power wire question
power wire question
I just got finished running my power wire (4ga) and I ran it along the large split loom above the fender liner and through the large firewall grommet. Once inside the wire is near the all of the car's electrical wires. This my be a stupid question but will the power wire cause any interference with the car's electrical system where it is? I don't think there is any other place to run it.
For all of you who run 4ga or bigger, how do you make it fit under the side sills? Mine is barely under there and I haven't even started running the speaker wire.
The car is an '02 Maxima. Sorry for such a noobish question, this is my first time doing this and I want to make sure it's right.
Thanks.
Thanks.
Originally Posted by dejahn23
Hey MACH999 that large firewall gamett where is it. did u have to go under the car or can U do it from just under the hood?
I used this guy's instructions as a guide. Very helpful.
http://www.vqpower.com/v2/readarticle.php?article_id=9
Originally Posted by viperxiv
I'm confused on this. What exactly is that a picture of in step 4, and how did he get the wire there from step 3?
The picture in step 4 is a the large rubber grommet that is on the inside fender on the driver's side. The wires for this come out right above the driver's side kick panel. If you remove the fender liner you can't miss it.
I didn't use the opening in step 3. I used the opening right next to the battery. A large piece of black conduit runs into this opening, just follow it. I'm at work right now but I can take some pictures when I get home.
