i want to use stock remote with a aftermarket siren. possible?
Old 09-09-2006, 08:19 PM
No More Maxipad
lowincash's Avatar
i currently have a phyton something alarm system on my car and i like the sound of the chirp when i arm/unarm the car. actually that's the whole reason i got the alarm...is for the sound haha i like the stock remote tho. my question is can i hook the stock chirper siren thing to the stock alarm system?
so instead of honking when the stock alarm is set off it'll chirp like a regular car alarm? i also want to make it so when i arm the car instead of a honk it'll chirp. is it possible to do so? thanks.
lowincash is offline
Old 09-10-2006, 07:27 AM
Suspension Yoda
djfrestyl's Avatar
1. Stock is not an alarm. It is simply keyless entry.
2. Need more information. Are you planning on disconnecting your horn? Because then your horn won't work at all, eg., through your steering wheel.
If you want to INTEGRATE the siren in conjunction WITH the horn, first verify that the voltage/signal going to the horn when arming the factory keyless entry is the same as the voltage/signal coming from the alarm when arming the aftermarket alarm. I'm pretty sure that the circuitry that makes the siren chirp the way it does is inside the siren itself, it doesn't come from the brain, so you should be ok there.
And I don't think you can mess anything up by trying this if you know what you're doing, as long as the factory voltage going to the horn is enough to power another siren as well.
Either way, this is a pretty crappy/ghetto/ricey way to make people think you have an alarm when in reality you don't.
djfrestyl is offline
Old 09-10-2006, 07:28 AM
Suspension Yoda
djfrestyl's Avatar
And also, if your aftermarket alarm works, why are you downgrading to stock? This logic has bigger and more holes than swiss cheese.
Old 09-10-2006, 08:35 AM
No More Maxipad
lowincash's Avatar
ya i'm just going to stay with the alarm i have now. i just wanted to use the stock key fob cuz i like the way it feels and look compare to the remote that comes with the alarm.
Old 09-10-2006, 09:43 AM
Suspension Yoda
djfrestyl's Avatar
Your priorities are kind of skewed....
aw11power
10-10-2021 04:57 AM
chisam14
11-06-2018 08:56 PM
bigdogsteve
01-31-2018 04:18 PM
sliptap
09-30-2015 05:57 AM
Kyle Lee Cleveland
09-28-2015 09:03 AM
Quick Reply: i want to use stock remote with a aftermarket siren. possible?
