power acoustik gothic series amp overheating
Old 01-08-2007, 06:19 PM
Mr. Blue Sky's Avatar
I have a new PA gothic series OV2-1200 amp that is scalding hot to the touch when I play loud music for any period of time. After about 10 minutes of music at top volume, it makes a fast clipping noise and is really hot to the touch. I have it bridged at 4ohms mono with Dual brand Dual 1200 Watt subs. How can I remedy this problem, should I just do some more tuning to it and see if that helps the problem? It is also on full crossover. thanks in advance for your help. I am an audio setup noob so any help will be greatly appreciated.
Mr. Blue Sky is offline
Old 01-08-2007, 07:05 PM
AscendantMax's Avatar
put it to low pass, crossed around 80 hz or so. also how are the gains set?
AscendantMax is offline
Old 01-08-2007, 07:58 PM
Ok, I will do that. I will also check how the gains are set, since I don't remember at the moment.
Old 01-09-2007, 10:06 AM
Tried it again today on lowpass with it being set to about 70-80hz(no frequency gaps as far as I could tell) and the gains set about 40-45% and it still heats up pretty quickly when at full volume with bass set at mid strength in the HU. I am thinking it might be the gauge wire that I am running. I am running 8 guage which worked well before with the same speakers but different amp(not a 1200 watt amp). Should I move up to 4 AWG?
Old 01-09-2007, 01:42 PM
mattj10's Avatar
i am not familiar with your amp but it is usually smart to feed the amp the largest power wire its terminals will allow, as that is usually the recomended guage as well.
mattj10 is offline
Old 01-09-2007, 01:48 PM
tastey wheat
mendon99's Avatar
how are the sub(s) wired? sounds like you have it wired down to 1 ohm on a non-1 ohm stable amp...
mendon99 is offline
Old 01-09-2007, 01:53 PM
the subs are bridged, they are in an enclosure which came that way from the factory.The amp itself says it has 4ohms mono(bridged) (2 ohms stable in stereo) on the packaging
Old 01-09-2007, 05:02 PM
a lot of amps are not stable at 2 ohms when bridged. maybe the final load of the subs are below the amp's stable operating range. and yeah, 8 gauge is too small IMO for anything above 800 watts.
Old 01-09-2007, 05:48 PM
tastey wheat
mendon99's Avatar
yep. anything above 600 watts really needs to be 4 awg. IMO, should be 400 watts and up for 4...
mendon99 is offline
Old 01-09-2007, 06:15 PM
§è~® f®ÈÄk
nismos14's Avatar
Safe bet that you need to change the wiring on the enclosure.
nismos14 is offline
Old 01-09-2007, 06:33 PM
thanks guys, I am going to buy some 4 guage power wire and ground wire.
Old 01-09-2007, 06:43 PM
arkainshadow's Avatar
well the dual, dual subs systems are all 4 ohm so it sounds like there probably is something wrong with the amp... if im right to small of power wire wont heat the amp up it will heat the wire up.
arkainshadow is offline
Old 01-09-2007, 08:45 PM
well these subs fried my last amp after a year, which was a dual brand amp that had only 300 Watts RMS. I think that was due to low wattage of the Amp(was a 420 peak watt amp),and that amp only overheated when I was running 10 guage wires. Once I went to 8 guage, it was fine for a year. this amp has the same symptoms as my last one, so I do think that it is a wiring problem. I mean the subs sound worlds better now than they did with the old amp, but it heats up quickly when I have it on high volume or strong bass settings. Here is a link: Power Acoustik OV2-1200
btw I am running it as 1 channel(bridged)
Old 01-09-2007, 10:41 PM
kpr10is's Avatar
I had one of those OV2 series amps blow up on me (in my friends car) about 5 years ago running it at too low an ohm load. Literally. Went up in smoke. Never touched power acoustik since.
Ill bet yours is running at 2 ohms bridged. Unbridge the amp to run it in stereo and see if the problem still remains.
kpr10is is offline
Old 01-09-2007, 11:04 PM
how should I do that?? It has something like this + - | + - and I have it on the far left positive and far right negative. Should I put it on the far left positive and negative or the far right positive and negative, and if I do how should I get rid of distortions that will occur in the sound????
Old 01-10-2007, 05:47 AM
§è~® f®ÈÄk
nismos14's Avatar
No, go in the box and do this :
nismos14 is offline
Old 01-10-2007, 10:04 AM
^ but that will give you 8 ohm. his subs won't get much power. IMO he should just get a monoblock, wire it down to 2 ohm, set the gains properly and be on his merry way.
Old 01-10-2007, 10:42 AM
§è~® f®ÈÄk
nismos14's Avatar
The way he's wired now is gonna blow his amp. So either less power or blown/overheating amp OR buy a new amp thats 1 ohm stable.
nismos14 is offline
Old 01-10-2007, 12:54 PM
so I should just return it and get myself a monoblock amp???
Old 01-12-2007, 08:37 PM
now gs's Avatar
just rewire your subs, it's a two channel amp. use them or blow the amp. pa is not realy a good brand, if this one goes try jl,rf,ppi something like that. i bet you will not have does problems anymore.
now gs is offline
Miket2006
03-01-2021 03:55 AM
leatherneck
09-30-2015 09:16 PM
sliptap
09-30-2015 05:57 AM
Quick Reply: power acoustik gothic series amp overheating
