Go Back   Maxima Forums > Track and Tune > Autocrossing and Road Course Racing
Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-05-2002, 08:45 AM   #1
RIceD OuT moDErAtor
Chebosto's Avatar
Send a message via ICQ to Chebosto Send a message via AIM to Chebosto
Suspension Setups [Road Course]
Please list the following suspension setup for Road Course Hot Lapping. Using this simple table.
Ko - Koni Adjustables [# of turns from super soft. max of 2 full turns)
Ag - Kyb AGX Adjustables [Setting number 1->8/1->4]
St - Stock Suspension
Gr - Kyb GR2 or Tokico Gas shock equivalent (i.e. aftermarket non adjustble struts)
F1 - Coilover setup (Cattman, FLT-A2, Progress, NOT Ground Control)
Ei - Eibach Springs
Nt - Sprint Springs
Hr - H&R Springs
Gc - Ground Control
Sw - Rear Sway bar
FSTB - Front Strut Tower Brace
RSTB - Rear Strut Tower Brace
UBB - Underbody X Braces
If other, please write in
[Your Name, Your Year Maxima, Stick or Auto, NA/Boost]
1. Strut/Shox [Setting #s F/R if applicable]
2. Springs [Drop in inches for coilovers]
3. Which Braces do you have?
4. Tire Pressure F/R
5. Camber
6. Tire Size and Brand
for example:
Joe Nismo, 1997 GXE, Stick, Supercharged
1. F1
2. F1 [2.5"]
3. FSTB, RSTB, Sw, UBB
4. 40/33
5. -2.0 degrees
6. 235/45/Z17 Bridgestone RE730
Cheston
Chebosto is offline   Reply With Quote
Old 12-05-2002, 10:54 AM   #2
Send a message via ICQ to brianw Send a message via AIM to brianw Send a message via Yahoo to brianw
Wouldn't the following changes make more sense?
UBB ---- SFC (subframe connectors)
AG ---- AGX
Sw ---- RSB
Gr --- GR2 (or maybe something else...)
HR ---- H&R (since H&R doesn't make Maxima coilovers, they're be no confusion)
I know you want to use 2-letter abbreviations, but many of these terms already have 3-letter or 4-letter abbreviations already in accepted, widespread use here on .org and in the racing community.
It'd be one less set of TLA's to memorize. Also you could consolidate both sticky posts into just one, as the setup information is similar. My $0.02.
__________________
Driven a Maxima, worked on a Maxima, lowered a Maxima, saving for a Maxima... where the heck is that damn thing now anyway??
"you're too stupid to understand how to fix it so stop asking" club member #4
brianw is offline   Reply With Quote
Old 12-05-2002, 05:18 PM   #3
RIceD OuT moDErAtor
Chebosto's Avatar
blah blah blah.
Old 03-29-2003, 07:12 AM   #4
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
Sue me for not using the assigned abbreviations :P
Neal Clary, 96GXE Stick, N/A
1. GR2 (f) / AGX setting 8 (R)
2. GC 2.75"
3. FSTB, RSB, SFC Stg 1&2
4. 42/40 (hot)
5. Unknown (lots :P)
6. 235-40-17 Toyo T1-S
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 05-19-2003, 07:00 AM   #5
Send a message via ICQ to mingo
1.daniel weng/ mingo/ 2000 se/ auto / NA
2.f1
3.f1 f=2.5" r=2"
4.fstb, sbb, Sw
5. 43/40 (hot)
6. -1
7. 245/35/18 bridgestone potenza s03
__________________
project status: it just never ends does it?
mingo is offline   Reply With Quote
Old 03-26-2006, 09:10 PM   #6
Not a Maxima owner
MaxBoost925's Avatar
1. Grant Lim, 2000 SE, Manual, NA
2. K-Sport, max stiff
3. K-Sport, 24.5" - 24.5"
4. FSTB, RSTB, ES motor mounts
5. 35, 35
6. unknown
7. 215/50/17 Kuhmo Ecsta Supra 711
__________________
Stance/Fitment - epitome of low, wide, and slow.
MaxBoost925 is offline   Reply With Quote
Old 06-09-2006, 07:18 AM   #7
KaZ
Send a message via AIM to KaZ
Kaz, 1997 SE, Stick, NA
1. Ag - Kyb AGX Adjustables [2/4 - F/R]
2. Hr - H&R Springs
3. FSTB, Sw, UBB - Custom Enterprise FSTB, Progress RSB, BlehmCo StageII Tie Bar
4. ~35/34
5. Factory
6. 245/40/W18 Toyo Proxes 4 on Falken Hanabi 18x8.5" 42mm
Had Matt Blehm riding along shotgun as a course instructor at MSR for Hot Lapping. He at first commented it felt like it understeered (big surprise) while he was driving for demo laps, but once I got behind the wheel, he said it felt like it was more prone to oversteer. Car was actually very neutral, but was a bit of a balancing act between feeling like it was going to slide straight off the course in the corners if I kept on the gas, to having the tail come around if I let off the throttle by a hair too much in the corner (I was really having to feather the throttle, but had Matt yelling at me to give it more gas!, lol). Maxima performed awesome!
__________________
KaZ
'09 Maxima SV Sport + Tech / Navy Blue over Charcoal!
KaZ is offline   Reply With Quote
Old 12-19-2007, 12:52 AM   #8
tru story
SoonerFan's Avatar
Send a message via AIM to SoonerFan Send a message via Yahoo to SoonerFan
Jason, 02, 6MT, NA
1. Gr
2. Hr
3. FSTB, RSB, LTB
4. 35/35
5. Factory
6. 235/45/17 Hankook
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
06 Mazda 6
Maxima - A33 | VQ35DE | RS6F51A | KH3/G
NWP Engineering Thermal Intake Manifold Spacers
Hybrid Berk/Frankencar Intake | Frankencar catback | Cattman STS | ES 6-speed bushings
H&R Springs | Tokico Struts | Progress RSB | Otto FSTB | Blemco LTB | Hawks HPS Pads | Custom Front Lip
O2 Sensor Locations and Corresponding Codes
SoonerFan is online now   Reply With Quote
Old 10-29-2008, 08:48 PM   #9
to those who served
97SEdriver's Avatar
The last time I went on Pocono (in 04)....all stock...
it was still a blast, I did 100mph in turn 1.
you can go on a road course on stock suspension no matter what anyone says
97SEdriver is offline   Reply With Quote
Old 06-03-2009, 06:32 PM   #10
Thinks he owns a sports car
Vehicle race setup tool
Very nice tool that R2P and NASA published for the Sim community. Free to use this month at least. Seems spot on from my limited experience.
http://www.race2play.com/special/setup_tool
Master the secrets of race car Setup Fu with straight-up questions and answers using the Race2Play Setup Developer Tool!
This interactive program steps the user through the major areas of race car setup and tuning, asking simple questions about the telemetry readings and behavior of the car under specific race conditions. "How is the car reacting at initial turn-in?" "How does the car feel from mid-corner to corner-exit when on the throttle?" "What type of track are you preparing for?"
Choosing from a menu of possible responses to the questions ("Sluggish turn-in", "Oversteer", "Long sweeping corners"), the user describes the car and the program calculates possible setup changes accordingly. Questions asked. Questions answered.
The Race2Play Setup Developer Tool covers the following areas of race car setup and tuning:
Springs and antiroll bars
Tire pressures and camber
Caster and toe
Gearing
Differential
Weight distribution
Dampers
Aerodynamics
The advice and interactive program is the product of Race2Play Chief Setup Engineer Tim McArthur's two decades of research in simulated auto racing. The information offered therein is relevant not only to all racing sims, but real world applications as well.
The program's complete and full functionality is unlocked for supporting members of Race2Play. Guest members unlock a limited set of the functionality. Special! For the month of June, all members enjoy the complete and full functionality!
BEJAY1 is offline   Reply With Quote
Old 08-08-2009, 08:20 AM   #11
Master the secrets of race car Setup Fu with straight-up questions and answers using the Race2Play Setup Developer Tool.This interactive program steps the user through the major areas of race car setup and tuning, asking simple questions about the telemetry readings and behavior of the car under specific race conditions.
__________________
limo miami
CyrusCarleton is offline   Reply With Quote
Old 08-08-2009, 01:27 PM   #12
[2006 Altima (04-07 Maxima), Auto, NA]
1. Tein Super Street Coilovers [F:16 R:00]
2. Tein SS coilovers [F: 2.5" R: 1"]
3. Racingline FSTB, Nismo RSB
4. Tire Pressure [F: 32PSI R: 45PSI]
5. Camber: -1.25
6. Tire Size and Brand [245/45/18 Potenza RE01R]
__________________
Cardomain
Mods:
| Berk V2 | Hella Optilux 1180 / Apexcone 3000k | Polk DB6500 + Polk DB690 | Apexcone 5000k | Racingline FSTB | Nismo Catback | AT S5 | Nismo 57F / Potenza RE01R; 245 45 18 | Redline Quicklift Elite | Hotshot header | Jihad folding mirrors | Nismo RSB | Audi DRL | Tein SS w/ EDFC | Racingline MMI | 350z seats | JWT BSR |
spike228 is offline   Reply With Quote
Old 09-21-2009, 06:15 AM   #13
Hy! My name is Jans, I love racing and I have a 2000 Mustang GT and if
you want to see one of my race I ll be glad to show you.
Enjoy the race.
iness is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
