Autocrossing and Road Course RacingEnjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
It depends on your powerband. Our auto/x is in a mall parking lot, so 2nd would seem like a good option. But play round with it and see what works best for you.
__________________ 03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
When I run, I usually put it in 2nd with OD off. It is too easy to mess up on your shift with no gates.
Most courses you will never see 3rd anyway.
__________________
SHIFT_AutoMagicly Slippery
2001 AE
PR CAI, Custom Magnaflow Cat-back, Unorthodox UDP, Restrictor Plate Mod.
BlehmCo Stock Caliper BBK,
Truax Subframe connectors, D2's, Addco RSB, CustomMaxima FSTB, VIS hood, 2k3 OEM HID's, Federal ss595's, Quantum Tint.
5sp swap w/Fidenza in garage waiting for quaife.
Favorite Quote: SCCA Solo2 announcer for STS class "Comon' Guys...if the Maxima can do it you sure as hell can"
It really isn't that hard. The maxima is a pretty decent handling machine. I will say there are a few tricks to getting around the course with a heavy fwd car though.
In the bay area, a 96 maxima took the STS class for the first couple years it was around. I did fairly well in STS with mine, and it is by far the most competitive class in our region, and I am a lowly auto.
Look around for Spaniard's videos if you want to see what a max driven to the edge can do.
Er... have you thought about the shift_fast mod for the automatic transmission, so you can shift up and down with a bank of pushbuttons?
Push the button for first, you're in first. Push the button for second gear, you're in second. No shift lag, no slippage. There's a lot of threads in All Motor about building and using it, and it's cheap to do.
For what's it's worth. I use an updated version on the drag strip. Read my sig.
I gotta admit that what you're doing seems like a lot of fun....
