Go Back   Maxima Forums > Track and Tune > Autocrossing and Road Course Racing
Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-20-2007, 07:25 PM   #1
Thinks he owns a sports car
SFC's soon SCCA SP legal
Ok, lots of abbrevs in that. Means SCCA is in process of allowing SFC's into the D Street Prepared autocross catagory and it wouldn't force us into the E Prepared class. No X-bracing though Think of it as a 1.6sec time drop (60sec course)
The following previously-published change proposal has been reviewed and recommended by the SPAC, is being recommended
to the BOD by the SEB, and is published here again for member reference:
Insert new section 15.2.E after 15.2.D and re-label subsequent sections of 15.2 accordingly:
“E Longitudinal (fore-aft) subframe connectors (“SFCs”) are permitted with the following restrictions:
1. They must only connect previously unconnected boxed frame rails on unibody vehicles.
2. Each SFC must attach at no more than three points on the unibody (e.g. front, rear, and one point in between such
as a seat mount brace or rocker box brace).
3. SFCs must be bolted or welded, but welding must be to the OE subframe stampings, not to the floorpan in between.
4. No cutting of OE subframes or floorpan stampings is permitted. Drilling is permitted for mounting bolts only.
5. No cross-car/lateral/triangulated connections directly between the driver’s side and passenger’s side SFCs are permitted.
Connections to OE components such as tunnel braces or closure panels via bolts are allowed and count as the
third point of attachment. No alteration to the OE components is permitted.
6. SFCs may not be used to attach other components (including but not limited to torque arm front mounts or driveshaft
loops) and may serve no other purpose.”
http://www.scca.com/_FileLibrary/Fil...full-final.pdf
BEJAY1 is offline   Reply With Quote
Old 06-20-2007, 07:46 PM   #2
Sexier Than Simpson
Bufflomike's Avatar
What if you are a newb, will they still let you run in an amateur class? I want to try "pine cone racing" (what the wife calls it) and I dont want to embarass myself
Bufflomike is offline   Reply With Quote
Old 06-20-2007, 09:02 PM   #3
retired moderator
irish44j's Avatar
wow...that is GREAT news.
too bad the Warpspeed and Truax SFCs attach in 4 points. grr.
irish44j is offline   Reply With Quote
Old 06-21-2007, 07:38 AM   #4
to those who served
97SEdriver's Avatar
What's SCCA mean?
97SEdriver is offline   Reply With Quote
Old 06-21-2007, 07:54 AM   #5
to those who served
97SEdriver's Avatar
Quote:
yes, if you're a "Novice" they will always allow you to run in "Novice" class.
You won't embarrass yourself, it's only much later when you've done it a while that you realize you sucked when you started. However, when you see other new guys out there, you won't tell them, if anything you'll encourage them and tell them they did fine.
As a newb, you're going to over drive your car, or underdrive it, you can't understand what I mean until you start doing it. Even on a real track going 100mph+, same thing, motions are different at 100, but thought process is the same.
I can honestly say that only one season did I see a "newb" kid out there that was really, really bad. He was embarrassing for a couple reasons. Although people gave him credit for trying to run his Geo Metro, he never went out and memorized the course. That fact would frustrate the instructors he would ask to ride with him because he would go off course almost every run.
Here is where it would be embarrassing, I remember getting in the order right behind him for a heat, where as the runs (at Ripken) are 45-60seconds, he would go off course, hit cones trying to get back on course and in general screw the course all up, AND he would take 100 seconds to do it. So I would have to wait another 2-5 minutes after he finished to start.
Old 06-21-2007, 03:40 PM   #6
michaelnyden's Avatar
Send a message via AIM to michaelnyden
this is interesting...but I have the x brace too...oh well...
michaelnyden is offline   Reply With Quote
Old 06-22-2007, 06:27 PM   #7
[/url]
GREAT... too bad I am 5 seconds behind the nationally prepared DSP BMWs in my region. And that is when I am driving at the limit of my car.
gdmaxse is offline   Reply With Quote
Old 06-22-2007, 09:29 PM   #8
retired moderator
irish44j's Avatar
Quote:
Run EP. Win Screw index.
__________________
Sold: 2000 Maxima SE - PR Intake - Frankencar CB - Truax SFCs - Wilwoods - Eibachs - Blehm LTB - Cattman Ypipe
Stillen RSB - RSTB - FSTB - ES Bushes - G wheels - Raxles - Mach1 lip - Illuminas - and plenty more
New: 2009 WRX - Cobb 25mm FSB - Perrin 19mm RSB - SPT Catback - STi springs - Rota SDRs - RalliTek Endlinks
Old 06-22-2007, 09:57 PM   #9
I'm lucky, no one who runs in DSP ever shows up in my region...sometimes there'll be an ae86 or mustang...
but you should just run EP as per irish's suggestions...
Old 06-22-2007, 10:03 PM   #10
retired moderator
irish44j's Avatar
Gabe, you're running DC this year instead of Philly, right?
How is the DC EP group? Was pretty weak for Philly (and DSP at Philly is fast).....
that's why me and you have all these pint glasses
Old 06-23-2007, 09:58 AM   #11
What can I get ya?
Cutler's Avatar
http://forums.maxima.org/showthread....23#post5783323
There's a set of nice SFCs for sale, the redesigned ones...
Cutler is offline   Reply With Quote
Old 06-23-2007, 08:26 PM   #12
http://solo.wdcr-scca.org/results/20070617.php
That is with me driving good lines and close to the limit of my car... so basically, I will never catch the bimmer. there is also an e46 323 that is 1-2 seconds ahead of the e30
EP is about 3-4 seconds behind me so it may be possible to take that class on street tires, there is a caged honda crx on RA1s and a gutted datsun 510 with 10" slicks
The courses at FedEX are much more wide open than ripken and the lot is easier on tires. The only problem is there is about a 15 minute window when you can sign up otherwise you are on the waiting list.
I will most likely do the events at ripken as well.
Old 06-23-2007, 08:54 PM   #13
retired moderator
irish44j's Avatar
may be until August-Sept timeframe before I run this summer, thanks to the moving and 3 weddings to got to....
in other news, the GT6 was prepared today to be towed up, as soon as I get the new house with garage I'll be taking a buddy's Titan down with a trailer to pull it
Old 06-26-2007, 11:11 PM   #14
Send a message via AIM to funky_monkey58
If anyone wants a set of sfcs with only 3 mount points Pm me I can make some really easy for the 4th or 5th gen. Josh Your New X bracing should be on its way tomorrow.
This is pretty good news to a sfc builder.
-Sean
TMS
funky_monkey58 is offline   Reply With Quote
Old 07-02-2007, 06:24 PM   #15
Chassis Freak
VQuick's Avatar
Send a message via ICQ to VQuick Send a message via AIM to VQuick Send a message via MSN to VQuick
But what about:
"3. SFCs must be bolted or welded, but welding must be to the OE subframe stampings, not to the floorpan in between."
Do the factory frame rails count as "subframe"?
VQuick is offline   Reply With Quote
Old 07-02-2007, 09:00 PM   #16
retired moderator
irish44j's Avatar
Quote:
Originally Posted by VQuick
But what about:
yes, they do. The reference to floorpan is that there can't be secondary welds reinforcing the floorpan itself (the flat area between the frame rails).
__________________
Old 07-03-2007, 12:51 AM   #17
Maxima.org Sponsor
TruaxMotorsport's Avatar
There is now a GB for 3 point tie in SFCS for $150 plus 25 for shipping in the Gb forum. There will be D street prepped legal.
-Sean
TMS
TruaxMotorsport is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
