Wiring Guru's help needed!
Old 12-16-2009, 05:02 PM
oxygen's Avatar
OK I made a video of this because it was too hard to try and explain without people thinking I'm crazy.
http://www.youtube.com/watch?v=mDCruFkhOec
The camera SUCKS. Here's what happens. Wiring up a whelen slimlighter. Connect + and - wires on the bar itself to the battery, ALL LEDs work just fine! Works great! ... I connect the power wire from the light bar to a connection on a 3 prong switch, and a wire running from the + battery terminal to another prong on the switch. I run the ground directly to the battery in the deminstration...
What happens when I run the light bar to a switch is that only 8 LEDs on the bottom of each side of the light bar will light up.
Summary = battery directly = fine
Switch = only 8 LEDs light up on each side.
Switch is 20 amps. I ran the light bar to a 10 amp fuse in the engine compartment and it worked fine all LEDs lit up so I don't think its the switch itself,not sure
oxygen is offline
Old 12-16-2009, 06:18 PM
oxygen's Avatar
problem solved! bad switch
oxygen is offline
Old 12-16-2009, 06:23 PM
anomaly117's Avatar
that woulda been my guess
anomaly117 is offline
Old 12-17-2009, 03:52 PM
abdel's Avatar
allite so check it my 4th gen is tripping i think the security system is stuck or something it wont start is there like a fuse or a way to disconect it.cuz its been doing this for two days .
abdel is offline
smplyamzng
12-13-2015 01:19 PM
TonyJr
08-20-2015 12:14 AM
Viralkill
08-16-2015 05:09 PM
doobadoo
08-15-2015 06:43 PM
maximaham
08-07-2015 01:11 PM
Quick Reply: Wiring Guru's help needed!
