Need some help with a sub and amp...
Old 03-18-2004, 03:11 PM
DrX
DrX's Avatar
Right now I have an Alpine 7893 hu and JL xr650s front and rear just on the hus internal amp. It sounds great but I want to add a sub. I don't want the thing to crush or anything, just some filler bass to pick up where the speaker's mid-bass leaves off.
I was thinking a 10" jl sub in a sealed box, powered by a jl 250w amp. How does this sound?
Also, since this box isn't going to be very big, how do you think I should secure it in the trunk? I don't want it flying around back there.
Thanks guys.
DrX is offline
Old 03-18-2004, 03:20 PM
MannyNJ2k2max's Avatar
That would be fine....although if you are doing a single sealed sub I'd go for a 12" for a little more bottom end.....
Your local Home Depot has a variety of L brackets you can use to bolt the box down....
MannyNJ2k2max is offline
Old 03-18-2004, 03:49 PM
slickrick's Avatar
where do you put the lbrackets? my box keeps moving around and i can only seem to put the l brackets in the carpet and they have fallen off.
slickrick is offline
Old 03-18-2004, 05:54 PM
DrX
DrX's Avatar
hmmm...I was just looking on JLs site and I found this stealthbox with a 10" already in it. Anyone use one of these? How do they sound?
http://www.jlaudio.com/stealthbox/maxima.html
DrX is offline
Old 03-18-2004, 06:24 PM
guyincognito's Avatar
I just purchased a stealth box. Will let you know once I have it installed and how it sounds.
guyincognito is offline
Old 03-18-2004, 06:31 PM
I know of some 4th gen/5th geners using a piece of wood /mdf at least 3/4 in thick ....the length of the trunk from wheelwell to wheelwell (approx 30+ inches) ran under carpet/trunk mat.....so you then position front to middle of box over that
and use L brackets to secure box to board and the weight of it should be enough from having any slidding probs.....
that board actually helps level you box at a nice position.......whereas without it its on a slight incline....
I myself have to work on that after i build my custom box for my 12"....
Old 03-18-2004, 07:11 PM
DrX
DrX's Avatar
Can I ask where you got it from and how much? Also, what amp are you going to run with it?
Definitely post up the results.
DrX is offline
Old 03-18-2004, 10:57 PM
slickrick's Avatar
hmm... i cant stand how my trunk is not level. so how wide would the mdf have to be? because wouldnt i only want it to be about 1/2 as wide as the box so it will make it even with the floor and level?
Old 03-19-2004, 04:04 AM
i think a 4" X 3?" 1/2" (or3/4") MDF will do
Old 03-28-2004, 02:27 PM
Blak MaX's Avatar
[SIZE=5]
[FONT=Arial Black]
I was wondering if u had installed the jl stealth box and what you think of it
if you can give me any info about it like how much it costs and what kind of amp your powering it with
thanx
Blak MaX is offline
Old 03-28-2004, 02:35 PM
friendhasmax's Avatar
after you build the custom box?
don't you mean after I build it? which is already in ur car
friendhasmax is offline
LeX
Audio/Video/Electronics
05-24-2007 07:09 AM
Ant96GLE
07-07-2004 12:31 PM
Ninty-two-se
01-05-2004 04:08 PM
Jung918
10-07-2001 10:50 AM
Quick Reply: Need some help with a sub and amp...
