Go Back   Maxima Forums > Track and Tune > Dyno Discussion and Slips
Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Thread Tools Display Modes
Old 08-27-2007, 04:42 PM   #1
The 14.4 ET has been solved (234.54/225.17)
got afr tuned today and realized wtf was going on, first run the afr was so rich that the machine couldnt even read it.
after a deal of tuning, let the car sit and made another 3 runs and tuned some more, the best was 234.54 WHP and 225.17 WTQ. Id say im much happier and i could def notice that difference on the way home. cant wait to get back to the track and see if i can do any better. i think it would have made better numbers if we had let it sit again cause he got the afr a little smoother but it was pretty heat soaked after 9 pulls in an hour. the afr is really goofy from 4-4.5, but after messing with it it didnt change so
Power mod list: custom short ram intake (filter, hemholtz resonator, maf tube), bored out 75mm maf tube, shelf removed, y-pipe, test pipe, vafc tune. its a 2002 6-spd
DasYears is offline   Reply With Quote
Old 08-27-2007, 04:59 PM   #2
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Nice #'s. I'm wondering just how much headers would help at this point.
You know I'm going to ask, got the DRF's? Also, how much correction are you taking out (%)? I'm curious as to why it was so rich in the first place. How many runs did it take to get to that point? What were the SAE CF#'s?
The large gain in power could be attributed to both AFR and possible added timing considering how rich it was.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 08-27-2007, 05:03 PM   #3
Quote:
ill find out, but it might not be for a while (years) cause im still going to school and dont quite that much, the 150 dyno tune is pushing it.
pm me the email, i have 9 for you. CF's we started at -6 @ 3000 and tapered to -10 @ 4500-cut (checking this). i wish i knew why it was so rich to start too, i expected the opposite since i have the sort-of bored intake.
Old 08-27-2007, 05:09 PM   #4
Certified Hooptie
NmexMAX's Avatar
Quote:
Even then strong #'s considering you do not have headers,
bizzy1999@hotmail.com.
I also expected maybe a little leaner because of the MAF. Looks like some DEK dynos I've seen before (fat AFR).
__________________
Old 08-27-2007, 05:24 PM   #5
yeah im pretty happy, i went expecting low 230's tops and i wasnt let down. overall pretty happy. although i wont be satisfied until i hit up the track and see if i get any better. hopefully ive learned how to drive since i went last time.
yeah, i think youre right about the timing thing, just like using bigger injectors or higher pressure and removing fuel, except i just have a retarded ecu.
Edit: the official CF's: -4 +/-1 from 2500-4100, -8+/-1 from 4100-cut. theres a little extrapolation in there, but it mostly follows that. i think the -6 and -9 that i stated before were the first corrections.
Old 08-27-2007, 05:31 PM   #6
interestingly enough, the highest #'s were from the only 4th gear pull. he was doing 3rd gear pulls to try to keep the heat soak down. i guess i should have stuck around until it cooled off and then had him run another in 4th to see the final outcome. oh well. and to add to that, the base run had some breaking up with it, the operator said it was because it was running so reach that the machine couldnt even read it. i guess it doesnt matter since the rest are all fine
Old 08-27-2007, 06:37 PM   #7
now im starting to think my car feels sluggish at 4k rpm and 5k rpm because i badly need a tune.
dirtydishes06 is offline   Reply With Quote
Old 08-27-2007, 06:40 PM   #8
Quote:
lol, if its anything like mine you need a tune from 2k-6650. my car now feels faster in full trim (150+ lbs extra, heavy 18's) than it did in race trim and a good deal faster than it did before in full trim.
Old 08-27-2007, 09:15 PM   #9
Send a message via AIM to SonicDust187
You are still on the rich side from 5-6.3k. Pull some fuel there. Try to tune to make the a/f line as flat as possible from 3k to about 6k at 13:1 ratio and 6-6.5k to about 12.5 or 12.7. The whole line should be a smooth line.
SonicDust187 is offline   Reply With Quote
Old 08-27-2007, 09:21 PM   #10
yeah i did a little more tweaking, just a small change at 4k, 6k and 6500. wish i had a WBO2 so i could see again. but im happy with what i got, considering it was only an hour of actual dyno time (20 mins setup) and a 35hp, 25tq gain. lol. probly the best $/hp mod that i have. but youre right, it should be smoother. it looks really straight on the printout, but i blew the afr way up on my comp and its pretty obvious
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
