headunit mod shop
headunit mod shop
Can anyone recommend a shop or member here that's in the tampa area that could do a bypass so that video will work without the parking break being up?
I have a navigation app (Motion X drive) on my iphone but it won't work unless the parking break is up
you'll need a 12v relay. run the parking wire (lt green) to pin 30, ground both pins 87 and 86, run the remote (blue/white) to 85. 87a (center) won't be used.
or, wait for a tampa member to chime in. Im sure someone could help you but I'm sure you could do this
Theres a mechanical piece in this radio that does not allow for relay switches to work. They work but only up to 10mph it has a built in accelerometer. Since the app uses built in equipment of the radio it will knock it down. Im not 100% sure if there is a software hack yet. I looked and I couldn't find anything hope this helps.
^^ Read the 2 posts above yours. The newer units have other engineering in them that prevent electrical workarounds to work.
Also, sent you PM re: spare tire cover a while back, never heard from you. Requesting the courtesy of a response at least.
1/3 correct. Any new Alpine is going to require a Pac TR7 to bypass video, pioneers you must either move pins or add a relay, and Kenwoods, yes all you need to do is ground a wire.
RealityCheck
10-02-2015 06:34 PM
