installing indash DVD player
for those of you have installed an indash dvd player, i have a few questions. there are a few wire that i havent seen before. there is a Brake wire and then also a back wire, both seem to be need to connect and get the player to work. any suggestions would be help
irish
irish
Ok buddy im kinda having a little trouble understanding u, but what i can understand is that u have a black cable and an e-brake cable right? Well both should be connected otherwise ur dvd player wont work. They do this in order to avoid people to drive and use dvd functions at the same time. Tell me wht kind of dvd player is this? I have a pioneer and didnt connect mine to the e-brake. I just connected the wire to a switch and ground (no power). With this I trick the HU to think i'm in park mode. I would check around first though because some DVD players are different and might need to connect urs diferently if u want to bypass the safety feature. The other cable(blk) should be grounded.
is it a microvision indash? if so check this thread:
http://forums.maxima.org/showthread.php?t=455920
my guess is the black is ground. what are the other wires attached?
edit: did you mean 'black' wire? or 'back' wire?
irish
irish
back wire.....
ya, i see it. i wasn't sure if it was a typo..
im not understanding what you mean by "back wire" then.
theres only one? what color is it? is it like a single 20 awg-ish wire? or an RCA? need more info. also never said if you had a microvision or not..
I tend to get a bit irritable
Without knowing what kind of DVD player it is its kinda hard to help. Although typically if you want to watch video while the car is running/ebrake off then you should just ground the brake wire.
"Back" wire is most likely for a backup camera activation. Although Again...we dont know what kind of unit this is...
MaxLife17
06-27-2019 01:37 PM
t6378tp
09-29-2018 04:27 PM
