hooptie
IBlearnhowtodynoyourauto  Nice numbers man
What wheels are you rockin'?
03-04-2008, 06:40 AM
It appears that your car is not level.
Sorry, couldn't help myself, and I know someone else will say if I didn't.
Nice dyno BTW.
__________________
Hotshot Headers, Cattman Catback and FastCat, Nissan Works Phenolic Spacers, Advanced Timing, Definitive Motorsports UDP, 2nd Gen Maximum Tuning VB, Maxspeed Springs, 9 inch K&N cone filter, Kosei Penta R/T (17x7.5, 16lbs)w/ Toyo T1-S 245/45/17, Odyssey PC 680 battery (14 lbs).
245.2 HP/245.2 Torque - Standard
237.5 HP/237.5 Torque - SAE Corrected
03-04-2008, 07:43 AM
3.5 in the works
Bwah hah ha ... level...
Congrachoomalations on breaking 300!
__________________
1998. 3L. 5-spd. Sterling Mist. SE.
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
03-04-2008, 11:28 AM
Nice, I'm also curious as to what wheels you're running. Those look like narrowish RP-F1s but I don't remember any dipping below 14lbs.
__________________
All stock.
03-04-2008, 11:42 AM
300+ HP! WOW! man i wouldnt know how to act with that much hp. congrats.
03-04-2008, 01:44 PM
Licensed to Spell
Thanks guys.
Yeah, yeah.... the level. I recently ordered a fiberglass hood with an inverse hood scoop and unfortunately the stock shock's bolts don't fit in the hood's holes.
The wheels are 17"x7" Kosei K1 TS.
Tire Rack lists them at 14.1 but I got 13.7 lb on my scale.
I hope this link works.
__________________
03-04-2008, 03:48 PM
12's or bust
congrat's, I hope to join the club next time I hit the dyno.
any pic's of the hood
__________________
My Cardomain _  _ Maxima runs 14.30 N/A
Mevi/I/Y/E/N
Dyno: 258whp & 267wtq
Nitrous PB: 13.9@95mph
All Motor PB: 14.3@95mph
Looking to join the 300whp club in 2008
3280lb with driver, full trim, rims, spare, jack, fluids, etc and notorized proof
03-06-2008, 01:10 AM
Carbon Fiber addict
Good job Josh!  Call Sarkis and bug him for the runfiles...
Can't wait to see your A/F. Time to tune the Max and extract some more ponies...
We should have installed a FP guage under the hood. I bet your FP is getting up there.
__________________
My Max:
99 Maxima 5 spd SE, SC'd, MEVI, Cattman Headers, KEVLO LED tails,R34 S2000 AP1 projector retro, Brembo GT BBK, Emanage Ultimate..
03-06-2008, 08:40 AM
I wish I stayed to watch your runs..
__________________
AEM/Cattman/Energy Suspension/FrankenCar/Motostorm/Place Racing/SSR
/////Alpine/CDT/Eclipse/KnuKonceptz/Optima/SoundSplinter/US Amps
03-07-2008, 12:58 AM
Nice Numbers...Pictures of the Hood?
__________________
1995 SE VQ30DE-T
Totaled: December 11, 2004
5 Speed Conversion, Custom Turbo Kit, Body Kit, Custom Body Work, Custom Paint, Chromed Engine Bay, Coilovers, Etc.
1995 SE 5MT
Purchased: May 12, 2006
Project Car.....Details Coming Soon
1997 SE 5MT Converted
Purchased: November 4, 2006
Daily Driver with Goodies
03-08-2008, 01:23 PM
Licensed to Spell
Well, Sarkis isn't sending me the run files on his own so I just sent him a friendly reminder.
As for the hood, I still need to paint it, figure out the hood shocks, modify it a little and so forth, but here is one of the few pics of it I took the night we test fitted it. I am not totally stoked over the looks of it, I just mostly wanted the weight reduction (41.5-20.7 = ~21 lb savings!!) and heat dissipation. It has front inverse hood scoops and a cowl design. The problem is, there is no outlet near the windshield even though it is shaped like a cowl! So I need to cut an opening. Fitment/quality is pretty good other than the hood shock bolt holes being too small and the front passenger corner is lifting a little but I think I can fix both. I'll take more pics when I am all done.
P.S. No, the hood is not closed all the way in this picture.
__________________
Reason: Add P.S.
03-09-2008, 10:21 PM
Z
Damn, that's a 12 second monster.
__________________
2006 Daytona/Frost 5AT: MotorDyne 5/16 Plenum Spacer | BTDC@17 | Borla True Dual | Ultimate Racing HFCs | Jim Wolf Popcharger | Weight: 3175lbs - 60LBS Weight Red. | Hotchkis Springs | Eibach 15mm Rear Spacers |Michelin Pilot Sports | Dunlop M3s | 3M Clear Bra | Polished Mini Antenna | 2005 FX35 Graphite/Brick
03-12-2008, 12:37 AM
Josh, have you gotten your runfiles yet? Sarkis lags...
__________________
03-12-2008, 01:15 PM
Licensed to Spell
Quote:
I was just thinking about that last night. No, I haven't. I sent a reminder e-mail several days ago - no reply. I'll send one more e-mail and/or call. Have you got yours yet Joe? If you do a drive-by to get yours, could you bug him to send mine? Thanks.
Joe/James, do you have Sarkis's phone number?
__________________
03-12-2008, 01:24 PM
Licensed to Spell
Quote:
That's the plan.
Not sure how accurate these formulas are but, if I plug my variables into this formula:
1/4 mile ET (s) = 5.825 x [Weight (lb) / Wheel HP]^.3333
(Weight of car with me = 3150 lb, conservative. FWHP = 300 HP, conservative)
Then: 1/4 mi ET = 12.74 s
We'll see.
__________________
03-12-2008, 02:59 PM
Carbon Fiber addict
Quote:
714 828 9182 Dyno Xtreme
714 231 4299 Sarkis cell
__________________
My Max:
03-12-2008, 06:36 PM
Licensed to Spell
Spank you.
__________________
03-14-2008, 11:24 AM
No one else had asked, but whats up with the large section in the charge pipe...
nvm, nice numbers
__________________
VQpower.com
Need work done: Suspension, Engine, Brakes, Cosmetic, Headlight Retrofits
03-14-2008, 12:28 PM
Licensed to Spell
Quote:
nvm, nice numbers
I don't think anyone else needs to ask.  I clearly stated I have a PWR water to air aftercooler (barrel design, 5" in diameter), talked about it in detail and even included a link to the manufacturer's website.
You read every one else's reply in full but not my first post in full??
Anyway, thanks GTR.
__________________
03-14-2008, 01:47 PM
Licensed to Spell
I just called Sarkis. I'll get my run files "tomorrow".
Translation: I just made the first of the four total phone calls it's going to take to get him to send the files.
__________________
1999 SE, Pearl White/Black leather - Fully loaded with all factory options except TC (ABS, heated seats, side airbags, etc. | |
