Replacing bose subwoofer
Old 06-28-2010, 10:31 PM
auveeb's Avatar
First time posting in this forum, or any audio related forum for that matter, so bare with me.
I have the BOSE subwoofer in my 5th gen, but as many know, the bass is lackluster. I want to take out the stock sub and place the Alpine SWE-1243e in the rear deck. It has the following specs:
Single 12" Woofer
Peak Power: 800W
RMS Power: 250W
Frequency Response: 28Hz - 1kHz
Sensitivity: 89.8dB/W(1m)
Installation Diameter: 282mm
Depth: 172mm
I already have the subwoofer and all of the neccesary wiring done, now I just need to pick out an amplifier to get the job done. What I ask from you, audio overlords, is for an amplifier suggestion. I know I can just pick any old amplifier but I want something tried and true that won't crap out on me.
Thanks in advance!
auveeb is offline
Old 07-15-2010, 06:31 PM
Maxy91's Avatar
I have this same amp, have had it for 2 years works like a charm no problems with it what so ever!
http://www.sonicelectronix.com/item_...+J2+250.1.html
Maxy91 is offline
Old 01-17-2011, 09:40 AM
mamclau's Avatar
Does anyone have a wiring schematic for the 2010 max stereo sys and speaker/sub locations?
mamclau is offline
Old 01-17-2011, 01:22 PM
ctsmith39's Avatar
this is the best that I could find on the subject from the tubes.
2010 Nissan Maxima Car Stereo Install Diagram
Car Radio Battery Constant 12v+ Wire: Yellow/Red
Car Radio Accessory Switched 12v+ Wire: Violet/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black
Car Stereo Amp Trigger Wire: Black/Pink
Car Stereo Amplifier Location: Under the Rear Deck in the Trunk
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): N/A
Left Front Speaker Negative Wire (-): N/A
Right Front Speaker Positive Wire (+): N/A
Right Front Speaker Negative Wire (-): N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): N/A
Left Rear Speaker Negative Wire (-): N/A
Right Rear Speaker Positive Wire (+): N/A
Right Rear Speaker Negative Wire (-): N/A
ctsmith39 is offline
Old 01-17-2011, 07:13 PM
Lani's Avatar
I would deff keep that in there those BOSE systems are nothing but the truth
Lani is offline
Old 01-17-2011, 07:23 PM
AscendantMax's Avatar
you have got to be kidding right? or you spamming threads to get to 15 posts?
AscendantMax is offline
Old 02-06-2011, 08:50 PM
keepitclean's Avatar
Bose is alright but depending on the music it cant compete.Rockford Fosgate all day long.
keepitclean is offline
Old 02-06-2011, 09:36 PM
BigLou55's Avatar
rockford fosgate has "too much bass" they generate bass from someone talking...totally unnecessary, i prefer alpine
BigLou55 is offline
Old 02-08-2011, 09:03 AM
tunafish51's Avatar
Alpine ftw
tunafish51 is offline
Old 02-08-2011, 10:50 AM
Ricksi30's Avatar
Is this thread a joke?
Ricksi30 is offline
Old 02-09-2011, 12:13 PM
§è~® f®ÈÄk
nismos14's Avatar
lmfao @ the tools in this thread.
nismos14 is offline
Old 02-09-2011, 08:39 PM
Tommiekatt916's Avatar
Heres the problem with replacing the bose sub well one of many....... the bose systems are quite often 2ohm and sometimes 1ohm... You can replace the bose speakers w 2 ohm systems with the Infinty Ref series while using the factory amp because Infinty runs their speakers at 2.2ohms and they are as close to matching the RMS wattage of the bose amps. I dont know the wattage on the Bose sub amp but I know they closely match the rms of the amp to the rms of the speaker. Thats how they get the decent sound while using low wattage.
Tommiekatt916 is offline
Old 02-09-2011, 09:17 PM
justinkc21's Avatar
If your just trying to get a cleaner bass sound take the sub out of the factory enclosure and get a nice prefab box for your new sub ported is the way to go for loud and sealed is the way to go for quality if your adding another amp into the pic don't worry about factory boss ohm loads their meaningless just match up your new setup ie sub and new amp
Pm me if you have any more questions I did audio compition for the last 3 years in Usaci
justinkc21 is offline
6spd4dsc
05-09-2022 12:30 PM
jskirwin
06-08-2016 08:49 AM
melteye
05-16-2016 12:02 AM
Maxinesdaddy
08-21-2015 11:43 PM
starman9215
08-11-2015 06:51 PM
Quick Reply: Replacing bose subwoofer
