7" LCD TV, DVD Player, custom trim piece for tv..
The TV is a 7" LCD made by TV ONE and the model number is LT-070S. It has a built in cable ready TV Tuner and supports 4:3 and also 16:9 formats. For connectivity it has a video out, headphone/audio out, composite video/audio in (RCA), and s-video/rca audio in. It has optional button controls if you wanted to mount those somewhere, and also a IR receiver for the remote control. Its not your typical car lcd tv, it is made for video playback on highend film videocameras, so it has a really good picture and very wide viewing angle. Used it very little, maybe 4-5 hours. Sold the car it was in and have nothing to put it in anymore so thats why I am selling it. It was taken out of the casing and modified so it would fit behind the dash where the radio and all is. I would like to get $260 for it. Here are some pictures:
I also have for sale a DVD Player made by XO Vision, model number XO-1100. Comes with a remote sensor eye so you can mount the dvd player elsewhere while still being able to control it. Also has a module to use to connect to the car 12V, or you could use the cig lighter adapter. Only used it like 2 times. I would like to get $75 for it. Here is a picture of it:
I am also selling a trim piece that was custom made for a 7" LCD mainly this one. What I did was take the casing that came with the tv and cut it out and placed that inside, and bondo'd it all together. I was in the process of redoing it to make it better, and had finished the exterior but there are no mounts. Would be pretty simple to make some on the rear of this piece for the tv though. I would like to get $40 for it. Here are some pictures of it and one with the tv behind it:
Here is a picture of the remotes for the DVD and TV, the Remote sensor, and the 12V Module for the DVD.
Here is a picture of everything when it was mounted in the car, as you can see you can just put your cd player in the bottom DIN slot.
Or, do a package deal with the TV, DVD Player, and Trim Piece for $350.
Or, just the TV and Trim Piece for $280.
They load fine for me. If they still don't work for you, go to this link they are in there near the bottom.
http://www.flickr.com/photos/phatmax...7594119422991/
Let me know,
Thanks,
Tyler
Let me know,
Thanks,
Tyler
Originally Posted by zippyflu
im a noob to all this tv stuff.. but why is it all wirey?? im buying a dvdplayer or at least looking into it.. a dvd/cd headunit... of course ill eventually get a tv...
Shipping should be around $10. I would put the DVD player under the seat. It has a remote sensor you can put up front so the remote would work with it. Where you going to put the TV?
Originally Posted by Fre$h_TurK
just where u put it ...(ur pic up there)
i was thinkin of getting a screen and a dvd/mp3 capable HU... without the dvd player ur selling ... is that possible ?
how does the TV work ? satellite or sumthing... lol sry for the nooby questions
Sure you can use any dvd player you would like, you will need a power inverter for a home dvd player though. And if you get a dvd headunit it will need a video out and you can plug that right into the screen.
The TV works like any other TV. You either use the built in antenna to pick up local TV stations, or connect an external antenna to the coaxial input, or if you wanted hook it up to a cable tv line through the coaxial input.
howcome u have a seperate headunit in ur car? how did u plug ur tv into the dvd player (the one ur selling) and the headunit where the tray is? just bought a dvd/hu so i would like more info
Originally Posted by maxiquin
you sold this yet? i'll give you 200 shipped for everything...
i see that you have a headunit underneath the tv, and u have the stand alone dvdplayer. wat is the dvd player for and how did u connect it to ur tv along with the headunit on ur dash underneath ur tv?
The DVD player is for playing DVD's... the headunit doesn't play DVD's...
You connect the audio out on the dvd to the audio in on the HU.
You connect the video out on the dvd to the video in on the TV.
If you want the sound from the TV tuner, you connect the audio out on the tv to the audio in on the HU.
Originally Posted by Canepole
Asking way to much man. I can get a new Screen/DVD player for around $250 (check Ebay). The custom in-dash part is just a bonus. You can't charge anything for it. Just trying to help you man.
whats the lowest you would go for just the dvd player?
does it have last memory playback? the dvd player i have now gets on my nerves since it doenst hold the memory from the time i turn off the car. if it does im really interested.
let me know. thanks.
