Avh-p6400 + Bose?
Avh-p6400 + Bose?
Does anyone know if AVH-P6400will work in 01 Maxima SE 20th Anniversary Edition with BOSE system in it? or what mods would i have to do to make it work? thank you in adavance.
Man. Im gonna permanently save all this typing in Microsoft word so I can copy and paste it a couple times a week. Its not your fault though hitman im just ranting lol.
Yes. You have a few options:
1) You can wire it up as a normal head unit without any Bose adapters, and have a small risk of burning up the Bose amp.
2) You can buy the $50 PAC or Scosche adapter
3) You can wire the deck's preouts so you send an unamplified signal to the Bose amps. You have front a rear preouts. Each of those has a left (white) and right (red). So youd plug in RCAs to all the front preouts. When you cut the front left, there will be 2 single wires inside it. Wire those to white and white/black. When you cut the front right, do the same and wire those to gray and gray/black. Do the same for the rears, Rear left will be the green and green/black, and Rear right will be purple and purple/black.
4) You can buy the Metra 70-7551 (which is usually hard to find locally) which will already have all of #3 above done for you, so you can just plug stuff in.
http://www.metraonline.com/i/METRAHANDOUT_2005.pdf
Page 25 of 36 is a pic of the Metra 70-7551
-Kevin
-Kevin
Originally Posted by raga55
yes, or probably any other radio with pre outs for that matter
Ahh yes. I wouldve been able to tell from the full model number. I havent seen a 6400 in person, theyre just before my time, but Ive seen the 6500dvd and 6600dvd so I figured yours was dvd too just a previous model. That sucks.
Anyway,
http://www.crutchfield.com/S-exemo6m...51&I=142C4NN03
-kevin
Anyway,
-kevin
Anyway,
-kevin
Anyway,
-kevin
will this piece work Maxima 2000+ kit with AVH-P7500 in 2k1 AE? or where else can i buy a trim piece to make it fit? thanks in advance.
Thank you.
Originally Posted by keanders21
You should be able to get the trim piece from Crutchfield.com that is where I got mine from originally for $19 bucks. Plus they also throw in a radio installation guide specific to your maxima.
trim piece from sound domain
or will this trim piece FROM SOUND DOMAIN TRIM PIECE work with my set up?
