BOOM BOOM (Installing Two 15'" RE Audio Subs) Noise/Rattle Suggestions?
I got a great deal on these bad boys... I had to snag em.
They are 1000rms a piece.
Im going to have them hooked up to a 1800 watt amp (Audio Pipe)
I can potentially push somewhere between 3-3500watts without them blowing, but I would need a separate battery or alternator (thats out the question $$)
They are in a sealed box with them facing up towards the top of the trunk.
Now I have no trunk LOL, but thats ok.
My question is, from what parts of the car would I receive any rattle from that you would hear outside the car. Im not trying to have it sound cheap and ratchet. I want good bass without the extra rattle you hear on these other old goofy looking cars. Thanks.
Second Skin Damplifier Pro. From the research done, Second Skin's products are among the best on the market, and many top professional well known car audio guys use it.
The owner of PWK designs used it in his suv, doing the roof, door panels, tailgate, etc., and installed 3 Sundown SA-12's and it doesn't have a single rattle.
And underpower is good for now as long as it booms, and my headlights not dimming im ok
Nice, will do some research. Now all i hear these days is "dynomat, dynomat!" how well in comparison is this to dynomat?
Any 'mass add' rubber butyl dampening material will work. Dynomat is good, so is second skin, and hush mat. They are all essentially the same thing.
Just avoid the asphalt mat that is sold at home improvement stores.
You will want at least one layer on the entire trunk lid, and I would also do the rear fenders from inside the trunk. You can do the spare tire well as well for sound reasons, but it won't change the amount of vibration much.
Those things are going to hit pretty hard. I'd recommend deadening everything possible... In the doors, below the carpet, the roof under the headliner, etc.
If you're going to do it, do it right the first time.
Hifonics Brutus brz2100.1 will push 2100 watts at 1 ohm. I have the brz2400. Amazing Amps for the price. Got mine from sonicelectronix.com run good power and ground. Got this on two 2012 12" alpine type R's also 1000 rms each. Amps are dirt cheap for the awesome power they put out.
lowpost99
05-16-2021 11:18 AM
markevans999
09-10-2015 04:29 PM
