Go Back   Maxima Forums > Regional Maxima Groups > Canada > Canadian Classifieds
Thread Tools Display Modes
Old 06-30-2008, 02:34 PM   #1
No longer a maxima owner.
kingrukus's Avatar
FS: Eclipse Subwoofers, Eclipse Speakers, Kicker 4 channel Amp
Eclipse SW6124BXD Dual Enclosure with two 12" Subwoofers
ECLIPSE subwoofer systems are constructed from sturdy wood, carefully assembled and well-damped for a tight bass. Finished in attractive and durable vinyl, these subwoofer systems are ready for final installation.
This unit was used for about 3 months, and is in great condition
  • 2 x 12" Subwoofer System
  • RMS power handling: 500W
  • Max. power handling: 1000W
  • Includes brand new subwoofer grilles
  • Single 4ohm terminal
  • Subwoofer Driver SW6124 × 2
  • Frequency Response 28 — 250Hz
  • Sensitivity 1W/m SPL 88dB
  • Normal Impedance 8ohm + 8ohm Parallel = 4ohm
  • Dimensions (W × H × D) 27.6? × 13.8? × 15.3? (701 × 350 × 389mm)
  • Finish Grey & Black Vinyl
Asking $350.00
Eclipse SE8365 6-1/2" 3-Way Car Speaker
The SE8365 6-1/2" speakers sport rigid mica polypropylene woofers that offer full, punchy bass, while butyl rubber surrounds keep cone movement smooth and accurate for greater sound clarity. Dome tweeters broadcast superior high-frequency response so
Speakers are in excellent condition, used for only 2 months.
  • 6-1/2"/ 6-3/4" 3-way car speakers (pair)
  • hybrid mica polypropylene woofer with butyl rubber surround
  • Kapton voice coil former
  • 3/4" PEI dome tweeter
  • Neodymium tweeter magnet
  • tweeter protection device
  • 3/4" Mylar dome supertweeter
  • power range: 2-40 watts RMS (120 watts peak power)
  • frequency response: 90-40,000 Hz
  • sensitivity: 90 dB
  • top-mount depth: 1-15/16"
Asking $65
__________________
Current:
G35 M6 Coupe
Previous:
5th gen Maxima SE 4AT
4th gen Maxima GXE 5MT
5th gen Civic CX 5MT
kingrukus is offline   Reply With Quote
Old 06-30-2008, 02:35 PM   #2
kingrukus's Avatar
Eclipse SE8355 5-1/2" 3-Way Car Speaker
The SE8355 5-1/4" speakers sport rigid mica polypropylene woofers that offer a full, punchy sound, while butyl rubber surrounds keep cone movement smooth and accurate for greater sound clarity.
Speakers are in good condition, used for 5 months.
  • 5-1/4" 3-way car speakers (pair)
  • power range: 2-30 watts RMS (90 watts peak power)
  • sensitivity: 89 dB
  • top-mount depth: 1-7/8"
One of the speakers has a bit of a scratch in the bottom of the cone, this does not affect the sound at all:
Asking $60
Kicker ZX350.4 4 Channel Amplifier
If you're into great sound, you'll love Kicker's ZX series amplifiers. These high-end amps set the standard for powerful sound, with a distinctive look that'll make your installation stand apart from the crowd.
The built-in variable frequency filters adjust the amp's output to get the most out of your speaker setup, whether you're running full-range speakers or subs. Use the bass boost control to dial in the exact amount of low-end bump you're looking for.
  • like NEW, IN EXCELLENT CONDITION!!!
  • 4-channel car amplifier
  • 60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
  • 175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
  • variable high- and low-pass filters (50-200 Hz, 12 dB per octave)
  • variable bass boost (0-18 dB at 40 Hz)
  • top-mounted controls
  • speaker- and preamp-level inputs
  • fuse rating: 20A x 2
  • 13-1/2"W x 2-5/16"H x 9-5/8"D
Asking $225.00
Local pickup in the GTA preferred (I am in the west end, Mississauga/Brampton area).
Please e-mail me at paradigm905@hotmail.com or PM me if interested.
__________________
Current:
G35 M6 Coupe
Previous:
Old 07-08-2008, 02:33 PM   #3
kingrukus's Avatar
Kicker ZX350.4 4 Channel Amplifier Sold. Everything else available.
__________________
Current:
G35 M6 Coupe
Previous:
Old 07-28-2008, 02:04 PM   #4
kingrukus's Avatar
Eclipse SE8365 6-1/2" 3-Way Car Speakers sold.
Subwoofers and 5.25" speakers still available.
__________________
Current:
G35 M6 Coupe
Previous:
Old 08-12-2008, 11:27 PM   #5
kingrukus's Avatar
Eclipse SW6124BXD Dual Enclosure with two 12" Subwoofers sold
Eclipse SE8355 5-1/2" 3-Way Car Speaker still available.
__________________
Current:
G35 M6 Coupe
Previous:
Old 08-15-2008, 08:51 AM   #6
kingrukus's Avatar
Eclipse SE8355 5-1/2" 3-Way Car Speaker Sold
__________________
Current:
G35 M6 Coupe
Previous:
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
