Go Back   Maxima Forums > Maintenance, Tech, & Care > Audio and Electronics
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-01-2009, 12:09 PM   #1
Send a message via AIM to Maximan190
5th gen NON-BOSE head unit problem
Through searches i was able to find tons of info on the Bose unit, but not the lower grade/non-bose model
Car is an 03 SE with the standard single CD/tape deck radio -
Problem is the text display on the deck will intermittently go out but the audio still plays, then soon after the audio will cut out. Everything will come back on at random and then go out again, sometimes in 5 minues, sometimes in an hour or more - any solutions? Probably worth just replacing it i assume
Id like to just get another of the same deck, just plug it in and go... downside is that a used unit may eventually experience the same problem i have with the current unit
Theres the option of going aftermarket but then id have to get the dash kit (GXE/Scoshe) and the wiring harness and worry about the steering wheel controls working or not
This isnt my car so im looking for the most painless solution (if it was mine id upgrade everything)
any suggestions/thoughts - thanks folks!
__________________
97 Camaro Z28 6spd - Intake, Catback, Suspension & Chassis upgrades
92 Maxima SE 5spd - JDM VE swap & Chassis/Suspension Resto currently underway
92 Maxima SE 5spd #2 - Daily Driver until the above is finished
Maximan190 is offline   Reply With Quote
Old 11-02-2009, 07:36 AM   #2
Send a message via AIM to bigpopaj369
most definitely go aftermarket bro unless u can find the same stereo mad cheap some wheres. its not expensive at all dash kit $20 antenna adapter $5-8 wiring harness $5-15. to me its well worth doing to avoid the same problem happening down the road. im almost positive they make a kit to utilize the wheel controls
__________________
BIGPOPAJ369
SEXIMA badge,black w polished lip rims,rain guards,SRI,painted spark plug cover,AE'd heads w/luminics bulbs,rewired yellow tinted fogs w/out glare guards,polarg blinkers/reverse/plate lites,tinted n rewired sidemarkers(blinker mod),painted interior trim,all interior lights to led,AB clock mod w/white display,red leds in climate control w/white display
bigpopaj369 is offline   Reply With Quote
Old 11-04-2009, 01:25 PM   #3
Send a message via AIM to djfrestyl
Go aftermarket. You're 100% right, a replacement unit will go bad down the road.
Depending on the aftermarket unit you purchase, there ARE steering wheel interface modules that will work flawlessly. They are made by PAC and the model # starts with SWI-(brand specific). For example, Pioneer units need the PAC SWI-PS.
__________________
Eclipse CD3000
Audison LRx 6.9-> Rainbow SLC 265.03, (2) 10" DLS Reference W710's
Knukonceptz 1/0awg / Cascade VB2Max / Stinger / Clifford / Optima
Exterior: stock-tastic.
I can install your suspension and stereo. Click here for info!
Is your spare tire cover sagging? Trunk have a big DIP in the middle? Click here to see a solution!
djfrestyl is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
