View Poll Results: Which sub should I get
Adire Brahma 12D4
42.86%
Sound Splinter RL-p12 D4
57.14%
Memphis M-1 DVC
0%
Voters: 7. You may not vote on this poll
Hmmm, which subwoofer?
I have a spare box and amp laying around, and I'm thinking of doing a temporary setup in my Maxima. I'm just not sure which subwoofer I want to get.
The amp is my old Memphis M-Class D, 500x1 @ 2ohms. The amp has shown it is 1 ohm stable, but I would rather keep the sub in the 2 ohm range.
So I have narrowed it down to 3 choices.
- Adire Brahma 12D4
http://www.adireaudio.com/Mobile/BrahmaSeries.htm
- Sound Splinter RL-p12 D4
http://www.soundsplinter.com/rlp_pre...subwoofer.html
-Memphis M1 DVC
http://www.memphiscaraudio.com/produ...at=&id=166&p=2
2 are quite close in price, with the Brahma being the most expensive around $420. I'm leaning towards the Memphis because the box it will be going into for now is a Audio Enhancers single sealed.
- Adire Brahma 12D4
-Memphis M1 DVC
Wheres the None of the above option? If your looking at a $420 brahma in the first place, you could do a lot better than any of those on that budget. Just my .02. But we all know Im not a nutswinger who lives and dies by the forums like most people who follow Adire and SS.
Well the M1 has the easy capability to repair if needed. The motor assembly is easily unbolted. I don't plan on running them that hard, so it's an option that I really don't need.
I've looked through most of the other brands out there. I'm actually thinking of the SS now. But I'm going to go next weekend to take a look a closer look at the M1. Luckily I know the owner of Mobile FX really well, so I get to play around with all the goodies in the shop.
Plus with their display setup, I can easily compare them to the M-Class.
Not sure on the memphis yet, I have to go listen to them first. Plus I finally found the specs on my box and going to compare to the required specs for both subs.
Memphis, 1 sub sealed, 0.8-1.00 cu.ft.
Sound Splinter 0.75-1.75 cu.ft.
Damn... that didn't help the decision any, the box is 1.34 cu.ft.
Oh ohhh.... Don's here
SP is 2 ohm DVC Don... and when wired will give me 1 ohm, or 4 ohms. I'm looking for 2 ohms. The UR will give me that with it's 4 ohm DVC.
Forget it... I'm going to go play with the M1 tomorrow. I was going to do a friend's remote start, but it didn't come in today.
I'll know tomorrow wether I want a M1, or SS RL-p
I tend to get a bit irritable
Ben, why do you ask questions that youve already answered in your head??
Because I'm not getting the answers to my questions, just a run around
Who said anything about a UR? SP my friend, SP
And the FL is cheaper than the Brahma, so is the Ur and Iridium
Although I would rule out the UR as its no longer.
How is that? You asked a question...
Hmmm... how much is the DLS UR-12 running? (considering my amp can't push the Flatlines)
You even played along...
The box size is a match for the SS, but it's also a nice match for the M1, a bigger box than recommended will give me some deeper bass.
Last response I'll give you on this topic Don
THIS... IS not a DAMN answer, it is a run around. This was the very first post you gave me after I asked the price question. As you can see, no where in that entire post is there a answer to my question, not even a "it's not available anymore." It took you almost another 4 posts to even mention that.
As far as I'm considered Don, you can on this topic.
Originally Posted by Pearl96Max
Did you not? I simply answered it and gave you more info. You even played along...
Who said anything about a UR? SP my friend, SP.
As far YOUR post, your the one that jumped the gun. I suggested a FL or SP, then you reply with...how much is the UR. WTF is that if its not a runaround game??
You are correct in one point though, it was your last post in this thread.
jskirwin
06-08-2016 08:49 AM
