Go Back   Maxima Forums > Maintenance, Tech, & Care > Audio and Electronics
Thread Tools Display Modes
Old 09-07-2008, 10:18 AM   #1
Subs making noise and loud thump
Hey guys,
I got in the car this morning and noticed sound coming out of my subs when I turned on the car. When I turn off the car it makes a loud thump on the subs as the amp shuts off. I checked all of my wiring and everything is connected right. I ran new RCA's and speaker cable to see if that was the issue and I still hear engine noise coming from the subs. I've had my system for a while and never experienced this issue until now. The HU is new and my amp is at least 2 years old. Could it be the amp?
__________________
05 Smoke 6MT
Interior: Blue neon, Blue L.E.D's, Pioneer Avic Z2, Phoenix Gold Xenon 12" subs, Xenon 1200 watt mono amp, Stinger wiring, cap, custom box, and amp rack.
Performance: Nismo short ram, NWP spacers, and home made grounding kit.
Stoppers: RPT cross dimpled/slotted rotors, PBR Ultimate pads, RPT SS brake lines.
Exterior Mods: Black headlights, Tinted tails, and Nismo gunmetal rims (need tires )
Under construction http://www.cardomain.com/ride/2222452[/list]
myer84 is online now   Reply With Quote
Old 09-07-2008, 12:28 PM   #2
Send a message via AIM to dnozzle2789
if you're hearing engine noise with your subs, then im going to assume that you mean engine whine when the rpms go up... if thats the case, then you need to run you're power wire and rca's apart from eachother so they're not close. Or you need to find a new ground... as far as the thump in the subs...it happens to me occasionally, and when i switch songs sometimes too...i was once told what it was, ill try and find out
dnozzle2789 is offline   Reply With Quote
Old 09-07-2008, 01:11 PM   #3
and then im almost postive that the thump is just youre amp turning on and off. no worries if you ask me..it can get annoying though
Old 09-07-2008, 01:30 PM   #4
Thanks for your replys. Let me give you a little more detail. I've had my system for over two years. I recently (about three weeks ago) finished my new setup. I have had audio install experience for over 4 years and know the basics. I have my power and RCA running seperatly. RCA's run on the passenger side and power on driver side. For the past three weeks my system had been working with no issues until this morning. I really dont hear engine wine on the subs. Its more like a buzz that stays constant and doesn't change its tone when I rev my car. When I shut the car off the thump comes on very loud. Another thing I discovered is that when I play a song the subs dont hit. I can hear and see the subs moving,but at a low volume even though the volume on my stereo is high. Its almost likethe signal is not going through the amp.
__________________
05 Smoke 6MT
Old 09-07-2008, 01:53 PM   #5
yeah, it could be the amp, i mean, two years...hm. I was gonna ask you, you have a monoblock amp with the 2 12's...are those subs dual 4 ohm or dual 2 or single...i had a similar problem running my jbl dual 4's off of my jbl monoblock amp. trying to be one ohm stable when monoblock (atleast my amp) cant be one ohm stable, that and a combination with my little battery can't push the power thirsty monoblock..but you have a cap, so im assuming its not the battery..
the buzzing..its in the subs and not the doors?
__________________
2k SE grey lustre auto
AE blacked headlights
15% tint all 'round
20 x 8.5 tsw vortex
trunk covered with stinger roadkill
2 jbl power series 12's - 2 jbl 700.1 amps - 1 jbl cs.60 4 channel - 4 pioneer revs 6.5" - panasonic cq7005u h/u
CAR AUDIO FTW
Old 09-07-2008, 02:12 PM   #6
The amp is 1200 watts mono running 2 ohms since the subs are dual 2ohms. I couldn't go any lower since my amp only handles up to 1 ohm stable.
There is nothing wrong with the power on my system. Recently bought a yellow top and I have a grounding kit with 0 awg runing from negative post to chasis. The cap is on just for looks. I bought the damm thing before I knew they are not necessary. The digital readout on the cap makes the system look cool. That's why I havn't removed it
__________________
05 Smoke 6MT
Old 09-07-2008, 02:19 PM   #7
haha, yeah, i feel the same way about caps...well..that rules out the batt. haha. unless its something ever so simple as reverse polarity somewhere, which with you're experience im sure you would of corrected that right away, im clueless with these details, and my only 2 cents is..amp? try hookin up a diff one for a min, see what happens...? sorry i cant be of much help.. wish you luck on it
__________________
15% tint all 'round
20 x 8.5 tsw vortex
CAR AUDIO FTW
Old 09-07-2008, 02:29 PM   #8
Lol. Thanks for your help. I will take my lil bros amp and see if I'm still facing the same issue. If his amp works with no noise than I know for sure that its my amp that doesn't work anymore.
Anyways if that is the case than I will have to find someone to fix my amp.
__________________
05 Smoke 6MT
Old 09-07-2008, 09:02 PM   #9
send back to mtx? or hey,i if it doesnt work anymore, just get 2 smaller mono's :-)
__________________
15% tint all 'round
20 x 8.5 tsw vortex
CAR AUDIO FTW
Old 10-02-2008, 11:55 AM   #10
my car was doin the same thing when i first put my amp in and it was caused by a bad ground. As soon as i changed the location of the ground my problem went away
c.mayer is offline   Reply With Quote
Old 10-04-2008, 09:11 AM   #11
Quote:
+1
find a better ground.
Nycist is offline   Reply With Quote
Old 10-04-2008, 09:27 AM   #12
My sub is flat.
Send a message via AIM to nishfish871
check the rca input maybe you only need one of them in cause it's mono.
__________________
HU: Eclipse CD8445
Front: Rainbow SLC265 <-- Eclipse PA5422 Bridged
Rear: None
Sub: 1 Arc Audio Flatline D2 <-- Arc Audio Kar1000.1v
Second Skin Pro, Stinger RCA's & 0 Guage Wire, and a whole lotta other stuff
nishfish871 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
