Go Back   Maxima Forums > Maintenance, Tech, & Care > Audio and Electronics
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-26-2009, 03:17 PM   #1
Bose Amp Integration Harness Question
Back in November, 2003 I went to a local audio shop in KC to buy a new headunit for my 96 Maxima. I purchased the Alpine CDA-9811, and also paid for all necessary equipment to make it work with the factory bose speakers/amp and antenna. Everything worked great, and still does.
The 96 is still in the family, but my dad is planning on trading it in on a new car here soon. The car is not worth much and I am considering putting the 96 head-unit back in, as the Alpine still works. My question to all of you audio guys: If I put the stock unit back in, would all of the adapters from my 96 be able to be used in my 01 or my brother's 03 if either of us decided to replace our stock headunits? I won't necessarily re-use the alpine head-unit itself, but if all of the adapter equipment would still work, I don't see any point in giving it away when my dad trades the car in.
I hope this is easy to understand. Thanks.
__________________
Current: AE KT3 MT | 5.5 HIDs | Fog-Light Rewire
Old: 96 KH3 MT | Fog-Light Rewire (sold 11/9/09)
AEMAXIMA01 is offline   Reply With Quote
Old 10-27-2009, 05:29 AM   #2
Anyone?
__________________
Old 10-27-2009, 03:58 PM   #3
As long as nothing was hard-wired, it should be fine. Most Nissan's 96 and up use the same harness until the early 2000s.. Then the Premium system started to get alittle funky. Ahh memories.. I did installs for 4.5 years when Circuit City was still around. If you want, take some pictures of the harness behind the radio. I'm about 95% sure the installer didn't use an actual line-output-convert (LOC) to your Bose amps. You'd know as they're usually north of $50 for the LOC.
__________________
1999 Infiniti i30 - FSTB | Warpspeed Y | Progress RSB
2006 BMW 330i Black on Terra Leather 6MT - ZSP | ZPP | ZCP
talisman311 is offline   Reply With Quote
Old 10-28-2009, 11:29 AM   #4
Send a message via AIM to djfrestyl
The theories behind the wiring between the generations are the same. It all depends how the shop installed the old one - however they did, if you replicated it to the new car, it will work.
__________________
Eclipse CD3000
Audison LRx 6.9-> Rainbow SLC 265.03, (2) 10" DLS Reference W710's
Knukonceptz 1/0awg / Cascade VB2Max / Stinger / Clifford / Optima
Exterior: stock-tastic.
I can install your suspension and stereo. Click here for info!
Is your spare tire cover sagging? Trunk have a big DIP in the middle? Click here to see a solution!
djfrestyl is offline   Reply With Quote
Old 10-28-2009, 11:45 AM   #5
This is exactly the information I was wanting to hear. I'll have to take it apart Friday night while I'm changing my oil. Hopefully I'll have some good luck! Thanks!
__________________
Old 10-28-2009, 01:55 PM   #6
No problem, good luck.
FYI, the wire colors may not be the same between generations.
__________________
Eclipse CD3000
Old 10-28-2009, 02:51 PM   #7
Does the FSM have the wire colors? Is that the best place to look?
__________________
Old 10-28-2009, 09:16 PM   #8
It should. I doubt you have access to installer databases so yea the FSM would be best.
Though a LOT of wire colors (especially for audio) have been posted in this forum. Look around.
__________________
Eclipse CD3000
Old 10-29-2009, 05:24 PM   #9
I was doing some thinking today. A few years ago I bought this: http://www.crutchfield.com/p_500KCA1...&ssi=0&tp=1672 so that I could connect my ipod to the alpine stereo. Before I bought it, I remember taking the dash apart to look at the back of the stereo. From what I can remember, there were at least 4 RCA outputs, but there wasn't anything plugged in. I tried plugging in my 1/8" RCA y-cable for my ipod into one of these (complete car audio noob back then, didn't know that that wouldn't work), and it obviously didn't work. Then I ordered the adapter linked above, and all was fine. Now to the point: since the 70-7551 utilizes the RCA outputs on aftermarket stereos, and the RCAs on that alpine 'could' be unused, this leads me to believe that it is hooked up some other way. Am I out of luck? Should I just wait until I take apart the 96 to come to a conclusion? I just spent quite a while reading through the bose radio/speaker replacement thread, and it's all starting to make better sense now.
__________________
Old 10-30-2009, 06:04 AM   #10
Quote:
There are two ways to get signal out of your aftermarket HU.
1. High level amplified speaker signal - wire them directly to unpowered speakers. Format: Speaker wires
2. Pre-amp level unamplified RCA wires - wire them to an amp, then amp to speakers. Format: RCA plugs
The Bose HU uses speaker wires, but an unamplified signal. So what the 70-7551 does is takes the unamplified RCA wires from the aftermarket HU and converts the format to the speaker wires that the rest of the Bose system uses.
I'm not sure what you mean by 'could be unused.' If you're using the 70-7551, the 4 RCA plugs coming out of your Alpine WILL be used.
__________________
Eclipse CD3000
Old 10-30-2009, 06:40 AM   #11
What I'm trying to say is that best I can remember, there wasn't anything plugged into the RCA's when I took it apart last. I'll just wait and see and mess with it when I get home tonight I guess. I can get a more definite description then.
__________________
Old 10-30-2009, 07:03 AM   #12
Oh, gotcha. Then the only other alternative is that the speaker outs are connected.
__________________
Eclipse CD3000
Old 10-30-2009, 08:58 PM   #13
Well here's the verdict. I opened up the dash and as I had remembered, the RCA outputs are not being utilized. Everything runs through this Peripheral Interface Component. I took pictures, and I'm going to post them in order coming out of the alpine and going to the stock bose harness.
This is right out of the alpine, on it's way to the interface adapter, lots of splicing. What's this grey box? It's got the alpine logo on it.
Next is the Peripheral Interface Component
Here's some more splicing after the peripheral adapter.
And lastly the plugs to connect to the bose harness.
Now, I unplugged the alpine from the bose harness and plugged the stock bose headunit back in. First time didn't work; had power but no sound, great. I plug the alpine back in and turn it on, everything works fine. Then I took everything apart again, plugged the stock bose headunit back in, and voila! Sound, everything! So it looks like the bose is going back in and the alpine is coming out so my dad can sell the car.
Here's a pic of the alpine in the dash now:
__________________
Old 10-30-2009, 11:15 PM   #14
Got the bose all back in, everything is working. Only thing is the bose headunit is a little shoddy. The display doesn't turn on all the time and the cd player will not work at all. Get sound on AM/FM, so that's really all it needs. The max is getting traded in soon. I might have a few more questions in the morning about the alpine and splicing. I'll take better pictures, too. Thanks for the help so far.
__________________
Old 10-31-2009, 12:11 PM   #15
The grey box is the in-line fuse holder. The peripheral box looks like a LOC.
You took the LOC out with the Alpine, correct?
__________________
Eclipse CD3000
Old 10-31-2009, 01:39 PM   #16
Oh yes. Here's a picture of the whole line out of the car:
I was looking at the wiring diagrams out of the owners manual from Alpine, and it seems like all of the wiring out of the back of the 9811 is the same as some of the newer units (9886). So correct me if I'm wrong, but would this be plug-n-play compatible with a newer alpine unit in my 01 as long as the harness on the new alpine is the same?
__________________
Old 10-31-2009, 03:15 PM   #17
Yep, should be PnP with newer units. But I'd still double check when you receive the newer unit.
__________________
Eclipse CD3000
Old 10-31-2009, 03:31 PM   #18
Would there be any noticeable difference in sound quality being set up like this? If not, I'd be completely down with reusing everything I have. It would obviously be easier to just reuse the cabling that I already have. If I try and sell the 9811, could I sell it with the cabling that comes with the 9886, or would it be better to re-splice all of the new cabling from the 9886 with the one I currently have?
__________________
Old 10-31-2009, 10:09 PM   #19
Doesn't matter, sell the HU with the original parts that came with it. Doubt you'll get anything more for the LOC.
__________________
Eclipse CD3000
Old 10-31-2009, 11:46 PM   #20
Well, I wasn't trying to get more out of it. I was just asking based on pure ease of installing a new alpine head-unit on my part, rather than having to re-splice. That's all.
__________________
Old 11-01-2009, 10:59 AM   #21
Yea, as long as the wires match just use what's already spliced. There's no difference in sound quality between one harness and the other.
__________________
Eclipse CD3000
Old 11-02-2009, 04:17 PM   #22
That's what I figured. Thanks for all your input man. I appreciate it.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
