Go Back   Maxima Forums > Track and Tune > Autocrossing and Road Course Racing
Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
Thread Tools Display Modes
Old 10-30-2006, 06:07 AM   #1
Very sound, Mike
Which Brake upgrade makes more sense?
For a street driver/weekend auto-rx'er, which of these brake set-ups would make more sense, and why?
Set 1:
Caliper relocation kit using 5.5 gen OEM caliper w/ 12.75x0.94" rotors (15.5 lbs.)
Set 2:
SSBC 2-Piston Caliper w/ 12x1" rotors (no idea on weight)
Both set-up's will be on Hawk HPS.
I'm thinking it's a wash, but what do you all think?
Thanks.
soundmike is offline   Reply With Quote
Old 10-30-2006, 07:26 AM   #2
for autocross i wouldnt upgrade the brakes other than hawk hps pads and stainless steel lines because the stock sized brakes will have less weight, moment of intertia and will come to temperature faster. also you will be able to fit smaller diameter wheels and shorter tires which once again have a lower moment of inertia and better gearing. plus i think brake caliper and rotor upgrades bump you into ridiculus classes like street modified or e prepared
gdmaxse is offline   Reply With Quote
Old 10-30-2006, 03:56 PM   #3
mad tyte JDM drift king
irish44j's Avatar
actually, you could upgrade to the full 6th gen calipers and rotors. Since it's a direct bolt-up with no brackets needed, it is at very least DSP legal under the update-backdate provisions....
If you're looking for a good street braking ability, the 6th gen setup is excellent. If it's just for autocross, don't worry about it. Brakes are not a huge upgrade for autocross, IMO.
irish44j is offline   Reply With Quote
Old 10-31-2006, 05:12 PM   #4
Thinks he owns a sports car
What tires you intend on running for auto-x? If you're overbraking the rubber changing the brakes doesn't help any more.
BEJAY1 is offline   Reply With Quote
Old 11-01-2006, 06:49 AM   #5
Very sound, Mike
Thanks for the responses, guys.
I'm looking into a good mix of effectiveness in both daily driving and the occassional auto-x stints. "Set 1" above wouldn't be any heavier than the OEM 2k2 set-up so i'm not worried much about weight and i'm pretty much stuck with 17's these days anyhow.
The 2k4+ caliper/rotor combo has always sounded good, but the caliper just doesn't seem to fit in my current set-up - from the limited info i gathered, the top hat (?) will hit either the wheel weights or the inside spoke of my rims.
Right now, i'm on 245/45/17 Proxes 4, there's plenty of grip for what its worth - it's just the feel of my current brake set-up that's got me thinking of an upgrade. The existing set-up brakes just fine, even under constant braking, but it doesn't bode well for daily driving.
Hmm, then again, do you guys think having Hawk HPS up front and Axxis MM's in the back have anything to do with it? It's a bit hard to explain, but whenever i do brake it feels the back just isn't biting as hard.
Thoughts?
Thanks!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
