02-16-2008, 08:31 AM
Owns a Maxima
2002 6MT Best Run - 241 WHP 237 TQ
I finally got this done and was pretty satisfied with the results, especially how consistent the curves are, I just wish the guy ran it to 6600 like I told him to. The AFR was much flatter than I expected too, considering it is untuned but is still in the high 12s, except for the last run. They did use a tail sniffer for the AF, FWIW.
Run 1 - 237 WHP 234 TQ
Run 2 - 239 WHP 236 TQ
Run 3 - 241 WHP 237 TQ
Current set-up:
GAB, Cattman Gen 2 headers, Frankencar b-pipe, Megan Racing axle-back, stock cat, stock 17s, stock base timing.
For those who are interested, there's a vid here:
Nmexmax - you have email.
02-16-2008, 09:36 AM
So your butt-dyno was pretty darn accurate!
__________________
AEM/Cattman/Energy Suspension/FrankenCar/Motostorm/Place Racing/SSR
/////Alpine/CDT/Eclipse/KnuKonceptz/Optima/SoundSplinter/US Amps
02-16-2008, 09:51 AM
Owns a Maxima
Quote:
LOL. It's well calibrated I guess.
02-16-2008, 10:35 AM
大 陆 弟
Car sounds great! What's next? IM spacers?
__________________
02-16-2008, 11:44 AM
12's or bust
from what I heard the driver did hit the rev limiter
__________________
My Cardomain _  _ Maxima runs 14.30 N/A
Mevi/I/Y/E/N
Dyno: 258whp & 267wtq
Nitrous PB: 13.9@95mph
All Motor PB: 14.3@95mph
Looking to join the 300whp club in 2008
3280lb with driver, full trim, rims, spare, jack, fluids, etc and notorized proof
02-16-2008, 12:48 PM
Owns a Maxima
The operator took it to fuel cut on the first run (the run in the vid) but stopped short on the next two runs. You can also see that from the chart; he only hits 6600 on run #1. It isn't really a big deal since the power starts to tail off after 5800 anyway.
02-16-2008, 09:40 PM
Good numbers man.
__________________
2002 Nissan Maxima 6-speed: GAB/SSIM/Cattman Gen 3 Headers/Megan Racing Test Pipe/Tsudo Catback/Apexi SAFC-2/Energy Suspension motor mounts/Tein S-Techs/blacked out sidemarkers/headlights blacked and cleared
STL MAXIMA MEET
02-17-2008, 01:19 AM
Nice numbers man!!
__________________
VQ30DE T - Holset HE351, Tial 38MM, HKS SSQ, MEVI, 3" Turbo back, Tein Coilovers, 17" Superleggeras, Full Z32 BBK
"Because boosted is beter.."
02-17-2008, 02:06 AM
Very good with your HP mods! Should be able to get up by 260 with just a few more bolt on's.
Your car sound nice also!
__________________
I'd rather spoonfeed than Flame and Postwhore.
YA THERE HEAVY 20'S FROM A FX45
My 02 6-speed SE Mods = intake, headers, full custom exhaust with no cats, 75 nx wet shot nitrous,denso iridium 1 step colder plugs, ssim, slotted/drilled brakes, ce front strut bar, heavy arse wheels, tein s-tech, In need of a/f tuner and tune badly, Plus some other randoms
02-17-2008, 02:22 AM
Need A Light?
so the v-afcii was causing you to lose hp last time?
02-17-2008, 09:28 AM
Owns a Maxima
Quote:
In a way, yes, but it wasn't due to a faulty unit or harness. It was the MAF connection from the harness. I tried two VAFC-IIs, without changing the harness, and got the same results. Every time I reconnected the direct MAF connection, the car ran fine, but whenever it went through the harness and VAFC-II, I lost power. I even mailed the VAFC-II to Deckdout2 to try and he said it worked fine. Someone else is using my harness and VAFC-II now and has had no issues, so I must have screwed something up along the way. I thought that I had rechecked everything multiple times and even the sensor voltages checked out fine. Must have been something obvious that I missed, but oh well, I've moved on now.
02-17-2008, 09:32 AM
Owns a Maxima
Btw, thanks everyone. I am happy with the numbers considering it literally is just GAB, headers, and cat-back.
02-17-2008, 09:36 AM
Owns a Maxima
Quote:
Now that I think about this again, I think I should just get the base timing advanced to 17 degs for now. That should be a pretty quick and easy thing to get done.
The spacers will depend on what route I decide to go with the IM.
02-17-2008, 10:48 PM
Where's NmexMAX?
Quote:
Any route you take, you're still going to have to take it out, so you may as well do the spacers
02-18-2008, 09:01 AM
Question for you puppetmaster, I put my Gen III Cattman Headers/Y-pipe on and when I took it for a spin I did a quick little punch and it really didn't seem all that much faster. It was definitely louder but I don't think it felt like it pulled as hard as what I was expecting. Could you tell a difference right away when you installed your Gen II's????
__________________
STL MAXIMA MEET
02-18-2008, 10:57 AM
It takes time for the ECU to "learn" new mods, so it may take a couple days or a week. You should get it tuned as well to notice full benefits.
02-18-2008, 12:13 PM
Well that is true....also I already am going this Saturday to get my SAFC-2 dyno tuned and I have a SSIM on the way. Hopefully after those two things are done I notice a difference....I think the tuning will help a lot because I know she is running pig rich because everytime I start it up it smells like a race car...lol. I am probably going to put my stock cat on the car though because right now I sound like a Honda Civic or something it has that bees in a can sound to it. Hopefully putting the cat on the car will take that away.
__________________
STL MAXIMA MEET
02-18-2008, 01:19 PM
Quote:
Just put your stock mufflers back on...NmexMAX and I will approve
02-19-2008, 06:32 AM
Owns a Maxima
Yes, we could tell the difference right away. Cutler was with me that day and he drove the car too and will agree.
That is also partly because you have no pre-cats (and a main cat, in your case). Get a dyno with AF readings to see what it is for sure.
02-19-2008, 06:37 AM
Owns a Maxima
Quote:
As posted above, with headers, I would think that most would feel some difference felt right away. I don't think the ECU is a huge factor in this because in open loop, O2 sensor feedback is ignored anyway, and I assume nothing was changed on the MAF end.
02-19-2008, 09:37 AM
I noticed somewhat of a difference, just not as much as some of you guys say.
__________________
STL MAXIMA MEET
02-19-2008, 09:39 AM
Owns a Maxima
IMO, butt dynos are pretty much extremely subjective, and in most cases, useless, so I never rely on them for anything. Once you get your car dynoed, you will find out for sure, so don't sweat it for now.
02-19-2008, 09:57 AM
True...I just hope I at least lay close to 250whp with the headers, SSIM, and the tune
__________________
STL MAXIMA MEET
02-20-2008, 07:32 PM
