Go Back   Maxima Forums > Maintenance, Tech, & Care > Audio and Electronics
Thread Tools Display Modes
Old 09-04-2008, 02:06 PM   #1
Send a message via AIM to tbombs32
fuse question no tail or engine gauge lights
so my entire engine gauge(spedometer tach gas oil), bottom A/C lights and my taillights/license plate lights all went out randomly. i checked most of the fuses and didnt find anythin. anyone know what fuse or the cause of this could be??
__________________
tbombs32 is offline   Reply With Quote
Old 09-07-2008, 10:07 AM   #2
Send a message via AIM to djfrestyl
It's a fuse, tail lights and gauge lights are on the same circuit. If you didn't find it yet, you're not searching hard enough
Don't forget there's a fuse box under the hood too...
__________________
Eclipse CD3000
Audison LRx 6.9-> Rainbow SLC 265.03, (2) 10" DLS Reference W710's
Knukonceptz 1/0awg / Cascade VB2Max / Stinger / Viper / Optima
Exterior: stock-tastic.
I can install your suspension and stereo. Inquire for prices.
Is your spare tire cover sagging? Trunk have a big DIP in the middle? Check this out!
http://forums.maxima.org/general-maxima-accessories-all-generations/357978-saggy-spare-tire-cover-solution-sale.html
djfrestyl is offline   Reply With Quote
Old 09-07-2008, 10:08 AM   #3
Send a message via AIM to ChrisMan287 Send a message via MSN to ChrisMan287 Send a message via Yahoo to ChrisMan287
Definitely a blown fuse. Check all your 7.5 fuses carefully.
ChrisMan287 is online now   Reply With Quote
Old 09-18-2008, 01:00 PM   #4
Send a message via AIM to bambino
Haha, that happened to me yesterday night as I was driving back home... My taillights, license plate lights, shifter lights, and stereo lights went out. I know we have 3 fuse boxes? right? One under the steering wheel, one on the engine/hood, but where's the passenger one that I hear people talk about from time to time?
bambino is offline   Reply With Quote
Old 09-18-2008, 01:34 PM   #5
Send a message via AIM to rocklee2029
DUDE i have the same exact problem! well in order to fix the taillights look under the hood. theres a fuse box on the drivers side next to the battery and air intake box. there should be a 15amp fuse for TAIL L. thats the one you change out for the taillights/license plate lights/cornering lights. i was able to fix my taillights that way... however still having issues with my gauges, havent had the chance to take it in to get it checked. but hopefully the fuse for the gauges/climate control/gear box is the only problem with those lights... that fuse is a 7.5 amp. the fuse box is under the driver's side dash.. look under INT ILL. that should be the culprit. if the fuse blows again after you put in a fresh one.... i dunno wat to tell ya i have the same prob =/
__________________
"every one of us has to find a reason to do this. you don't climb into a T-180 to be a driver. you do it because you're driven."
-Racer X. Speed Racer.
rocklee2029 is offline   Reply With Quote
Old 09-19-2008, 06:33 AM   #6
thanks a lot... I guess I have my little project for the weekend.. Hope you get yours fixed too...
Old 09-29-2008, 02:56 AM   #7
The passenger side fuse box (at least, on an 04 Max) is under one of those plastic covers on the left hand side. Once you get the cover off (pop screws, just lift the center part, twist and they should come right out) it'll be just above the coolant reservoir.
Unfortunately, I can't seem to find a fuse diagram for it on the internet anywhere, but you're having the same problem I am currently. I imagine it's a fuse that's blown, I just need to get some daylight so I can check 'em all without a billion flashlights.
--Jed
Akodo Jed is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
