Go Back   Maxima Forums > Track and Tune > Dyno Discussion and Slips
Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Thread Tools Display Modes
Old 09-15-2007, 10:19 AM   #1
Send a message via AIM to streetzlegend Send a message via Yahoo to streetzlegend
Rear Mount Turbo, finally dyno at 10psi
I finally Dynoed at 10psi. Results:
299WHP and 291TQ
__________________
Currently Under construction check my progress so far http://forums.maxima.org/supercharge...-new-post.html
Auto, TO4b(10psi), 2.1 60' 8.6@82 1/8th , 312WHP/301WTQ[/b]
streetzlegend is offline   Reply With Quote
Old 09-15-2007, 10:48 AM   #2
Send a message via AIM to 95BLKMAX
yyyyyyyyyea that my boi!!!!!!!
__________________
NA-Built Baseline
95BLKMAX is offline   Reply With Quote
Old 09-15-2007, 03:38 PM   #3
192.168.1.1
gtr_rider's Avatar
good work
__________________
VQpower.com
Need work done:
Suspension, Engine, Brakes, Cosmetic, Headlight Retrofits
gtr_rider is offline   Reply With Quote
Old 09-15-2007, 04:11 PM   #4
Send a message via AIM to MDeezy
very nice powerband
__________________
1996 Nissan Maxima 5MT 3.5 (Getting a fresh remix)
1995 Nissan Maxima 4AT "Champagne Coolie" *Sold*new home in FL
1997 Nissan Maxima "Powder Fresh" 5MT 3.5 (performance built)(*new plans*)
MDeezy is offline   Reply With Quote
Old 09-15-2007, 04:25 PM   #5
I dont understand something though. My previous dyno at 7psi, the TQ peak was at 4400 RPM, and now my TQ peak is at 5.2k'ish. I dont understand what could have shifted the torque curve to the right. I have done the following, put header wrap on the charge pipe, put header wrap on the exhaust (excluding ypipe, everything else, catback).
Could it be the way im controlling my wastegate, I have it completely closed when below 10psi, as it gets close to 10psi it starts opening up. Before at 7psi, i just had a manual one that was set at 10psi all the time. Maybe having it closed completely while spooling up is causing a bit of loss in TQ and shifting of the curve? Also, the tq at 7psi was higher than hp, now its opposite.
__________________
Old 09-15-2007, 07:12 PM   #6
The LandShark has teeth..
grey99max's Avatar
That's a good set of dyno numbers, streetz. Now if you can take it to the strip and lay down some good times, maybe you'll be as quick as a sprayed automatic I can think of?
__________________
'99 GXE, Tune-by-Tape MAF mod, 3.5L w/cams, SSIM, 255Walbro,AERO FPR, VLSDauto, Edge TC, DR-mod, Shift_Fast, dual-B&M cooler, JClawbars, dual-NX nitrous, dual heated15lb bottles, OBX headers, 3"Warpspeed exhaust, PLXR-300 wideband, IlluminasStrut/springs, 24.5"M&H, ProgressRSB, HawkHPS, Clarion50Wx4 head w/Alpines, Fosgate sub. Spare tire+jack,3300 lb car. 355WHP-dyno.
13.158 3.0 time slip
http://i48.photobucket.com/albums/f2...3/Fscn1518.jpg
12.394 @113.22 w/3.5
http://i48.photobucket.com/albums/f2...9/DSCN0527.jpg
grey99max is offline   Reply With Quote
Old 09-15-2007, 07:52 PM   #7
Par-mi-gian-o
Tatanko's Avatar
Send a message via AIM to Tatanko
Update your sig.
Yeah, Streetz, I'm not sure what the deal is with the torque curve. Maybe explain to them your manifold?
__________________
SHIFT_obsession
Tatanko's Maxima Site & VQ35DE.com
Tatanko is offline   Reply With Quote
Old 09-15-2007, 08:56 PM   #8
Merc signs my checks
liqidvenom's Avatar
Send a message via AIM to liqidvenom
veru nice dyno...you are making alot of people who though you were nuts look stupid now
__________________
which team are you with?
liqidvenom is offline   Reply With Quote
Old 09-16-2007, 07:51 AM   #9
Quote:
thats my fav part lol
__________________
Old 09-16-2007, 09:45 AM   #10
3.5 in the works
DandyMax's Avatar
Send a message via AIM to DandyMax Send a message via MSN to DandyMax
'Bout time you dyno'd! Hah j/k.
What kind of intake manifold set up do you have again... MEVI?
__________________
1998. 3L. 5-spd. Sterling Mist. SE.
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
DandyMax is offline   Reply With Quote
Old 09-16-2007, 10:20 AM   #11
Nah i have a 00vi with a working vias. How ever, i had done a couple things to the rod. i sharpend the plates on it to see if it improved top end, but im now thinking that this might cause it to leak air when closed, also i removed one or two O rings from the rod because it was getting stuck after it heated up. I compared my torque curve to my buddies which he didnt have a rod in the VI, and his dyno looks very similar to mine. so im thinking that w/e i did to the rod, is causing the loss of low end torque
__________________
Old 09-16-2007, 11:20 AM   #12
^^ that would make sense
__________________
NA-Built Baseline
Old 09-16-2007, 12:20 PM   #13
Slow...Streetz vs. Goaliekeg coming soon!!!!!
BTW, nice numbers.
__________________
South Florida Maximas
GoalieKeg is offline   Reply With Quote
Old 09-16-2007, 01:27 PM   #14
Well i just took out the power rod, i moved the o rings closer to the vias, now the rod dosnt rattle anymore at idle like before. i went for a drive, and yea, big difference, it seems that the o rings not being present caused for air to leak or for the rod to not functon properly, i felt a difference right away, instant acceleration n power
__________________
Old 09-16-2007, 01:30 PM   #15
Quote:
Werd son, I see 310whp and 300wtq in your future.
__________________
Old 09-16-2007, 04:24 PM   #16
Well, torque should now be higher than hp. feels nice =). next step, is Moroso!!! im going gutted this time, and also spraying 1st maybe 2nd.
__________________
Old 09-16-2007, 04:48 PM   #17
DYNO VIDEO:
http://www.youtube.com/watch?v=pw51bz5i_EY
__________________
Old 09-16-2007, 09:34 PM   #18
Quote:
BTW, nice numbers.
I want to see this!!
__________________
I love My Maxima!!
Mods: CAI, Ypipe, Test pipe, Exhaust, FSB, RSB, E-Manage Blue, 350z Tsat, Full painted white lexus pearl maxima, Stillen lip kit
supermanrox305 is offline   Reply With Quote
Old 09-17-2007, 11:11 AM   #19
192.168.1.1
gtr_rider's Avatar
dyno video..
http://www.vqpower.com/v2/downloads....ownload_id=208
__________________
VQpower.com
Need work done:
Old 09-17-2007, 08:49 PM   #20
liqidvenom's Avatar
very nice vid...your car is very quiet for a 300hp turbo vehicle
__________________
Old 09-17-2007, 09:07 PM   #21
00vi'dvq30devq354.5genftw
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
Aww yes I love the sleepy sound. No whistle or nothing just straight POWA! Congrats Streetz. We need 1/4 mile times pleeasee. The suspence is tearing me apart. lol
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The Dark Phoenix 13.517@102.3mph 60' 2.0 AUTO 245 RWHP 3280lb w/driver
Fear me.
VQ35 Swap Progress Thread
ajcool2 is offline   Reply With Quote
Old 09-18-2007, 03:59 PM   #22
Quote:
hah dont worry buddy, i cant wait for 1/4 either. was waiting for a slightly cooler weather, its been in the 100's lately, today i felt a nice cool air hit me while at work so might be soon.
thanx, btw you should hear how it sounds with the cutout closed. its like a stock maxima lol yet still putting down power
__________________
Old 09-18-2007, 04:22 PM   #23
ajcool2's Avatar
Do you go to brandenton? If so you should sign up for this and beat up on some Z's. lol
http://www.my350z.com/forum/showthread.php?t=285518
__________________
DCMAX FTW
Fear me.
