Autocrossing and Road Course RacingEnjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
im planning on doing a lil oval racing in the next few weeks, local z/nissan meet. id like to run as best i can but im not sure which rim/tires i should use.
options are
17lb enkie rp01s 17x8with 255/40/17 dunlops, about 75% tread left
18lbish enkie rsvs 17x7.5 with 235/45/17 nitto 555, not the drag tires the street tire, about 95% tread left
stock 18inch 350z 6spokes with 225/245/45/18 potenzas, about 95%tread left
im pretty sure it noone in theire right mind would run the 18 z's but i figure id throw them out there.
my suspension setup is basiclly jic a1's hopefully with a2 rear springs by event time, with all es bushings progress rsb, f&rstbs welded sfc's and stictch welded frame. also new balljoints tie rods, lcas and solid mm's
brakes are ss lines hawk pads and rtp rotors, 12.6 fronts and stock calipers, hopefully my quad pistons by race time. new fuild too
other thing, hotshot headers, vis hood, id trunk. not that any of that matters, but ya never know
thanks all
__________________
Shift_Afganistan deployment 08-09 Of the troops, for the troops!
05 sti, snorkel stock, small mods on the pipeline
89 SHO 5spd k&n maf clutch/flywheel. 400lbs weightlose and counting
00 Maxima se 5spd - SOLDEU,JIC,SFC,Hotshots,frankencar,BBK,Rota/nittos,cf hood/trunk, stillen lip
95 Maxima se 5spd-d2s,greddy sp2,enkie,cf lip, y pipe ready to install
93 SHOatx - gutted being parted out
what kind of dunlops or pretendas?
there are about 30 different types of dunlops that can fit on your car- anything from snow tires to race slicks. same thing with the potenza line.
Depending on what sort of dunlops they are, I'd lean towards the nittos mainly because the tire/wheel width combo will make for more crisp handling. A 255/40 on an 8J rim is pushing it width-wise, and you'll probably notice that out on the track as when the tire deforms not all the tread will be contacting the road. I also wouldn't run a staggered setup at the track unless it's reverse-staggered e.g. wider in front.
Actually the car was running Eibachs and KYBs with 18x8" wheels. Nothing done to the fenders except trimming the small tab where the rear bumper meets the sheet metal. otherwise it was 100% stock underneath.
