Go Back   Maxima Forums > Maintenance, Tech, & Care > Audio and Electronics
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Sponsored by:
Click Here
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 07-11-2006, 08:08 PM   #1
Points: 7,956, Level: 60
Points: 7,956, Level: 60 Points: 7,956, Level: 60 Points: 7,956, Level: 60
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to spencediggy Send a message via Yahoo to spencediggy
Directed 2400D amp..Opinions???????
Wassup ... I recently bought a used 1000bd rockford fosgate amp and tried to run it on a 1 ohm load(2 HX2 punch 12" subs). i last about a week before it started clipping. im running it on 4 ohms 500w rms but i wanna play 1000w rms again.
Click the image to open in full size.
i found an amp the was affordable, Directed 2400D, that does 1200w rms at 1 ohm load. is this amp good? what? let me know.
__________________
www.photochopworld.com
Custom Signatures - $10, PM if you're interested!!!
spencediggy is offline   Reply With Quote
Old 07-11-2006, 10:51 PM   #2
HitManSE's Avatar
Points: 3,569, Level: 37
Points: 3,569, Level: 37 Points: 3,569, Level: 37 Points: 3,569, Level: 37
Activity: 0%
Send a message via AIM to HitManSE
Damn they are really messing up the #'s now. The 2400Dused to be the D, which used to be the 1200D...which was the 1100D
They are decent amps, nothing special. They will do rated power, just make sure you get a fan on them. My 1500D didnt like heat too much, it never cut off while playing, but after a short drive & shutting the car off for a few min & back in to take off it didnt go on numerous times. No doubt due to the heat, then again I am in Phx so you might just be alright up there.
Now if this is the older model 2400D, then its a bit different. That will put out 1200 @ 4ohms and about 2400 @ 1ohm. The only reason im thinking its the previous gen directed amps is because there is no current gen directed amps that im aware of. So im personally leaning toward the previous gen which will pull a lot more power then your thinking.
HitManSE is offline   Reply With Quote
Old 07-12-2006, 12:34 PM   #3
Points: 7,295, Level: 56
Points: 7,295, Level: 56 Points: 7,295, Level: 56 Points: 7,295, Level: 56
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
I thought the 2400D does its power at 2 ohms.....
Fast1one is offline   Reply With Quote
Old 07-12-2006, 02:30 PM   #4
Activity: 0%
Amplifier Specifications:
* Number of Channels: 1 - Mono
* RMS Power (4 ohms): 400 watts x 1 chan.
* RMS Power (2 ohms): 600 watts x 1 chan.
* RMS Power (1 ohm): 1200 watts x 1 chan. - this is what i'm looking for!!!!
* Bridged RMS Power: Not Bridgeable
* Peak Power Output: 2400 watts
* Min. Impedance Unbridged: 1 ohm
* Min. Impedance Bridged: Not Bridgeable
* THD @ Rated RMS Power: 1%
* Speaker Level Inputs: No
* Amp Preamp Outputs: Yes - 1 Pair
* Built-in Crossover: Yes - LP
* High-Pass Crossover: N/A
* Low-Pass Crossover: 30 Hz - 250 Hz
* Subsonic Filter: On / Off
* Signal-to-Noise Ratio: N/A
* Channel Separation: N/A
* Bass Boost: 0 / 8 dB
* Bass/Gain Remote: N/A
* Fan Cooled: Optional
* Fuse Rating: 30A x 3
* Warranty: 1-year SE
Old 07-12-2006, 03:30 PM   #5
HitManSE's Avatar
Activity: 0%
Interesting, I guess there is another gen of directed amps. I could hace sworn they stopped making amps
That amp above, minus the looks is the exact same amp as the previous 1500D, same as the 1200D & the 1100D. The only difference is the looks as far as I know. You should be fine, they are decent amps.
Btw your subs, they are dual 4ohm voice coils right?
Old 07-12-2006, 05:54 PM   #6
Activity: 0%
yeah meng.
Rockford Fosgate
HX2 dual voice coil 4 ohms 12"
500w rms
1000w total power handling
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
