Go Back   Maxima Forums > Maintenance, Tech, & Care > Audio and Electronics
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-26-2004, 05:26 PM   #1
Wants the EVO X
MyownNismo's Avatar
UD pulley and stereo
I have a 1000 watt amp running two 10's. I also have one 1 farad cap and stinger deep cycle battery. Will a UD pulley be bad for my situation.
__________________
Custom intake w/Apex-i filter, Cattman headers & Cat-back, 350Z RAYS wheels 18X8.5 33 offset w/ Yokohamma S-Drives, 2001 AE AT w/ Stage II VB, ADV Timing 17 degrees, Stillen 2 piston BBK W/ Coleman Racing 2pc Rotors(front), Racing Brake Rotors w/Hawk HPS pads (rear), Stillen Bodykit, Smoked 2k2 Headlights, Progress Springs, Tokico illumina's, Stillen RSB, FSTB. ES motor mounts, ES suspension Bushings.
MyownNismo is offline   Reply With Quote
Old 08-26-2004, 05:41 PM   #2
if your talking about an underdrive pulley, and the altenator, then i guess the altenernator will do its job still, well probably even better since the udp would spin much faster than a stock one, so your battery would be charged up quicker.
__________________
2 Da Max is offline   Reply With Quote
Old 08-26-2004, 07:00 PM   #3
Quote:
absolutly wrong the pulley spins the same speen but has a shorter circumference thus moving the belt less causeing the alternator blet to not move as fast.
I cant answer your question but you could probably get away with a blue top and a cap
__________________
2001 Red Z28 5.7 mmmmmm
waveridr85 is offline   Reply With Quote
Old 08-26-2004, 09:28 PM   #4
lol my bad i wasnt thinkin bout dat
__________________
Old 08-27-2004, 07:51 AM   #5
Wants the EVO X
MyownNismo's Avatar
Well Unorthodox racing makes a SC pulley. Which is basically a lighter pulley than stock which gives you thr HP. It isn't a underdrive cause it isn't smaller. I will get that one.
__________________
Old 08-27-2004, 08:53 AM   #6
i have my udp and a 2000 watt amp pushin 3 audiobahn 12's. no problems for me..... but then again i only had my udp for about 4 months. pics on my website
__________________
A few Upgrades Here and There
http://www.cardomain.com/ride/2659568
Magikone69 is offline   Reply With Quote
Old 08-27-2004, 01:26 PM   #7
Maxima of the Month Winner
An underdrive pulley does turn the alternator slower than the stock pulley (at a given RPM), but this has no effect on how it charges the system, because an alternator charges throughout the entire RPM range, even at idle.
In the "old" days, cars had generators which put out lower voltage at slower RPM's. This is why they don't put generators on cars anymore.
I have an Unorthodox Racing UDP on my 04' Max, and have had no problems so far. As a bolt-on performance item, I recommend it. Good bang for the buck.
04RedOpMax is offline   Reply With Quote
Old 08-30-2004, 08:50 PM   #8
Send a message via AIM to image
im running a yellow top.. to 0 guage.. to a cap.. to a ditro... then to my (2) JBL 1200.1 Amps and a JL Audio 300.4.. you think i will be able to do a UDP set? I doubt it.. but worth a shot.
__________________
03 Cobra
95 maxima - R.I.P.
image is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
