Go Back   Maxima Forums > Track and Tune > Dyno Discussion and Slips
Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Thread Tools Display Modes
Old 04-18-2007, 10:35 AM   #1
Carbon Fiber addict
Wizards second dyno...323 HP
Kinda dissapointed with my results.... I only gained 4hp over my last dyno a year ago. Mods since the last dyno include ceramic coated Cattman Gen 3 headers, and MEVI. I expected about a 15-20hp gain over last year. Looks like I can't go any further w/o more fuel, a tuning device, and a good tune.
I welcome your comments/suggestions. Thanks. James
323 HP, 273 TQ
Performance mods on the 99 CA 5spd:
V2 blower
3.25 pulley
FMU (8:1 disc)
T-rex aux fuel pump
Cattman Gen 3 headers (ceramic coated inside and out)
Test pipe
Cattman catback
Exedy Stage II ceramic clutch
Fidanza flywheel
14 lb Centerline rims
NGK one step colder plugs (gapped at .038)
Reclocked blower with 3" charge piping
Vortech Race BOV
MEVI is actived to open at 5100 rpms via Harlan RPM switch
No filter on blower
Other goodies..
Autometer boost gauge
Autometer fp gauge
Autometer dual intake temp gauge
Innovative Motorpsports LC-1 O2 Wideband kit with XD-16 gauge
Other info:
stock injectors
stock maf
stock ecu
After hitting the recall button on my boost gauge, it read exactly 10psi.
To see last years dyno, click here....
http://forums.maxima.org/showthread....highlight=dyno
To see pics of the dyno day event, click here......
http://forums.maxima.org/showthread.php?t=514758
__________________
My Max:
99 Maxima 5 spd SE, SC'd, MEVI, Cattman Headers, KEVLO LED tails,R34 S2000 AP1 projector retro, Brembo GT BBK, Emanage Ultimate..
The Wizard is offline   Reply With Quote
Old 04-18-2007, 11:01 AM   #2
V1SuperCharger
Stillen Maxima's Avatar
Send a message via AIM to Stillen Maxima Send a message via MSN to Stillen Maxima
Damn good numbers!
Stillen Maxima is offline   Reply With Quote
Old 04-18-2007, 11:04 AM   #3
GO TEAM GO
Kevlo911's Avatar
Going MAD LEAN up top, that might explain the low numbers. Tooooo much air and not enough fuel.
Kevlo911 is offline   Reply With Quote
Old 04-18-2007, 12:17 PM   #4
Blown
Send a message via AIM to cardana24
do you have anything to tune your air fuel? I see the red doted line is around 13:1, where I dyno that is where they normally put your target if you are N/A, but lower/richer if you are boosted. Like Kevlo said if you can add some fuel up top you may gain some good power.
*edit*, I thought you were on the same pulley as I am (3.125), but those are really good numbers for 3.25.
cardana24 is offline   Reply With Quote
Old 04-18-2007, 01:11 PM   #5
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
You need to get your AFR in line(i.e, add some fuel)
It's been noted before, but something should be done about it.
Good #'s though.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 04-18-2007, 03:15 PM   #6
96sleeper's Avatar
Send a message via AIM to 96sleeper
As others have said, you are too lean up top. You probably need Z32 MAF and injectors as well as some sort of fuel adjustment to take out the richness in the middle and fine tune the top end. Also, once you have fuel up top, take the car all the way to redline. I would think peak power would be at or near redline especially with the MEVI.
96sleeper is offline   Reply With Quote
Old 04-18-2007, 08:30 PM   #7
Send a message via AIM to MaxObesset
you runing stock injectors on you setup
MaxObesset is offline   Reply With Quote
Old 04-20-2007, 12:36 AM   #8
Carbon Fiber addict
Quote:
Yes, but not for long... just finished soldering the Z32 Maf pigtail on. On deck--> either 410 or 555cc injectors.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
