PAC adapter oem-2 remote wire question
I brought the pac oem-2 from cobymoby & wired everything, it works pretty well with the stock bose deck wired to an amp & the sub. But the remote wire only works when I use FM/AM radio, the amp won't turn on when I play teh CD :S
right now I have it hard wired to the battery thru another wire, and I have to disconnect it everytime I get out of the car to turn the amp off
is there anyway I can wire it to the PAC to make it turn on when I play CDs too?
I posted on the other post. But here is another system diagram color chart. 2002 Nissan Maxima Audio System Wiring Colors
Where Description Wire Number & Polarity Base System Color Bose System Color
Back of Head Unit Front Driver Side 2 (+) Blue with White Stripe White
Front Driver Side 1 (-) Blue with Yellow Stripe Black
Front Passenger Side 4 (+) Brown Green
Front Passenger Side 3 (-) Brown with White Stripe Red
Rear Driver Side 14 (+) Light Green Brown
Rear Driver Side 13 (-) Black with Yellow Stripe Black with Red Stripe
Rear Passenger Side 16 (+) Blue Blue
Rear Passenger Side 15 (-) Pink Black with White Stripe
+12v Always On 6 Yellow Purple
+12v Ignition On 10 Purple Yellow
Antenna 5 Green with White Stripe Green with White Stripe
Combo Meter 22 Red with Black Stripe Red with Black Stripe
Illumination Dimmer 7 Red with Yellow Stripe Red with Yellow Stripe
Illumination On/Off 8 Red with White Stripe Red with White Stripe
Amp On/Off 12 N/A Green with White Stripe
Front Ground 9 N/A Unknown
Rear Ground 11 N/A Unknown
CD Left Channel In 42 (+) *1 Brown
CD Left Channel In 41 (-) *1 Yellow
CD Right Channel In 44 (+) *1 Light Green
CD Right Channel In 43 (-) *1 Purple
CD Left/Right Ground 45 *1 Unknown
CD TX Data 50 *1 Black
CD RX Data 49 *1 Red
CD REQ Data 48 *1 White
CD Data Ground 46 *1 Unknown
Input of Amp Front Driver Side 33 (+) N/A White
Front Driver Side 20 (-) N/A Black
Front Passenger Side 35 (+) N/A Green
Front Passenger Side 22 (-) N/A Red
Rear Driver Side 34 (+) N/A Brown
Rear Driver Side 21 (-) N/A Black with Red Stripe
Rear Passenger Side 36 (+) N/A Blue
Rear Passenger Side 23 (-) N/A Black with White Stripe
+12v Always On 27 N/A Yellow
Amp On/Off 25 N/A Green with White Stipe
Amp/Woofer Ground 40 N/A Black
Output of Amp Front Driver Side 30 (+) N/A Blue with White Stripe
Front Driver Side 31 (-) N/A Blue with Yellow Stripe
Front Passenger Side 28 (+) N/A Brown
Front Passenger Side 29 (-) N/A Brown with White Stripe
Rear Driver Side 18 (+) N/A Light Green
Rear Driver Side 17 (-) N/A Black with Yellow Stripe
Rear Passenger Side 41 (+) N/A Blue
Rear Passenger Side 42 (-) N/A Pink
Subwoofer 24 (+) N/A White
Subwoofer 37 (-) N/A Black
Input of Subwoofer Audio 44 (+) N/A White
Audio 43 (-) N/A Black
+12v Always On 48 N/A Red
Amp On/Off 45 N/A Green with White Stripe
Ground 47 N/A Black
Output of CD Changer Left Channel Out 6 (+) *1 Brown
Left Channel Out 16 (-) *1 Yellow
Right Channel Out 5 (+) *1 Light Green
Right Channel Out 15 (-) *1 Purple
TX Data 11 *1 Red
RX Data 10 *1 Black
REQ Data 12 *1 White
+12v Always On 3 *1 Yellow
+12v Switched On 1 *1 Purple
Ground 7 *1 Black
*1 There is no indication as to whether or not the CD Changer is supported by the base system. The wire colors are the same in either case.
________________________________________
2002 Nissan Maxima Steering Wheel Wire Layout
Wire A:
The Mode, Up, and Volume Up all connect to this wire.
The Mode button is a direct connect and does not use a resistor.
The Up button passes through a 150 ohm resistor.
The Volume Up button passes through a 605 ohm resistor.
Wire B:
The Down and Volume Down all connect to this wire.
The Down button passes through a 159 ohm resistor.
The Volume Down button passes through a 606 ohm resistor.
Wire C:
The Ground is connected to this wire.
The Ground is a direct connect and does not use a resistor.
Wire D:
The Trip button is connected to this wire.
The Trip button is a direct connect and does not use a resistor.
Location Wire Pin Number Color
From Switch to Steering Column A 1 N/A
B 2 N/A
C 3 N/A
D 4 N/A
From Steering Column to Spiral Cable A 14 N/A
B 15 N/A
C 16 N/A
D 19 N/A
From Spiral Cable to Main Vehicle Harness A 34 Red
B 33 Blue with Yellow Stripe
C 32 Brown with White Stripe
D 25 Green with Red Stripe
From Main Harness to Back of Head Unit A 26 Red
B 27 Blue with Yellow Stripe
C 29 Brown with White Stripe
From Main Harness to Combo Meter D 63 Green with Red Stripe
Disclaimer of Liability: The information provided here is "as-is", meaning that I am not responsible for it's inaccuracy. Every means possible has been made to verify its accuracy, however, I am in no way liable for any modification/damage/etc that may occur from misuse and/or inaccuracy regarding this information.
The Frye
09-02-2021 11:03 AM
