Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Powerloss due to rotational weight and stuff
Old 09-21-2004, 05:46 PM
SLC I30t's Avatar
Ok I have a question.
How much power am I losing by inceasing my wheel weight by 4lbs per wheel?
My new rims are lighter but the rubber is heavier, so my OEM wheel set up is 32lbs with rubber and the OZ rim with rubber is 36lbs. Is there any way to figure out what kind of powerloss I'm experiencing.
SLC I30t is offline
Old 09-22-2004, 01:46 PM
Pimpmobile's Avatar
another thing to factor in is the distance from the hub the weight is. Its easyer for a mass closer to the center to spin than one that is further away from the axis. ie, bigger wheels are that much worse compared to a smaller wheel of the same weight
i think
Pimpmobile is offline
Old 09-23-2004, 10:01 AM
SLC I30t's Avatar
there is a mathematical equation to figure out the power loss.
SLC I30t is offline
Old 09-23-2004, 11:24 PM
My Maxima thinks your Maxima is HOT!
Jumbo™'s Avatar
Is this what you're looking for?
Formulas for tire size & their effect
effective ratio = (old tire diameter / new tire diameter) x original ratio
actual mph = (new tire diameter / old tire diameter) x actual mph
But I think this is what you are looking for, check the bottom of the page:
http://www.pumaracing.co.uk/flywheel.htm
Jumbo™ is offline
Old 09-28-2004, 12:44 PM
SLC I30t's Avatar
ummm errr I'll have to work that one out.
I just remember an equation to figure it out... it came out to something like 1lb of rotational weight equaled like 90lbs of unsprung weight. something wierd like that...
SLC I30t is offline
Old 09-28-2004, 04:34 PM
VQ30DES's Avatar
i believe it was for every 1lb it was 8lb's of "dead" weight. so if it is a 4lbs difference in each wheel, it is equal to 128lbs of dead weight.
VQ30DES is offline
litch
123
01-04-2024 07:01 PM
hcarter1112
42
07-18-2022 03:35 PM
mclasser
22
11-12-2020 01:58 PM
04-16-2020 05:15 AM
Quick Reply: Powerloss due to rotational weight and stuff
