Ok, last dyno was
http://forums.maxima.org/showthread.php?t=494574. (220whp-223wtq). It was rich, had an exhaust leak at rear header. Things different with my setup from that last dyno are...
- Fixed Exhaust Leak
- Added CAI
- Added Straight Pipe
- SAFC Tuned (last time I didnt really do much tuning)
- Fuelab FPR (ebay POS unit rusted and seized at 70psi FTL, so I hammered it to peices after replacing it lol)
- PF TB with StephenMax's Adapter
- NEW Cooper NGK Spark plugs (last dyno I just cleaned up the plugs that were in and reused them)
Note- Sorry, no Run Files
This is the printout with all 4 runs on it...
Note- The 1st run did not have the sniffer hooked up, thats the blue line at 18:1.
This is the print out comparing Run01 against Run04...
For those that will ask me, even though its on the link on the top
, my mods are...
- CAI
- PF TB
- Stock 3.0 Headers+ WSP Ypipe+ WSP Straight Pipe
- MotoStorm UDP
- Fuelab FPR
- Z33 HGs
- No P/S belt (forgot to mention this on the previous thread, but it was also like this on the previous dyno, so no change)
- SAFC1-Tuned for 13.0:1 and slightly richer towards redline
- VI powerflap is running full open
My Final 2 cents...
Sure peak #s are slightly less than before, but that means nothing. A 3WHP difference can be caused by anything. Area under the curve>*. These power curves are alot more healthy-looking IMO compared to before.
Also, I used to have to empty my oil catch can pretty much every gas tank fill. Now, I finished the HG replacement just before X-Mas. Its been exactly 2 months since I finished and the catch can has not been drained ONCE. There is exactly I'd say less than 1/8 of the capacity of oil in the can for the last 2 months.
This baby is being held back so much its insane. I might just have to go all out NA (with bolt ons, no internal work other than more cam retard on intake cams with custom-speced adapters, and ARP Rod Bolts) and see how much juice I can squeeze out on stock cams and 3.0 ECU. Things such as WSP catback (still rocking the stock stuff with the nasty crimped b-pipe), SSIM, the new re-designed OBX headers, and of course, E-Manage Ultimate for ubber timing advance and extended rev limiter.
: werd
