Where can I place my remote wire?
OK, if any gurus know this, then you gurus do. I want to put my subs and amp in my new mazda. The car is only like 3 months old tho so I am not going to haul my dash apart yet. I have a Kenwood 1000W amp with the plug to be able to tie it into my back speakers so I don't need an aftermarket deck. My question is, without taking my dash apart, is there somewhere I can splice the remote wire for the amp into? Like somewhere that looses power when the car is turned off but has power when the acc is on?
There has to be a way or why was this kind of amp made..
Thanks in advance
Thanks in advance
if you want you can take your underdash apart (I know you wanted to avoid this, but it really isn't as bad as taking the radio out) and get to the ignition switch wires - grab an accessory wire or an ignition wire.
usually when I do installs and the person doesn't replace the HU, I grab signal and remote behind the radio anyways, in case they ever decide to replace the HU, you then don't have to re-run the RCAs.
do you mean pop open the plastics below the steering column? They are probably different, but there are only 2 wires running into the ignition correct? One being the acc and one running to the ignition switch?
either one will work fine, but Id just grab the acc's that way your car doesn't have to be on in order for the amp to be.
yes, the dash beneath the steering column. No, theres going to be about 6 wires. You want the white, or pink for your car (these are accessory's), or the blue wire (this is an ignition)
thanks man...now i feel a little more comfortable with it. I just need to figure out which one of the speaker wires to use for sendig sound to the subs. I don't have that original plug that came with the amp. It was made in '91
so basically i take wires and run them from the + and - of the speaker into the + and - of the channels of my amp? I have a 4 channel amp (i know, not the greatest, but it works) and then do the same for the other speaker into the other + and - terminals of the amp? That sounds like it would work to me, but i don't know and thats why I didn't do it yet lol
oh boy
No, thats backwards. the + and -'s on the amps are probably outputs which means they will go to the sub (or whatever you're powering).
do you have a line output converter? you're going to need one to change high level (speaker lines) to low level (RCA) and go from there to the RCA inputs on your amp. Then, standard power, ground, remote, and the outputs to your sub.
oh boy
LOL...sorry for the confusion. I've only done amp and sub installs with an aftermarket deck b4, it makes it a hell of alot easier.
Ok, so I run my power wire from the battery, the remote wire from the acc wire, ground to the chassis. Thats step one.
Step 2 is buy a Line Output Converter and run that into one of the rear speakers.
Step 3 is to run the rca's from the LOC to the amp.
Step 4 is to run the wiring from the amp to the subs.
Then give it a try? lol
well it has come to me having to take the headunit out and place the LOC behind there. When i went to hook it all up yesterday, i see that the rear speakers are in the doors. This requires me to run wires from both rear speakers to the trunk and then attach the LOC. Thats a pain in the *** if you ask me. So, 4 clips and 2 screws and i have my head unit in my hands. Sounds much easier.
Also, there is an "acc" wire running into the HU so i can just attach my remote wire into that, correct me if I am wrong.
Sound like a plan?
i guess you might as well, you will need to tap a wire from the harness.
if you go through the fuse box you can just pull the fuse, stick the wire in either hole from the fuse blade and jam the fuse after it, either way is a piece of cake
TKHanson
11-24-2018 01:39 AM
