Go Back   Maxima Forums > Track and Tune > Autocrossing and Road Course Racing
Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-22-2008, 12:49 PM   #1
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
Took the max to the road course for the first time since '04
I signed up for a two day event at Gingerman Raceway and then had a mad rush to get the max ready for the event. I haven't driven on a road course since 2004 I think, so I needed to get back in the groove. I forgot how fun it is. Saturday was rainy all day and I only went out for one session - wasn't terribly fun running a 3/10ths and still feeling like I was on pins and needles trying to keep the car under control.
Sunday though dried out and I got back at it, and had a blast. The basic setup of the car is:
95 SE 5spd
3.5 swap w/ 4th gen intake manifold (no power above 5300ish) and 4th gen timing
Quaife limited slip diff
PPG 3rd and 4th straight cut gears, shot peened
Shot peened, detailed and deburred 1st through 5th gears
Oscars Radiators 1.5" all aluminum radiator
short ram intake/Ypipe/3" exhaust
K-sport coilovers
generic front strut bar
Cattman rear sway bar
J30 calipers front
z32 rotors front
Goodridge SS brake lines
Carbotech XP8 pads in front
Hawk HPS rear pads
17x7.5" SSR Competitions
Kumho MX tires in front (245-45-17)
Hankook RS2 tires rear (245-45-17)
PLX Devices DM100/SM-AFR/SM-Fluid temp gauges (oil temp and water temp)
I was pretty happy with my performance and that of the car. The Quaife limited slip is pretty awesome - you can get on the power so early coming out of the corner it's incredible. The 3.5 has good grunt and this track can be run in 3rd gear the entire time with the power level I am running. I could have shifted into 4th in the straights and 2nd in the corners but after a session of trying that, I decided to save the wear on the trans and keep the car in 3rd the whole time and just concentrate on running the proper line and hitting my braking points.
This brake setup never missed a beat, pedal feel was consistent and solid the entire time, what it really boils down to is I had way more braking power than traction, so the brakes were not even close to being pushed to their limit.
I started out in Intermediate II (the higher of the intermediate classes) because I hadn't been on a road course in 4 years. I ran a couple sessions in Int II and was running over everyone so I moved up to Advanced I (the lower of the advanced classes) in which the split is about 50-50 cars on R compounds vs cars on street tires. I was middle of the pack in Advanced I.
Handling of the max was interesting - you can tell it doesn't handle or grip as well as the smaller/lighter cars but for the most part I was making up for the handling deficiencies under braking and somewhat under acceleration as well. I'd say braking was my biggest advantage over most cars out there and truthfully, I wasn't really braking at 10/10ths. I picked braking points and pretty much stuck with them even though as the day wore on I sincerely felt I could take it another 50-75 feet into the corners on the ends of the two straights before really getting on the binders.
My coolant temps were rock solid 195 degrees the entire time out there (temps were high 70s low 80s). Oil temp was a little on the high side, 260-270 degrees. Not out of this world high but high enough that I'm going to run an oil cooler before the next time i run out there (next time I'm out there I'll probably be turbocharged anyway, in which case I'll obviously need an oil cooler). Power steering never boiled and neither did the Valvoline SynPower brake fluid.
I've got in car video from each of my sessions that I'll post up eventually, and I've found a few pictures that different people have posted from the event that have my car in them, so I'll post those as well. Should have some external video of my car available pretty soon too.
Credit for these photos goes to Lovefab, briangaudy, cleanblackZ, etc. None of these were taken by me.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 07-22-2008, 01:19 PM   #2
SLOW
Nealoc187's Avatar
__________________
Old 07-22-2008, 01:21 PM   #3
SLOW
Nealoc187's Avatar
__________________
Old 07-22-2008, 01:23 PM   #4
SLOW
Nealoc187's Avatar
__________________
Old 07-22-2008, 02:07 PM   #5
khantalha+'s Avatar
Send a message via MSN to khantalha+ Send a message via Yahoo to khantalha+
offcourse u couldnt take the pics...
always good to hear from you neal... great work
__________________
95 SE (VQ35DE EATER) - 96 GXE (Weekend Fun) - 98 GXE (Daily Driver/Grocery Getter) = sold
Quote:
Originally Posted by irish44j View Post
khantalha, in case you didn't see my other post - your signature is not appropriate for this forum and needs to be deleted. Please take care of it...
Lots of NEW/USED 4th Gen Parts , Click here, if dont see what ur looking for then PM me...
khantalha+ is offline   Reply With Quote
Old 07-22-2008, 03:30 PM   #6
Slow Azz 4th Gen Driver
il99max's Avatar
Hey Neal. Glad to hear you got the car together and got to have some fun on the road coarse. Now get the rest of the engine finished already!!
il99max is offline   Reply With Quote
Old 07-22-2008, 06:06 PM   #7
Send a message via AIM to maxmaxima91
Dude.. whats that third gen doing in front of you... ROFL
__________________
12.8 @ 114 mph 14 PSI
maxmaxima91 is offline   Reply With Quote
Old 07-23-2008, 09:35 AM   #8
Send a message via AIM to QNO_A32
good job holding it down in adv 1
__________________
I LOVE WEED CREW MEMBER #1
QNO_A32 is offline   Reply With Quote
Old 07-23-2008, 04:21 PM   #9
great job neal and jeremy! that must have been a blast! looks awesome!
jeremy.... you got your car finished and up and running already?
__________________
Current Mods: 3.5 Swap, EU, Full exhaust
Track Times:
Nitrous,00vi,slicks
60' 1.86
330' 5.4
1/8th 8.4 @ 83
1000' 10.9
1/4 13.1 @ 104
3.5 Swap with street tires
60' 2.11
330' 5.77
1/8th 8.79 @ 83.23
1000' 11.19 @ 95.06
one_fast_max is offline   Reply With Quote
Old 07-23-2008, 04:55 PM   #10
Beater
Tatanko's Avatar
Send a message via AIM to Tatanko
Looks like a ton of fun! Way to show 'em how it's done in an A32
__________________
SHIFT_obsession
Tatanko's Maxima Site & VQ35DE.com
Tatanko is online now   Reply With Quote
Old 07-23-2008, 06:21 PM   #11
Send a message via AIM to G4nismo
he should stick one of these on the back. newb lol
__________________
03 Z33 Brickyard touring coupe 6spd
97 Maxima - Sold
Quote:
Originally Posted by 35oZephyR View Post
My350z = General Car Enthusiast Forum (sprinkled in with a little Z douchebaggery)
G4nismo is offline   Reply With Quote
Old 07-23-2008, 09:28 PM   #12
Send a message via AIM to Drockb418
nice pics
__________________
1998 318 ti,s50 swap, m3 brakes, green house control arm bushings,H&R race springs with bilstein struts,ASA wheels,Magnaflow catback ,sparco seats,two 10” JL audio subs,3.73 rear end,euro headlights and more to come![/center]
Drockb418 is offline   Reply With Quote
Old 07-23-2008, 09:48 PM   #13
O yea.. with 2 days to spare.
__________________
Old 07-23-2008, 10:27 PM   #14
no wonder you never replied to my emails! ....you were too busy getting the car ready!! ....haha
were you happy with the turbo setup??
__________________
Track Times:
Nitrous,00vi,slicks
60' 1.86
330' 5.4
1/8th 8.4 @ 83
1000' 10.9
1/4 13.1 @ 104
60' 2.11
330' 5.77
1/8th 8.79 @ 83.23
1000' 11.19 @ 95.06
Old 07-24-2008, 08:22 AM   #15
Ive got a few kinks to work out but overall so far so good. 14 psi on this setup feels similar to what 16-17 psi did on the other setup. o yea,.. sorry about the emails.. ill work on that
Jeremy
__________________
Old 07-24-2008, 08:48 AM   #16
Wild for Width
Fr33way™'s Avatar
Send a message via AIM to Fr33way™
Awesome. Glad to hear the J30 setup standing up to RC duty, should get more interesting (for everyone) when you run some boost through the 3.5.
__________________
Fr33way™ is offline   Reply With Quote
Old 07-24-2008, 09:02 AM   #17
192.168.1.1
gtr_rider's Avatar
Good to see the cars out of the woodworks again
__________________
VQpower.com
Need work done:
Suspension, Engine, Brakes, Cosmetic, Headlight Retrofits
gtr_rider is offline   Reply With Quote
Old 07-24-2008, 10:26 AM   #18
ah its all good jeremy! just messing with ya
great job on the car! i want to make a trip up there sometime to see it. might be a christmas break thing or something...we'll see how it goes. i need a turbo setup possibly
Neal what place did you come in?
__________________
Track Times:
Nitrous,00vi,slicks
60' 1.86
330' 5.4
1/8th 8.4 @ 83
1000' 10.9
1/4 13.1 @ 104
60' 2.11
330' 5.77
1/8th 8.79 @ 83.23
1000' 11.19 @ 95.06
Old 07-24-2008, 10:51 PM   #19
NICE.
I have been wanting to run a track day for quite awhile but I was afraid my brakes are inadequate (stock except for HPS up front) and it would wear the hell out of my tires.
Congratulations on the track day man, I hope to see some more from you. One more thing, why'd you go with the USIM instead of the 3.5 IM?
MorpheusZero is offline   Reply With Quote
Old 07-24-2008, 11:11 PM   #20
the reason neal used the USIM was due to time. he needed to get the car going so he didn't mess with the time consuming job of getting the 3.5 IM on, he was working in a friends place and needed to get it going. he has other plans anyways
__________________
Track Times:
Nitrous,00vi,slicks
60' 1.86
330' 5.4
1/8th 8.4 @ 83
1000' 10.9
1/4 13.1 @ 104
60' 2.11
330' 5.77
1/8th 8.79 @ 83.23
1000' 11.19 @ 95.06
Old 07-27-2008, 10:38 PM   #21
SLOW
Nealoc187's Avatar
Exactly as kevin said, I just ran out of time to do the swap and doing the USIM was less time consuming. I've got both a DEK and 3.5 IM sitting in the trunk of my beater and I'm going to throw one (or both, and do a dyno comparison maybe) on my car one of these days. Just hasn't been a priority.
Kevin - it wasn't a real race it was just hot lapping which is basically just for fun. There is no official timing.
Morpheus you are right those brakes would not hold up. Back when my other max was stock (except for ground control coilovers) HPS pads and stock rotors were not sufficient. You would need better pads and it'd be wise to run a heavier rotor as well (more mass to absorb heat).
__________________
Old 07-28-2008, 12:22 AM   #22
ah ok. well that is awesome! i wish there was more of that kind of stuff around here! haha. i would for sure go try that out!
__________________
Track Times:
Nitrous,00vi,slicks
60' 1.86
330' 5.4
1/8th 8.4 @ 83
1000' 10.9
1/4 13.1 @ 104
60' 2.11
330' 5.77
1/8th 8.79 @ 83.23
1000' 11.19 @ 95.06
Old 07-28-2008, 02:18 PM   #23
Quote:
Haven't we done that already? 3.5IM > 00VI for the 3.5, not only does the 3.5IM flow better but the ports of the 3.5 heads and the 00VI don't match up IIRC.
Yeah, I was looking at Z32 fronts with milled rotors and some better pads. I flogged the max hard up and down a mountain road recently and I did witness the beginning of fade so I backed off, but I also noticed that HPS were worlds better than stock pads and did hold up to a fair share of abuse. Obviously a 60-20mph mostly second gear mountain road isn't going to compare to consistent threshold braking from 100mph/third gear road course.
How'd your pads look afterwards, notice some taper or were they ok?
Old 07-28-2008, 03:31 PM   #24
SLOW
Nealoc187's Avatar
Who tested that? I'm not aware of any such test, certainly not on a 3.5 with proper matching of the 3.5 LIM to the 00vi (which is what I'd be doing). Dandymax's 270whp and still climbing at 7500rpm all motor dyno would indicate to me that a 3.5L intake manifold is not capable of as much airflow as the 3.5L IMs which peak at like 6100 and then start to fall (96sleeper's cammed 3.5 dyno for instance). If there has been such a test I'd like to see it so I can re-sell this DEK manifold I just bought and not waste the time putting it on.
The pads are perfectly fine. I don't know what you mean by taper - they are worn perfectly even across the surface if that's what you are asking. They probably have 5-6 more lapping days of similar intensity left in them, based upon how much they were worn down from this one.
__________________
Old 07-28-2008, 05:10 PM   #25
I can't remember who, when or where--I could be wrong. Maybe they were referring to an 00vi lower IM as well in the 00vi setup.
Pad taper is exactly what it sounds like--something I have heard of happening when you beat the piss out of a street pad. The leading edge of the pad tapers off.
So you're running the entire Z32 front setup then? Milled rotors et al?
Old 07-28-2008, 09:46 PM   #26
SLOW
Nealoc187's Avatar
I think tilleys99 had a DEK mani on his 3.5 but didn't have an adaptor and thus was still dealing with the mismatched ports. Other than that I can't think of anyone who's tried it.
No the pads look perfectly normal. I've never had anything weird happen with my pads from HPS to HP+ to HP+ with 13" cobra rotors to this setup all run on road course. These pads are certainly not a street pad by any stretch of the imagination. Carbotech is very adamant about that.
__________________
Old 07-29-2008, 01:20 AM   #27
3.5 in the works
DandyMax's Avatar
Send a message via AIM to DandyMax Send a message via MSN to DandyMax
Glad you had fun out on the road course Neal!
As far as all the 3.5 manifold dynos peaking too early... I'm not sure it's just the manifold... one has to consider cam timing and cam specs also plus header design...
However that 00VI does flow very nicely when matched with a proper intake/TB/valvetrain/headers etc. It's true my dyno was still climbing slightly, as my cam timing was set to give me a peak at 7700 or so for an 8200 limit (presuming the bottom end would hold up, which was proven not to), but I wouldn't have gained a whole lot more by 7700, a couple whp maybe. So the timing was pretty much set optimally.
__________________
2000. 3L. 5-spd. Black on black. SE. (DD)
1998. 3L. 5-spd. Sterling Mist. SE. (fun car)
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
DandyMax is offline   Reply With Quote
Old 07-29-2008, 04:30 PM   #28
Seems like sum1 had lots of fun.Looking good man.Where are you spin-out pics.?
__________________
FOR SALE
97-99 Headlights $100 shipped obo
Snypa is offline   Reply With Quote
Old 07-29-2008, 08:09 PM   #29
Hes running the J30 brake upgrade, using j30 rotors, j30 calipers, slightly moded Maxima torque members, and maxima pads. This way you can have Full rotor diameter.
__________________
Old 08-24-2008, 01:47 PM   #30
Still waiting on that video....
Old 08-24-2008, 09:26 PM   #31
yea neal
__________________
Old 08-27-2008, 03:26 AM   #32
ZHP
4DRSpeed's Avatar
Send a message via AIM to 4DRSpeed
looks like a ton of fun.
that viper is the tits!
__________________
'96 Nissan Maxima SE 5-SPD - Ruby Pearl/BLK Leather
4DRSpeed.com - It's coming!
4DRSpeed is offline   Reply With Quote
Old 08-28-2008, 07:13 PM   #33
Old 09-04-2008, 08:35 AM   #34
SLOW
Nealoc187's Avatar
me too. guy that took the external video hasn't done anything with it to my knowledge, and the guy that has the in-car video camera hasn't either because he lost his video editing program when he installed his new OS on his mac.
__________________
Old 09-05-2008, 07:31 PM   #35
Don't you know how to run a business? Go break their legs
Old 09-08-2008, 07:55 PM   #36
lol, thats an awesome pic. saved.
Mr. Phonso is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
