Go Back   Maxima Forums > Regional Maxima Groups > Canada > Canadian Classifieds
Thread Tools Display Modes
Old 01-14-2008, 11:43 PM   #1
No longer a maxima owner.
kingrukus's Avatar
FS: Kicker KX350.4 4 Channel Amp, Kicker Dual 12 Sub System, 6.5" Components
Kicker KX350.4 4 Channel Amplifier
This 4-channel workhorse is packed with the features you need, and you can trust that the CEA-2006 compliant power rating reflects a true measure of the amp's capabilities. Kicker's SORT protection circuitry safeguards against damage from short circuits, overvoltage, reverse voltage, or thermal overloads.
Variable filters may be set for high-pass, low-pass, or full-range operation so you can use the amp for different applications. Feel the need for some thump? The KickBass control lets you kick in up to 18 dB of bass boost at 40Hz.
  • Used for 6 months
  • a few scratches, but in overall excellent condition
  • 4-channel car amplifier
  • 60 watts RMS x 4 at 4 ohms (90 watts RMS x 4 at 2 ohms)
  • 175 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
  • variable high-pass/low-pass filters (50-200 Hz, 12 dB/octave)
  • variable bass boost (0-18 dB at 40 Hz) with wired remote level control
  • speaker- and preamp-level inputs
  • Tri-way capable (Tri-Way Crossover required)
  • fuse rating: 20A x 2
  • 8-gauge power and ground leads recommended
  • 15-3/4"W x 2-9/16"H x 9-15/16"D
Asking $150.00
LIKE NEW Kicker 05DC122 Vented enclosure with dual 12" Comp subwoofers
This subwoofer system was used for 2 weeks and is in excellent condition, basically like new. It hits very hard, and is built very well, with two reliable Kicker Comp subwoofers in a well crafted Kicker built-to-spec vented enclosure.
  • ported hatchback-style enclosure with two 12" Kicker Comp subwoofers
  • 3/4" medium density fiberboard construction covered with gray and black carpet
  • 2-ohm total impedance
  • power handling: 300 watts RMS (600 watts peak power)
  • frequency response: 20-200 Hz
  • sensitivity: 99.9 dB
  • 32-1/4"W x 16-1/6"H x 17-1/4"D1 x 14"D2
Asking $275.00
LIKE NEW - Kicker KS6.2 6-1/2" component speaker system
The Kicker KS6.2 component speaker system renders the low frequencies with light, yet rigid 6-1/2" woofers, suspended in vibration-dampening rubber surrounds. Sturdy steel baskets provide a solid housing with plenty of venting to keep internal parts cool.
Aluminum dome tweeters project the highs with authority, slicing through road noise to ensure lifelike stereo imaging. External 2-way crossovers provide a seamless transition between the woofers and tweeters — you'll revel in detailed, realistic sound when you play your favorite tracks.
The versatile KS6.2 system includes mounting hardware for a variety of tweeter mounting options, or you can install the tweeters inside the woofers to create high performance 2-way speakers.
  • Mid bass drivers used for 1 week, the rest of the items are BRAND NEW IN PACKAGE, NEVER USED!
  • component speaker system includes woofers, tweeters, and crossovers
  • 6-1/2" polygraphite woofer with Santoprene surround
  • 1" aluminum dome tweeter with multiple mounting options
  • tweeter may be mounted on woofer as a high-performance coaxial speaker
  • external 2-way crossover (4000 Hz, 12 dB/octave high-pass, 6 dB/octave low-pass)
  • marine ready with water-resistant mounting hardware
  • power range: 6-75 watts RMS (150 watts peak power)
  • frequency response: 35-21,000 Hz
  • sensitivity: 88 dB
  • top-mount depth: 1-15/16"
Asking $150.00
Local pickup in the GTA preferred (I am in the west end, Mississauga/Brampton area).
Please e-mail me at paradigm905@hotmail.com or PM me if interested.
__________________
Current:
G35 M6 Coupe
Previous:
5th gen Maxima SE 4AT
4th gen Maxima GXE 5MT
5th gen Civic CX 5MT
kingrukus is offline   Reply With Quote
Old 01-17-2008, 08:32 PM   #2
kingrukus's Avatar
Kicker KX350.4 4 Channel Amplifier & Kicker KS6.2 6-1/2" component speaker system sold.
Kicker 05DC122 Vented enclosure with dual 12" Comp subwoofers still available.
__________________
Current:
G35 M6 Coupe
Previous:
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
