Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
new best 3.5 dyno...273hp, 249tq all motor
Old 07-15-2006, 08:23 PM
96sleeper's Avatar
I went to dyno tonight for the heck of it. Since the last dyno I have installed a zeitronix wideband and tuned it on the street (which turned out identical when I datalogged on the dyno at 13:1) and I have also tweaked a few things in the intake tract. Still on the 02 maxima intake manifold.
Special thanks to SR20DEN for some pointers on what direction to head. Every time I dyno and see my torque below 4000rpm I wish I had done a full 3.5 swap, but I got too sweet of a deal on that engine to pass up so I went with it.
I absolutely can not wait until this fall when it cools down and I head back to the 1/4 mile track.
96sleeper is offline
Old 07-15-2006, 09:05 PM
Kevlo for President
Kevlo911's Avatar
WOW amazing numbers.
Kevlo911 is offline
Old 07-15-2006, 10:01 PM
AsthmaMax11's Avatar
Hey matt, is this a different dyno than last time?
Sick numbers man. I predict you'll be giving JIME a run for his money this year!!
AsthmaMax11 is offline
Old 07-15-2006, 11:33 PM
3.5 in the works
DandyMax's Avatar
Nice numbers. Looking forward to track results. I too cannot wait for the hot air to go away and cooler track days to come. Probably won't be anytime soon though. We're in the middle of a heat wave up here.
DandyMax is offline
Old 07-16-2006, 07:36 AM
SDot82's Avatar
I have the same heat wave coming through my area 100+ degrees.
SDot82 is offline
Old 07-16-2006, 08:05 AM
UCF Lexus
|Bijan|'s Avatar
jesus matt!
come to atl
|Bijan| is offline
Old 07-16-2006, 09:01 AM
VQ Wizard
SR20DEN's Avatar
Got the run files?
And congrats. I am probably #2 in the hp department now. Oh well.
SR20DEN is offline
Old 07-16-2006, 09:04 AM
VQ Wizard
SR20DEN's Avatar
Oh, and you can get that torque number back up by doing what I did with the ignition timing. That is if your ECU responds like mine did.
SR20DEN is offline
Old 07-16-2006, 09:15 AM
gtr_rider's Avatar
NICE numbers..
gtr_rider is offline
Silver Tooth S2K 9k FTMFW
95 maxima se's Avatar
sick numbers!!!
95 maxima se is offline
Old 07-16-2006, 09:48 AM
Father of the 00 VI
krismax's Avatar
those are def 12's kind of #'s
krismax is offline
Old 07-16-2006, 09:53 AM
3.5 in the works
DandyMax's Avatar
Run files for me too please!
DandyMax @ auracom . com (no spaces)
DandyMax is offline
Old 07-16-2006, 10:00 AM
Custom User Title
Nismo3112's Avatar
wooo!!!!! Sweet jesus
Nismo3112 is offline
Old 07-16-2006, 12:55 PM
96sleeper's Avatar
I should have the run files on Monday. I left and forgot a disk again as usual, but he promised to email them to me.
Old 07-16-2006, 12:56 PM
96sleeper's Avatar
Originally Posted by SR20DEN
Got the run files?
As soon as you add cams, it will be over for everyone else.
Old 07-16-2006, 04:32 PM
fwd gone rwd cr00
tavarish's Avatar
yeah, this engine without vtc's is a drag lower than 4500rpms. The big question I have for you is: do you have aftermarket rod bolts for the extended rev you have?
tavarish is offline
Old 07-16-2006, 05:18 PM
96sleeper's Avatar
Stock rod bolts. I am only running to 7000 rpm. Technosquare flashes the 350z ecu's to 7100 rpm on stock rod bolts, so I concluded that I would be fine.
Old 07-16-2006, 05:25 PM
Bacon Lover
Tatanko's Avatar
Good job on a new record
I only wish I had a 3.5 Oh well...
Tatanko is offline
Old 07-16-2006, 06:31 PM
Made in Taiwan
GodFather's Avatar
Hot dang! Nice hp+tq curvature you've got there. Man, so your power/rpm is like a 3 stage hauler. 200, 250, and 270. Nice...
GodFather is offline
Old 07-16-2006, 08:18 PM
fwd gone rwd cr00
tavarish's Avatar
i'd go with arp rod bolts for added security. the 3.5 stock rod bolts aren't the best.
I can't wait to tune my car. it's running uber rich.
tavarish is offline
Old 07-16-2006, 08:42 PM
nismology's Avatar
There's nothing wrong with the stock rod bolts unless you want to rev in the 7200-7500 RPM range.
nismology is offline
Old 07-17-2006, 05:47 AM
dot dot dot ...
NmexMAX's Avatar
Very nice #'s....
Sleeper FTW.
Also interested in the run files.
NmexMAX is offline
Old 07-17-2006, 07:34 AM
ajcool2's Avatar
WOW. Congrats. I really need to step my game up.
ajcool2 is offline
Old 07-17-2006, 08:27 AM
mforrest100's Avatar
I remember Matt said this before. Not really necessary to rev above 7000 which evident in his dyno graph seeing how the power starts to drop off after 6500 RPM's.
mforrest100 is offline
Old 07-17-2006, 09:58 AM
virgilio7's Avatar
^ the power at 7000 is higher than it is at 5000. you land next gear higher in the powerband.
virgilio7 is offline
Old 07-17-2006, 02:05 PM
Z
NYPD-Arnold's Avatar
Ehh...not quite correct. Instead of shifting into a weaker powerband, he'll be shifting into a higher RPM range and thus into a much stronger powerband.
NYPD-Arnold is offline
Old 07-18-2006, 06:18 AM
VQ Wizard
SR20DEN's Avatar
I am going to try, but I don't think I will be able to beat you now without them.
SR20DEN is offline
Old 07-21-2006, 07:16 PM
A Canadian using the expression "heat wave"
A heat wave in Canada is like a cold winter breeze in Atlanta
Old 07-21-2006, 08:07 PM
motocross416's Avatar
I'm at about the similar type of climate as dandymax, the heat waves we get are 90 degrees with 99 percent humidity, aka, severly down on power
motocross416 is offline
Old 07-21-2006, 08:40 PM
vsamoylov
not bad at all
Old 07-22-2006, 02:56 PM
GoalieKeg's Avatar
You and me both.
GoalieKeg is offline
Old 07-22-2006, 04:38 PM
Hoooper
not so much. i was just up in ontario and the temp was 103 with a humidity around 70-90, i dont remember.
as for the OP, those are some pretty great numbers, i wish i was 30hp short
Old 07-22-2006, 10:47 PM
brotherhood of tq
liqidvenom's Avatar
very nice numbers....
liqidvenom is offline
Old 07-25-2006, 08:19 PM
Wat
E55AMG2's Avatar
Runfiles plz
E55AMG2 is offline
Old 07-26-2006, 06:23 AM
virgilio7's Avatar
what tweaks and mods you have? the list on your car domain only shows bolt ons like cutout headers and intake.
Old 07-26-2006, 04:19 PM
csb
csb's Avatar
Hey...SR20DEN...I just tried to PM you, but it says you can't accept any more messages due to a full Inbox. So:
"Hello. I'm not quite finished with my 3.5 swap, however, I'd like to be prepared for the tuning process. The car SHOULD be up and running within 1.5 weeks. Which product should I purchase as a "piggyback"? I was considering the E-Manage Ultimate. I'll probably need your assistance when the time comes, OK? Thx."
csb is offline
Old 07-26-2006, 04:40 PM
96sleeper's Avatar
page 3 of my cardomain shound have the latest list.
Old 07-27-2006, 08:55 AM
SonicDust187's Avatar
Can you tell me what your idle is set to and does it have a loppy idle?
SonicDust187 is offline
Old 07-27-2006, 11:18 AM
3.5 in the works
DandyMax's Avatar
Thankyou! Why do people think Canada is all snow and ice? Nothing could be further from the truth.
DandyMax is offline
Old 07-30-2006, 04:29 PM
Hoooper
lol, def no ice there. and i was pretty far north
Quick Reply: new best 3.5 dyno...273hp, 249tq all motor
