Go Back   Maxima Forums > Track and Tune > Dyno Discussion and Slips
New! Use your Facebook to securely log into this site, click logo to login
Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-11-2007, 10:10 PM   #41
Send a message via AIM to 98SEBlackMax
Quote:
Originally Posted by Niz-Dat
I don't have a scanner available since I just have the print outs. If someone has a scanner and a fax I could send the sheets out that way. The 260 is at 6300 rpm and the torque is a flat line from 3750 to 6300 rpm. I am also using the 3.5 intake with the pathfinder TB.
That HP at that RPM is odd, for that kind of cam & head setup it peaks to early IMO. Have you removed the shelf and VIAS inside that 3.5 intake manifold?
For example I was able to hit 201 WHP at the redline with my DEK manifold swap and VQ30DE with stock internals, only thing that was stopping me from more WHP was the redline.
http://forums.maxima.org/showthread....16#post4077916
That was a true 201 WHP, later on that year I was able to get 196 WHP with bad head gaskets on that hot house dyno at Maxus '05.
__________________
- Joe
1996 KH3 Maxima SE - 222 WHP / 208 WTQ SAE corrected @ 209,000 miles, VQ30DEK swap
(5 spd - project car, never ending money pit )
2007 KH3 Frontier NISMO 4x4 - ??? WHP / ??? WTQ
(6 spd - daily driver)
Disappointment is par for the course when modifying a Maxima.
98SEBlackMax is offline   Reply With Quote
Old 07-12-2007, 10:50 AM   #42
3.5 in the works
DandyMax's Avatar
Send a message via AIM to DandyMax Send a message via MSN to DandyMax
I have always just had the paper print out and did not know you could get an electronic file, but I will have them email it to me.
Thanks I got the fax... will you be getting run files or should I post one of the fax?
In the mean time, could you post the complete mod list here for clarity's sake? This VQ30 is in a 350Z (w/ 6-spd)?
So far you've mentioned:
VQ30
Nismo heads with S-2 cams
3.5 IM w/ PF TB (is the mani modified ie no shelf/power valve or is it a 350Z mani?)
Motec
Headers (which ones?)
__________________
2000. 3L. 5-spd. Black on black. SE. (DD)
1998. 3L. 5-spd. Sterling Mist. SE. (fun car)
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
DandyMax is offline   Reply With Quote
Old 07-12-2007, 08:25 PM   #43
Send a message via AIM to 98MaXeDouT
subscribed for runfiles...
98MaXeDouT is offline   Reply With Quote
Old 07-16-2007, 06:21 AM   #44
Sorry I'm so late getting back, I was at a race in Spokane and just got back. If you can post the faxes, that would be great, go ahead. I am jammed up at work since taking a couple of days off and need to get with the dyno guy to get to the files. The VQ30 has the following:
VQ30 short block with ARP rod bolts
Nismo heads
Stock 3.5 intake and injectors
Pathfinder TB
Cold air inlet from 350Z
Motec ecu running MAP
Jerico four speed
Quartermaster 5.25" clutch
This is in a tube frame chassis with a weight of 2280# with a fiberglass shell of a 350Z
Niz-Dat is offline   Reply With Quote
Old 07-19-2007, 04:02 PM   #45
3.5 in the works
DandyMax's Avatar
Sorry it took me a while but here are a couple of the dynojet printouts he faxed me:
__________________
Best 60': 1.73
Old 07-19-2007, 04:25 PM   #46
I see what you did there
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Not too much under the curve there. Another case where peak #'s aren't all they're made out to be.
Strange that power falls of toward 7k or so. So, this is re: thread title
That'd be damn sweet on the highway though.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
Quote:
It's like killing ants with a rocket launcher ....
NmexMAX is online now   Reply With Quote
Old 07-19-2007, 09:58 PM   #47
6yrs old=36,500 miles :)
harmbone2k2's Avatar
[quote=NmexMAX]On Dynojets:
96sleeper @ 273
SR20DEN @ 265
ULISES @ 252
ALLBlackMAX @ 248
And there are a good handful in the low/mid 240's.
I am hurt that no one put me in that category
That's ok. I will be gaining more ground soon after the SSIM is finished this fall.
harmbone2k2 is offline   Reply With Quote
Old 07-19-2007, 11:32 PM   #48
Toolie
knight_yyz's Avatar
i'm getting there too, next mod custom phenolic spacers
__________________
6MT | 06HLSD | I/H/E & FC | Stillen FSTB & RSB | Eibach Pro Kit | Illuminas | Watkins STS | UDP | NWP Spacers | Greddy Blue | ES Bushings
sig courtesy of rochester
253.50 fwhp
249.75 lb/ft tq
14.3 @ 101mph (street tires, bad wheel bearing and a few spun tranny bearings)
knight_yyz is offline   Reply With Quote
Old 07-20-2007, 05:01 AM   #49
VQ Wizard
SR20DEN's Avatar
Send a message via AIM to SR20DEN
6400rpm seems really low for 2988cc to throw down 260whp.
This requires some microscope study.
SR20DEN is offline   Reply With Quote
Old 07-20-2007, 06:20 AM   #50
NmexMAX's Avatar
Both of you realize that when I posted those #'s, neither you 2 (knight) had dynod yet
Quote:
Custom? Not Aarons?
__________________
Old 07-20-2007, 06:25 AM   #51
I am aware of that NmexMAX, I was joking around.
Old 07-20-2007, 08:04 AM   #52
Super Moderator
Send a message via AIM to nismology
I'm more interested in what exactly he had to do to get a VQ30 to work in a RWD configuration than those numbers.
But on another note, whudafxup with the torque curving back up after 6500 RPM?
nismology is offline   Reply With Quote
Old 07-20-2007, 08:07 AM   #53
NmexMAX's Avatar
Quote:
Those are 2 hp curves. I had the same brain lapse.
2 hp curves, 2 torque curves, both sets on different sheets. No one sheet has hp/tq. Look at the readout, Max power...Max power.
__________________
Old 07-20-2007, 08:11 AM   #54
Super Moderator
If that's the case, then are the two curves comparing?
Either way, my question still stands. In the second graph the curve does the same thing after 6500, just not as much.
Old 07-20-2007, 08:13 AM   #55
NmexMAX's Avatar
Nearly 3 months of difference?
It does look fishy though.
__________________
Old 07-20-2007, 08:30 AM   #56
Toolie
knight_yyz's Avatar
[quote=
Custom? Not Aarons?[/QUOTE]
Why pay someone to do something you can do yourself? I get the phenolic for free from work. Mine won't be as pretty as Aaron's but they will still work just as well. And I have a lot more room between the upper manifold and the FSTB than most people so I will make mine thicker.
__________________
253.50 fwhp
249.75 lb/ft tq
Old 07-20-2007, 02:11 PM   #57
[quote=nismology]I'm more interested in what exactly he had to do to get a VQ30 to work in a RWD configuration than those numbers.
I will try to get a couple of shots of my set up. It uses a pathfinder bellhousing that bolts to a plate at the firewall and the bellhousing is bored out to fit the snout of the jerico tranny. I also used a pathfinder oil pan because I needed the clearance at the front of the motor. I cannot describe what had to be done to fit this in the frame so I will try to get some pictures. This was a fabricator's dream or nightmare depending on your point of view.
Old 07-24-2007, 04:13 PM   #58
256whp/ 250wtq. with 19's on
Hopefully i'll be push mid 260's + next time
Jay_pee99 is offline   Reply With Quote
Old 07-24-2007, 04:43 PM   #59
NmexMAX's Avatar
Any runfiles to go with that? ^^
Old 07-26-2007, 12:53 PM   #60
brotherhood of tq
liqidvenom's Avatar
Send a message via AIM to liqidvenom
subscribing to see what he did to get so much out of that 3.0
liqidvenom is offline   Reply With Quote
Old 07-26-2007, 02:41 PM   #61
posting photos?
I have some photos of the VQ 30 but it looks like you can not post attachments. How does everyone post their photos, Cardomain etc. ?
Old 07-26-2007, 02:52 PM   #62
NmexMAX's Avatar
Host it from photobucket/imageshack etc, then do this with th picture location, but W/O the asterisk.
[IMG] *http://forums.maxima.org/images/site/bn_left.jpg* [/IMG]
__________________
Old 07-26-2007, 02:52 PM   #63
VQ Wizard
SR20DEN's Avatar
email them to vqtech@gmail.com
I will reply with the link to your pictures.
Old 07-26-2007, 02:52 PM   #64
NmexMAX's Avatar
Or that.
Old 07-26-2007, 03:37 PM   #65
Super Moderator
Quote:
He's already posted the mod list.
Old 07-26-2007, 03:44 PM   #66
DasYears
f5 f5 f5...still no pictures!!!
Old 07-26-2007, 11:40 PM   #67
If anyone's still wondering about the two different runs, that looks like one run with the VI open and the other with it closed... crossover is even in the right place (5k).
The curve upwards at the end of the primary graph (VIAS/power rod closed) is the runners getting a "second wind" as the intake pulses are approaching the second resonant frequency of the runners. IIRC the 3.5 IM exhibits similar yet more prominent behavior, where there are two crossovers and one stage of the IM is used both in the low-mid and uber-high end of the rev range, and the secondary stage is used to fill in the valley of the primary stage in the mid-high range.
MorpheusZero is offline   Reply With Quote
Old 07-27-2007, 04:21 AM   #68
VQ Wizard
SR20DEN's Avatar
If you're talking about the Niz-Dat graphs, you're way off. He clearly said he was using a 3.5 IM. And it appears he's using a 350Z IM which has no VIAS.
I
__________________
Introducing the new 2010 6.0 liter Jacuzzi Maxima http://www.jacuzzi.com/baths/options...uzzi%20maxima#
Old 07-27-2007, 04:38 AM   #69
Super Moderator
^^ Yup. And even if he was using the FWD 3.5 IM for god-knows-what reason, it doesn't utilize dynamic supercharging like the MEVI/00VI anyway.
Old 07-27-2007, 05:52 AM   #70
Vq30 Pictures
I hope this works. There is a picture of the car, with motor in car,with custom oil pan, and a shot of the oil lines coming from the pan. The image link did not seem to show up.Try http://www.vq35de.com/Images/Niz-Dat/
Old 07-27-2007, 05:56 AM   #71
VQ Wizard
SR20DEN's Avatar
Old 07-27-2007, 05:56 AM   #72
VQ Wizard
SR20DEN's Avatar
Old 07-27-2007, 05:58 AM   #73
dyno runs
The first run is a stock VQ 30 and the second run is the VQ 30 with the Nismo heads and JWT cams with the 3.5 IM.
Old 07-27-2007, 07:39 AM   #74
3.5 in the works
DandyMax's Avatar
What do you mean by "stock" VQ30? That first run is 208 hp and 215 ft-lbs, and there's no way you'll see that at the wheels on a stock Maxima. Now I know it's in a Z but still, there's no way.
Are you referring to the engine only - ie. do you mean stock internals, but with modified intake/exhaust/drivetrain/standalone ECU etc? What were the mods on the car for those "stock" dynos? Which IM for starters...?
__________________
Best 60': 1.73
Old 07-27-2007, 08:05 AM   #75
brotherhood of tq
liqidvenom's Avatar
i think we should take it a bit easy on him....we dont want to scare him away or anything with all these questions... even though i understand how curious we all are
__________________
Slow car on 18's
Old 07-27-2007, 08:35 AM   #76
What I mean by stock is a junkyard motor from my favorite wrecking yard and bolting on headers and using a Motec ecu running MAP instead of the mass air.
I was surprised also by the numbers and wanted to see what the heads would do for a 3.0. After this season I will put these heads on a 3.5 short block I have and then run the dyno and see what it will do. I believe that there is more power in the 3.0 but I was squeezed in for some dyno time and we could only make two runs for adjusting before he had to leave.
Old 07-27-2007, 08:38 AM   #77
3.5 in the works
DandyMax's Avatar
I wasn't being harsh (does it read that way?), just asking some questions and wanting some details/clarifications. Why would that scare him off?
__________________
Best 60': 1.73
Old 07-27-2007, 08:43 AM   #78
3.5 in the works
DandyMax's Avatar
Ok, so what engine... out of which year Maxima? A DEK? Which intake manifold? Which headers (which brand name) or custom? What tranny and drivetrain? Size and weight of wheel setup? The same tranny/tiny clutch you have now with the Nismo head setup?
In your opinion, what accounts for the high TQ #? I'm not attacking you I just want to know the details, as like I said, I know the engine might be stock internally but there are other mods in the picture to get those numbers, especially the TQ.
__________________
Best 60': 1.73
Old 07-27-2007, 10:24 AM   #79
The VQ 30 that put out 208 hp is from a 95 maxima with stock intake and TB. The headers are custom by the guy that built the frame. It uses a Jerico 4 speed with a Speedway quick change rear end running 12" slicks on 15" wheels. The drive train is the same as always. I am sure the headers help the torque and I don't know if the long run from the TB to the intake on the VQ 30 with the heads helps the flow but I would say that the Motec and the ability to tune the fuel and timing is probably one of the biggest factors.
Old 07-27-2007, 10:57 AM   #80
VQ Wizard
SR20DEN's Avatar
To put it lightly, I think most of us are still struggling with those numbers with those mods. Somehow your numbers are way above the norm, and something still isn't adding up to us.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Advertising - Terms of Use - Privacy Policy - Jobs - Maxima Forums - Archive -
Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.0
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
