What size fuse?
Old 06-13-2005, 07:56 AM
99maxk2's Avatar
What size fuse?
What size fuse should i run with a 4 guage wire?
99maxk2 is offline
Old 06-13-2005, 08:02 AM
Dexter's Avatar
use cylindrical fuses for those wires, much more reliable.
Dexter is offline
Old 06-13-2005, 08:04 AM
I tend to get a bit irritable
Pearl96Max's Avatar
Size would depend on your amp(s).
Pearl96Max is offline
Old 06-13-2005, 08:10 AM
99maxk2's Avatar
I am running a 1200 watt Rockford Fosgate amp and a 600 watt Rockford Fosgate amp
99maxk2 is offline
Old 06-13-2005, 01:49 PM
jigga123's Avatar
The maximum amps for 4 gauge is 125 I believe. A 100 amp fuse should be sufficient.
jigga123 is offline
Old 06-13-2005, 02:29 PM
merovi's Avatar
dont you just add up the amps on the fuses in the amps. Like if there are 2 25 amp fuses and 1 30 amp fuse, wouldn't u only need a 80 amp fuse?
merovi is offline
Old 06-13-2005, 04:42 PM
Terran's Avatar
That's my exact setup (plus a 50 and 30 amp in the dist. block splitting into two 8 ga.) and it runs fine. I believe that is how you do it.
Terran is offline
Old 06-13-2005, 05:56 PM
LeX
Nissan by Nature
LeX's Avatar
i have 180 worth of fuses and i run a 170 amp main fuse
LeX is offline
Old 06-14-2005, 12:42 PM
merovi's Avatar
well as long as ur MAIN fuse is the same of i guess a little lower its not big deal. the last thing u want to happen is the fuses on ur ampifiers go. then problems can start occuring.
merovi is offline
Old 06-14-2005, 12:47 PM
jigga123's Avatar
The fuse in the power line is for the wire and should be based upon the maximum that wire can handle. The fuse on your amps are just that, for your amps. The maximum current draw for 4 gauge should be about 125 amps. I would suggest a 100 amp fuse, its fine to use a smaller one but definately wouldn't recommend going bigger than 125 amps.
jigga123 is offline
Old 06-14-2005, 08:08 PM
99maxk2's Avatar
i just finished installing a 60 amp fuse to my 4 guage and everything works good now.
99maxk2 is offline
Miket2006
03-01-2021 03:55 AM
knight_yyz
11-01-2015 01:34 PM
leatherneck
09-30-2015 09:16 PM
Quick Reply: What size fuse?
