Go Back   Maxima Forums > Track and Tune > Dyno Discussion and Slips
Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Thread Tools Display Modes
Old 06-20-2007, 10:56 AM   #1
6yrs old=36,500 miles :)
harmbone2k2's Avatar
248.5whp-248wtq
S-AFCII(tuned 1 year ago),HS HEADERS,UDP,FC INTAKE,FC B-PIPE,GENERIC MUFFLER
71deg day with 5-7 minutes in between runs.
__________________
harmbone2k2 is offline   Reply With Quote
Old 06-20-2007, 11:01 AM   #2
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Sweet #'s
Got runfiles? If so, may i have them please bizzy1999@hotmail.com
If you could post the AFR curve, that be nice.
Take it to 6550 next time What was the difference between runs that made more hp? Also, what was different on this run vs your previous best?
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 06-20-2007, 05:25 PM   #3
Thanks!! I will be going back to the dyno when the weather cools off. Gotta a new baby boy so car tuning is on hold for now. My last run was around 236whp/237wtq. I took off the Frankencar muffler and replaced it with a straight thru design cheap muffler from X3racing. I also changed the Apex'i intake filter to a $30 Filter from the internet somewhere. I had the dyno shop put the AFR to around 13.5 last year due to my car being a daily driver. I just wanted to see if my car could put down the numbers it was capable of with what I have installed. I am not too familiar with this mod but, next year I will be looking to purchase the Technosquare ECU Flash(L-SPEC maybe). That should put me close to if not over the 260whp mark. I still have that stupid SES light from my header install 2 years ago that will never go away. Other than that, I am pretty happy with the numbers.
Old 06-20-2007, 09:01 PM   #4
Certified Hooptie
NmexMAX's Avatar
Nice improvement. I’m still sticking with my stock muffler because it hasn’t failed me yet. The L-spec really doesn’t do much if any for performance. The throttle closing theory has been debated, and IMO, has been shot down. Speed limiter also doesn’t add power. Mine is useful because I’m auto, and some have seen a soft limiter @ 130MPH, which is about fuel cut (6550) for 4AT A33B’s. One thing you’ll like is the extended rev limiter, but your dyno cuts out earlier than stock, so it will be nice to see what you will muster@ that RPM(7100). What I would suggest before you do the L-spec is the large MAF mod since you already have the SAFCII. It quite cheap and you will feel the gains even @ part throttle.
Here’s the link.
http://forums.maxima.org/showthread.php?t=517758
BTW, I have not receive the runfiles . Were you able to get them from the shop?
Old 06-21-2007, 12:35 AM   #5
Send a message via AIM to l3ftonm3
SSIM the manifold and add a 82mm maf then go tune again.
l3ftonm3 is offline   Reply With Quote
Old 06-21-2007, 09:00 AM   #6
Sexier Than Simpson
Bufflomike's Avatar
Quote:
Okay, are there instructions on how to SSIM the manifold or is this only available from SR20...
Nmex you have the link because all I can find are vague references to this.
Bufflomike is offline   Reply With Quote
Old 06-21-2007, 10:05 AM   #7
Owns a Maxima
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
http://www.nissanclub.com/forums/eng...d-results.html
Puppetmaster is offline   Reply With Quote
Old 06-21-2007, 10:08 AM   #8
Owns a Maxima
Quote:
Those are nice numbers, you're going to have to do much more than a L-spec to get to 260 whp.
Btw, I'm curious to see if the Frankencar rear really is that restrictive since your peak hp has changed considerably. I was always under the impression that the differences were minimal up top between the baffled FC and a straight through muffler.
Old 06-21-2007, 10:21 AM   #9
Sexier Than Simpson
Bufflomike's Avatar
Quote:
Originally Posted by Puppetmaster
Thanks Puppet, still got that stock IM for sale?
Old 06-21-2007, 10:37 AM   #10
Certified Hooptie
NmexMAX's Avatar
It's a trying to keep up with you darn 6MT's.
IBintrawebdynoqueenstatus
Old 06-23-2007, 10:55 AM   #11
huffdaddy2008's Avatar
Send a message via AIM to huffdaddy2008
Beastly #'s. Congrats. Just curious harmbone, what did you do w/ the frankencar muffler? Disregarding sound, this really changes my impressions of that muffler. I know theres too many factors that could account for the different #s and Im not trying to start anything back up but i remember reading Catts "claiming" it was more restrictive than stock. Itd be interesting to see someone dyno a frankencar vs. stock vs. a free flowing muffler.
Nmex, any new plans to try and keep up w/ the 6 speeds?
huffdaddy2008 is offline   Reply With Quote
Old 06-23-2007, 01:16 PM   #12
Certified Hooptie
NmexMAX's Avatar
Quote:
14.0
94oct
__________________
Old 06-23-2007, 08:36 PM   #13
I sold it about 2 years ago huffdaddy. It was way too heavy for one thing. It kept banging underneath and yes it is very restrictive. Look at the cutout on their website.
NmexMAX--I will not get any runfiles until this fall. When I meet up with the guys in OK City in September, I will post them.
Old 07-02-2007, 09:02 PM   #14
Thinks he is fast
maxspeedse02's Avatar
Send a message via AIM to maxspeedse02
I plan on changing my rear section very soon for something free-flowing like a custom magnaflow. I unfortunately do not have a shop equipped with a mandrel bender nearby so I'm thinking about buying some pre-bent stuff online and having a local place weld. Any thoughts?
__________________
2002 SE 6-speed HLSD: WM STS, ES poly shifter bushings, PR CAI w/ K&N, SSIM, Hotshot headers, Warpspeed MS cat, Cattman Cat-back, ES Motor Mounts, TS L-Spec, Emanage Blue, Cleared out turn signals, Black headlight housing, Umnitza DDEs, Progress RSB, Powerslots/Hawk HPS, Fidanza aluminum flywheel, Exedy Stage 1 clutch, 06 G35 Sedan seats.
FS: 02 Frost Leather Front Seats
http://forums.maxima.org/5th-generat...ml#post6563024
maxspeedse02 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
